#21 |
Any way I could know if it's the starter?
#22 |
If it's cranking, it's not the starter.
#23 |
That crank sensors yelling your name pretty loud about now, lol.
#24 |
Please just check your crank sensor for crying out loud.
#25 | |
My Ride: '06 330CiC, '03 M5
I believe all cars support this, typically once the throttle is above 75% during cranking "clear flood mode" should be enabled. The only exception that I can think of is if a TPS is way off and cannot see more than 75% throttle position.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#26 |
#27 |
How do I "just check my crank sensor". Unless i'm mistaken, it's on the bell housing, very difficult to reach. If there is a way to troubleshoot and test it i'm all for it, just haven't heard of a way...Thanks in advance.
#28 |
best way to check is to pull codes
pic of sensor located under the starter motor. starter motor removed here for clarity. nasty to get to. Last edited by Stinger9; 01-16-2013 at 07:19 PM. |
#29 | |
Stay stock my friends!
In rereading, I'm struck by this 'it worked when you repositioned yourself facing downhill.' Prior you had no lights, no cranking...then everything comes to life. So...check battery connection...make sure the battery is tightly clamped and pull up on the clamps to check. Check where the bst is connected...some screw on terminal...haven't done anything with it myself, but others have had issues with it getting loose. I'm thinking of things affected by change in position...electric connection to battery seems not unlikely. I wouldn't go on randomly trying to help you, but this is sweeps week at Fanatics, and I can't let Mango get more votes than me...I know I'm much nicer, even if he seems to actually know stuff! So...it's not crank sensor or any other sensor...because you have no codes. What would lead to your issue without throwing codes...very significant. I like the loose connection somewhere now--grounds, bst, clamp on battery terminal. Also, this immobilizer? If you have an AM device, or an alarm, then there's a tilt sensor, isn't there, so alarm goes off is someone is towing your car...something like that? Maybe a motion sensor? Maybe part of that is wonky...and the dealer was thinking it too, otherwise why play with another fuse (if I read you right). You wrote that like they replaced a fuse just because...not because it was blown. They were thinking that...but if 'they' though replacing a good fuse with another would fix anything, I don't know. Read up on immobilizer issues...if you have an alarm, maybe some part of the system thinks it's locked...maybe your key is going bad (does happen...and that it happened to you with both keys, doesn't prove it's not the keys)...order a replacement key (not valet), so you have a known reliable chip (maybe? I don't know if the chip fails intermittently, but think ews system does get bugs at times...a number here have needed new ones. A few thoughts...and if any help, either vote for me or post pic of Marisa...my usual fee!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax Last edited by dmax; 01-16-2013 at 09:23 PM. |
#30 |
thanks for the input! How do I vote for you?
