#1 |
Yellow Brake light and Triangle with ! with Circle
Ok, so bought i used bmw and have had a few issues of which a quick search on here has found the right fixes, one thing i have searched for and cant really geta clear answer for is that when i start the car, there is a yellow brake light on as well as the triangle with the ! with a circle, all the searching has done nothing as i could not find anyone else with the same problem,
any help would be great, Thanks |
#2 |
something is wrong with DSC
#3 |
ok, so what would one do ? take it to a shop?
is this something i could fix my self? also pushing and holding the dcs button for 3-30 seconds does nothing Last edited by ScouseYank; 12-30-2012 at 01:00 AM. Reason: extra info |
#4 |
you need to diagnose it, it could be anything. Check the fuses, take it to an indy or someone that has a BMW scanner and they can pull codes and tell you exactly what's wrong.
#5 |
My Ride: my favorite two feet
you could try the stomp test and see if you get any codes from that if not, try the basics like unplug the battery for 30-60 minutes then repeat stomp test and see if any new codes come up. Agreed on checking the fuses as well after doing the code test. If possible use a code reader but if you don't that's a good place to start
#6 |
Its either a steering angle sensor or a wheel speed sensor.
.:Eugene:. I used to be an e46 owner. I love this one more. ![]() |
#7 |
Have you tried just pressing the DSC button once and releasing it immediately?
#8 |
Banned User
It was the steering angle sensor for me. Fastest thing to do like people have said is to go get it scanned by an indi, or if you're suicidal by the dealer. The steering angle sensor was fairly expensive from what I remember. Good luck!
#9 |
The steering angle sensor (SZL or SLZ, can't remember) was around $1000 when I was pricing it for an E90, to give a ballpark.
#10 |
Banned User
#11 | |
#12 |
Don't start anywhere with out getting the codes read first. You'll just waste time and money ****ing around.
Sent from my PC36100 using Bimmer App
#13 |
Banned User
#14 |
Correct me if i am wrong but is the ! with the Circle around it just the traction control? the DISC button just needs to be pressed for a second or so to turn it off and on.
#15 |
Banned User
If evrything is working properly that's true but combined with the yellow brake light it means you've got a more serious problem like the ones above.
#16 |
Could be thinking of different dash light, but one would come on all the time driving in the snow. Snow got stuck up all in the brakes and by that sensor...
#17 |
Speed sensors work by detecting changes in magnetic flux density as rotating elements move in and out of the sensor's magnetic field. They are basically permanent magnets with a coil wrapped around them. Anything that interferes, obstructs or bridges the normal gap between the magnet and the rotating element (eg: snow, mud) can have an impact on the voltage of the pulses received by the DME which, in turn, can be interpreted as fault resulting in automatic shutting down of DSC as precaution. So check the cleanliness and integrity of the wheel sensors first.
#18 |
Bad wheel speed sensor.
Scan the car to see which is throwing error and clean it with a wire brush. Might as well clean all of them while your at it. If cleaning doesn't work just replace the sensor. Takes 5 min .
![]() TC Kline | BMW Performance | Active Autowerke . |
#19 | |
![]() What I meant was, when snow got packed up in my brakes, the light would sometimes come on and then go off when it was clear again.
![]() Last edited by sweetbro858; 12-30-2012 at 01:43 PM. |
#20 |
If is the steering angle is about $300 in E90 the SZL brings the steering angle that is the reason of the price $1,000
