Old 12-30-2012, 08:50 AM   #1
erlstifen
My Ride: E46 323i
Send a message via Yahoo to erlstifen
Alternative coolant for E46?
Sent from my GT-I9100 using Bimmer App
erlstifen is offline   Reply With Quote
Old 12-30-2012, 08:55 AM   #2
330iPilot
My Ride: Titanium Silver 330i
You can use other coolants but genuine BMW coolant is only a few dollars more so I just stick with that.
330iPilot is offline   Reply With Quote
Old 12-30-2012, 09:37 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Also use distilled water, DO NOT USE tap water.
Old 12-30-2012, 09:41 AM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Why are you looking for an alternative? It's hard to beat the BMW-brand coolant.
Old 12-30-2012, 09:42 AM   #5
zhenkaaaM3
My Ride: Fst'r then your e46
No difference. 50/50 prestone
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-30-2012, 10:35 AM   #6
Sweetness
My Ride: '01 325i
Zerex G-05
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 12-30-2012, 11:13 AM   #7
wildirish317
My Ride: 2004 325Ci vert
Here's the best thread I've seen yet on coolant:
http://forum.e46fanatics.com/showthr...errerid=227595
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-30-2012, 11:47 AM   #8
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
JPR also had a great post on coolant somewhere...
From what I know, it's OE or G-05, but just yesterday saw a BMW coolant bottle posted here that had a typo...said Volvo in one instruction and BMW in another...so some Volvo coolant would work too, I suppose.
It should be a $25 investment every few years. I have to do mine...will plan on it in the spring when I put in a new WP just to be safe(r).
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-30-2012, 12:23 PM   #9
LeMansteve
I would not assume Volvo coolant is the same. Based on the thread you mention, I would only assume the bottle manufacturer made a printing error. They may make coolant and/or bottles for Volvo and BMW, but that does not mean the coolants specs are identical.
Old 12-30-2012, 12:28 PM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
Zerex G-05 or Mercedes Benz coolant.
Old 12-30-2012, 12:29 PM   #11
RoOs
My Ride: 2004 BMW 330i ZHP
Volvo coolant is same as BMW.
RoOs is offline   Reply With Quote
Old 12-30-2012, 01:04 PM   #12
Grande D
My Ride: E36 M3
Originally Posted by Sweetness View Post
Zerex G-05
This.
Prestone is inferior. I've run an E46 with Prestone for 6 months, and when I did a full flush it was blowing chunks (that weren't there before).
It will change your life!
Old 12-30-2012, 05:59 PM   #13
wildirish317
It's most likely the label supplier who's at fault. I used to work in a distillery, and we purchased labels from one supplier, bottles from another, caps from a third supplier, and glue from yet another supplier. Although, somebody at the bottling plant should have "proofed" the labels to make sure they are correct.
Old 12-30-2012, 06:11 PM   #14
scarede46er
My Ride: 2001 BMW 325i ZSP
Prestone/Supertech Long life work perfectly well. Flush every 2 years and you will be OK.
Old 12-30-2012, 09:41 PM   #15
erlstifen
My Ride: E46 323i
Thanks for the advices... I may just stick with bmw coolant.
Old 12-30-2012, 09:45 PM   #16
TerraPhantm
My Ride: M3 & ZHP
Volvo coolant is G48, so chances are it's the same as the BMW stuff. I doubt it'd be significantly cheaper if at all.
The Volvo community isn't nearly as anal as the BMW community about coolant types.
Old 12-30-2012, 09:47 PM   #17
erlstifen
My Ride: E46 323i
Thanks for this... It made me understand more the principle of it
