Project: Useless E46 - Page 22 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 74 votes, 4.96 average. Display Modes
Old 12-19-2012, 11:45 PM   #421
RyanKW
My Ride: BMW 330i
so freaking dope dude. Can't wait to see the MTechII kit installed on your car.
RyanKW is offline   Reply With Quote
Old 12-23-2012, 12:27 AM   #422
LoveBeingUseless
My Ride: 2003 325i Sedan
So sorry I havent been posting a whole lot lately. I have been busy with Christmas shopping and what not. My car just struck 91,500 miles and I found my valve cover gasket starting to leak a little. So I picked up a gasket kit after work the other day and changed my valve cover gasket. I know there are DIY's on how to do valve cover gaskets. Its pretty simple, I thought I would just point out a couple tips along the way.
First of all I wanted to share I got a new thrust plate. It was crammed behind a ton of other old parts in our storage at work. Cleaned it up
Gonna take mine to my buddy and have him reinforce the **** out of it.
Then Got to work on the valve cover gasket. Removed he microfilter housing.
After you pull off the engine covers, next step is to remove the coil packs. For the push-down style coils like mine, here is a little tip to getting the coils out with ease. They can be a fight you trying to remove some times. First unclip the coils from the harness. Simply take a mid size screw driver, stick it through coil. Set the handle on something sturdy and pull up on the other side to lever it out.
A thing a lot of poeple dont think about is called PREVENTATIVE MAINTAINANCE. I'm not just talking about gasket and filters. Things like vacuum lines, hoses, coolant flushes, ect. All these things matter believe it or not and can easily leave you on the side of the road just as easily as a blown water pump. An example is, I change my spark plugs every 60K because newer plugs make your ignition coils work less. There for they will last a lot longer. You could change your plugs twice for less than the cost of one ignition coil. Not to mention the better performance/gas mileage/engine cleanliness spark plugs bring.
Basically it is always a good idea to keep your eyes peeled for little things that are easy to fix. A little work now can save you big headaches in the future. Trust me I see poor cars come through everyday that get so neglected.
I found a vacuum line starting to come apart at my secondary air valve so I went ahead and replaced it. A little trick to remove small air lines without damaging the line is take a metal 90 degree angle pick, lube it up with some wd40 or dry silicone spray. Gently slide it into the airline and work it around (careful not to damage the inside of the hose) so you can slide it off without breaking it. The line was brittle as hell, and came apart anyway! Glad I changed it
I have a habit of doing this. Mark and identify what is what when you have similar connectors.
Be very careful when pulling the valve cover off. Take your time and slowly let it detatch from the head. The heat from the engine can practically glue the valve cover on. So gently pry it up from multiple spots on a side of the valve cover to release it.
Clean all the mating surfaces very thoroughly. Install the new gaskets in the valve cover. Put RTV on the half moons of the gasket and where the upper front timing cover, head and valve cover meat (front sides of head).
Are you curious if your valve cover gasket is leaking? Take a look at the bank 2 exhaust heatshield. You will start to see oil accumulate there and it will look like this.
Thats all for now guys!! More to come
Front:18x10 et12 Rear: 18x10 et20
Check Out My Build Thread:
For more updates, Follow me on Instagram! @LoveBeingUseless
LoveBeingUseless is offline   Reply With Quote
Old 12-23-2012, 11:48 AM   #423
tock172
My Ride: '12 135i Dinan S2
My reinforcement plate is a mess too. Might replace it someday. Great DIY!
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 12-29-2012, 10:31 PM   #424
dinan19
My Ride: 2004 Imola ZHP
I can tell you have put alotf of time an dedication to your car. Nice work and car looks great!
Old 12-30-2012, 04:01 AM   #425
Fuxxo
My Ride: E46 330D Mpaket tour
Send a message via ICQ to Fuxxo
nice mine looks similar.. I see that you too dont have the lid there :-D I've lost it somewhere..
and it would be great to reinforce it, thats great idea
E46 330D Mpaket touring - Street Rocket..
Wheelslist.net: Your #1 OEM list of wheels!
My Thread..
Fuxxo is offline   Reply With Quote
Old 12-30-2012, 12:58 PM   #426
honkifyoubonk
My Ride: E 6666
when you say put rtv on the "half moons" where exactly do you mean?
honkifyoubonk is offline   Reply With Quote
Old 12-30-2012, 01:08 PM   #427
LoveBeingUseless
I apologize for the vague manor I explain some of the things.
If you look at the picture below of the valve cover and the old valve cover gasket. At the front and back of the gasket there are 2 rubber bumps, commonly refered to as the half moons due to their semi-circular shape.
When replacing the gasket, you want to apply two small blobs of Black RTV on the sides of the half moons and a thin film over the top to help ensure a proper seal. I'm sorry I dont have pictures of it! Many good DIY's show this step.
Old 12-30-2012, 01:16 PM   #428
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Damn! Wish I would have seen that about the half moons. Now I almost want to re-do it before my VCG gets all crispy.
hi its me alec is offline   Reply With Quote
Old 12-31-2012, 10:39 AM   #429
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
If it's not leaking you don't need to...
