Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 12-29-2012, 12:18 PM   #1
thecarguy
My Ride: M3
Strut tower reinforcement plates - does mine already have them??
I'm not sure if the previous owner installed strut tower reinforcement plates on the 05 330i zhp I purchased about 2 years ago. I bought the plates from a dealer several months back and have just put off installing them. I then started wondering if there is a way of "seeing" the plates from the top?
Last thing I would want to have happen is go to the effort of dropping the strut down to discover it already has them.
thecarguy is offline   Reply With Quote
Old 12-30-2012, 12:15 PM   #2
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
It just a black disc that goes between the top of the strut and body of the car.
Looks like this:
Stiggles is offline   Reply With Quote
Old 12-30-2012, 12:19 PM   #3
rcsummers
Mister TechnoMeister
rcsummers's Avatar
My Ride: M3
looks like you do.
if you didnt, above the strut would be that same grey color.
"RICH"
EURO.TECHNIKS
My Build Thread
rcsummers is online now   Reply With Quote
Old 12-30-2012, 12:24 PM   #4
Stiggles
Stiggles's Avatar
I'm not the OP
Old 12-30-2012, 12:41 PM   #5
rcsummers
rcsummers's Avatar
My Ride: M3
Hahahah totally read that all as one post
"RICH"
EURO.TECHNIKS
My Build Thread
Old 12-30-2012, 12:49 PM   #6
Stiggles
Stiggles's Avatar
Lol
I like the camber in your sig
Old 12-30-2012, 12:52 PM   #7
thecarguy
My Ride: M3
Looks like this:
Perfect, thanks for the pic. I'll check her out!
Old 12-30-2012, 04:06 PM   #8
rcsummers
rcsummers's Avatar
My Ride: M3
Lol
Hah thanks. It's about -4.2 there
"RICH"
EURO.TECHNIKS
My Build Thread
Old 01-29-2013, 04:55 PM   #9
yannis4ny
My Ride: 2004 325ci conv
would you consider selling them? I need a pair
yannis4ny is offline   Reply With Quote
Old 01-29-2013, 09:39 PM   #10
peytonracer4
My Ride: '00 328i
does anyone know if these raise the car at all?
i'm wanting to raise my front maybe 2 mm and this would be a nice and easy way to get a little lift.
i don't want to take the springs out and put different spring pads on.
choose to click or forever hold your piece ;)
Old 01-29-2013, 09:52 PM   #11
yannis4ny
take a 2mm aluminum sheet, machine it and make holes on it. then install it in the place of this reinforcement. you can get it from:
http://www.mcmaster.com/#standard-al...sheets/=l95ty1
Old 02-01-2013, 10:53 AM   #12
Stiggles
Stiggles's Avatar
Do not do this.
The reinforcement plates are shaped specifically for the strut towers. Using a flat piece of aluminum creates stress points, and mushrooms your towers even quicker.
If by “machining” you imply that you’ll be shaping them, why go to all that effort?
BMW sells the plates for around $10 each, and yes they’ll add about 2mm to the ride height.
Old 02-04-2013, 11:08 AM   #13
yannis4ny
Do not do this.
Thanks for the info, I was planning on doing this actually.
Old 02-06-2013, 10:56 PM   #14
Stiggles
Stiggles's Avatar
No problem, I hope that saves you some trouble