Schlag96 is offline   Reply With Quote
Old 01-16-2013, 01:41 AM   #430
LoveBeingUseless
So happy that it was time to do my front brakes. I cant wait to do my rear. The previous owner had put some crappy aftermarket pads on, and my god does it make your pedal alot squishier. I didnt do anything crazy yet, just went with factory size for now because it is easy on the wallet and I'm not sure what BBK I would like to go with.
I went with ECS Tuning Geomet Rotors, Genuine OEM BMW Semi-Ceramic Brake Pads, and Genuine OEM BMW Brake Pads Wear Sensor.
The ECS Turning Rotors are awesome. I got them for a great price during the christmas sale. A set of quality front rotors for less than $130 shipped. They are coated in an aluminum coating to prevent rusting and to keep them looking good. It is a very similar coating to what comes on BMW's factory rotors. I am very happy with them and give a big to ECS Tuning.
People often under estimate the quality of BMW OEM brake pads. An e90 M3 or E60 M5 all have single piston sliding brake calipers with semi floating rotors. No fancy 6 pot rotors or anything, but my god, the braking power would blow you away.
One little side note...
Got a new Canon 1.4f 50mm prime for my camera. I love it!!!!!
Now back on topic.
Got her set up on the blocks.
The parts set up waiting to get put on.
Took off the front wheels... Look at them ugly front brakes. Rusting like hell for living in socal.
Old pads are getting low.
Old pads out.
Old rotor off. Comparison between old vs. new.
Cleaned up the hubs from left over rust.
Installed new rotors.
Cleaned the calipers up and compressed the pistons. Make sure you take some brake fluid out of the reservoir so it doesnt over flow when you compress the brake pistons back in to the calipers. Removed and cleaned these horrific guide pins.
Cleaned them up and relubbed them with some anti-sieze
Cleaned the caliper carrier and relubricated the guides. Prepped the pads.
All back together!
I properly bedded the brakes and it is night and day.
Old 01-16-2013, 03:28 AM   #431
ode_joy
My Ride: E46 318td Compact
Very nice upgrade! Tell me, your brakes are smaller than 330i, right? I've got 30d/30i brakes, and it's one of the best modding I've made in my compi.
BMW 318td Compact E46 Kit
ode_joy is offline   Reply With Quote
Old 01-16-2013, 06:24 AM   #432
vassilisvot
My Ride: E46 Convertible
Send a message via MSN to vassilisvot
About new rotors...Tell us some information...
vassilisvot is offline   Reply With Quote
Old 01-16-2013, 04:41 PM   #433
Fabster760
My Ride: E46 318ci
Damn that stretch is serious! Great setup, car looks clean, great write up! I'm suppose to be hitting the sack but then I started reading and I don't regret it keeping me up And I do enjoy seeing pics of home
Wish I could go that low tho
Fabster760 is offline   Reply With Quote
Old 01-16-2013, 05:07 PM   #434
cak323i
My Ride: ///M3 & 330i ZHP
Your car is looking awesome! Are you planning to install the MTec II kit? I thought you mentioned that you were planning this....
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 01-16-2013, 05:49 PM   #435
erod225
My Ride: 2003 M3XI
Originally Posted by LoveBeingUseless View Post
Dude thats probably the lowest E46 i've ever seen... EPIC!!
erod225 is offline   Reply With Quote
Old 01-16-2013, 07:11 PM   #436
DSeyf
My Ride: b6s4
makes me miss my e46
DSeyf is offline   Reply With Quote
Old 01-17-2013, 01:07 AM   #437
SK8URDEAD
My Ride: TopazBlu 325I
idk this chicks is pretty low
but i do love these in silver my buddies is pretty sick aswell.
but your car does look clean. once you throw on that MTech it'll make the car look totally different. atleast thats how i felt once i put the MTII on my car just happy to drop her next month aswell
325i Topaz Bluuu
Umnitza MTech II Body Kit, M3 Steering wheel, ZHP Weighted Shift Knob, Muffler Delete, Resonator Delete, Khoalty LED Tail lights, LED Corners, Bimman LED Side markers, Long CAI, Koni FSD's + B&G Lowering Springs, Black Suede Headliner + Pillars, Thule 753 Roof Rack n Fairing, AvinAvant2, 5% Rear 20% Front Tint. No such thing as DONE lol.
SK8URDEAD is offline   Reply With Quote
Old 01-17-2013, 01:28 AM   #438
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
gross tattoo (any tattoo)
and tell her to get her foot off the car
/_________\
O==[][]==O
Old 01-17-2013, 01:29 AM   #439
330i ZHP
330i ZHP's Avatar
and take off the shorts
/_________\
O==[][]==O
Old 01-18-2013, 12:58 AM   #440
SK8URDEAD
lol thats physically her car. i think she can stand on it if she wants haha.
325i Topaz Bluuu
