Old 11-30-2012, 12:17 PM   #1
Elephant1
My Ride: E30, E36, E46, E39
M54 ZHP motor/trans into '99 323i
I've got a '99 323i 5spd and a buddy has a 2004 330 ZHP that he's pulling the motor/trans from. I had no intention of doing a motor swap but if I can get the motor locally cheap (and the 6spd trans) I might as well consider it. But what is involved in this?
He planned on keeping the DME for the project he's working on so I'd be short that. I would get the wiring harness and the complete engine, trans, & driveshaft, just would be missing the DME. I have a 3.38 diff already (though it's just an open diff for now).
So what is involved? I'll need a DME I presume...what about instrument cluster?
Thanks for any help. Cheers.
Jack Money
E30 M3
E46 323i
E39 540 6spd (wrecked, parting out)
E36 M3 (for sale as roller/race car project)
Elephant1 is offline   Reply With Quote
Old 11-30-2012, 04:11 PM   #2
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
You can use ur DME. Just have to do some Custom stuff and etc...
Old 12-01-2012, 09:58 AM   #3
Elephant1
What is the custom stuff? TBW I assume is one.....that's why I'm thinking it'd be easier to do the correct dme. I still have plenty of research - and time fortunately - before this is a concern but I want to understand it. I was hoping I sent the first to try this, and I guess I'd be surprised if I were.
Jack Money
E30 M3
E46 323i
Old 12-05-2012, 06:36 AM   #4
TerraPhantm
My Ride: 2005 M3 Coupe
If you want to use the correct DME, you'd either need to get one with a matching EWS, or get your EWS and keys synced with the new DME (RPM Motorsports can do this)
Old 12-13-2012, 02:04 PM   #5
Elephant1
If that's all I need to worry about then no problem, that's cake. I have no problem picking up a used DME and having it all sync'd up. What about ABS....any interaction there? Instrument cluster? I'm used to E30 and E36 swaps where all that stuff is separate of the engine for all practical purposes.
Cheers.
Jack Money
E30 M3
E46 323i
Old 12-23-2012, 04:31 AM   #6
TerraPhantm
Cheers.
Hard to say for sure, but I think it'll be okay. If you were using an MS43, the electronics would definitely be fine. The MS45 is a bit of an unknown. Theoretically it should work fine -- the signals didn't change format, and the ABS controllers all communicate in the same language so to speak... but since the MS45 arrived late enough that it was never used with the early ABS controllers, it's hard to say with any certainty that you won't have issues.
Old 12-27-2012, 06:34 PM   #7
jdny516
My Ride: 323Ci/2006 X3M-sport
only thing you may have difficulty with is the wiring
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | ZSP | ZPP | Shark Injector | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
jdny516 is offline   Reply With Quote
Old 12-28-2012, 10:34 PM   #8
HakenTT
My Ride: 323i with S54
That is horrible overpriced company based in Victoria Canada. I had hard time getting my refund
HakenTT is offline   Reply With Quote
Old 12-28-2012, 10:39 PM   #9
HakenTT
Cheers.
Hello there, I have the same car as you and I did 2006 S54 swap. Not sure if CSL has MS45 ecu or MS43. Anyway, so far no one has ventured into it that much. You won't be able to get it work, you will be in "limp mode". MS45 required CAN comunication with ABS, Cluster, sterring angle sensor... and much more. Don't waste your time.
Old 12-31-2012, 02:03 AM   #10
TerraPhantm
Originally Posted by HakenTT View Post
That is horrible overpriced company based in Victoria Canada. Stay away from those guys, they will rip you off
Know anyone else that can sync a used DME with a used EWS?
1999 323i is an E46...
M54B30 should be more or less a direct swap, and almost all of the wiring is already in place if he uses the MS43 ECU. Only wiring he'd have to add is for the electronic pedal.
ZHP did come with the MS45... but he can run it off an MS43 just fine. The ECU should be able to adapt to the (slightly) hotter cams. He could raise the rev limiter to 6800 if he wants. And if he really wants, he could try tuning the base maps to accommodate the hotter cams
Old 03-06-2013, 11:54 AM   #11
Elephant1
Bringing this up again, have found a few threads of people doing the same thing I'm trying to do...'cept they don't provide much detail. Couple questions if anyone knows.......
1. I'd much prefer to NOT use TBW set up and stick with the manual 323i pedal. However, does that mean I'm stuck with the 323i TB? I'm not familiar enough with the TB's to know and I don't have the 330 TB yet.
2. So ABS is not a concern here? I plan to ditch the ASC, car has no AC already (and won't, it's a track car), not concerned about EWS or security other than the car must start and run). Hopefully this limits the pain of all the wiring disparities I will face.
I'd love to simply run my current 323i DME (which has a Conforti Shark Injector tune), especially if it simplifies things. But I'm concerned about not being able to take advantage of all the power available. I might be willing to lose a little for the sake of less complexity but I'd definitely want to understand this.
Thanks for any input, I'll definitely document this for others once I get going on it.
Cheers.
Jack Money
E30 M3
E46 323i
Old 03-06-2013, 12:02 PM   #12
E46Enthusiast20
Modded ///Member
E46Enthusiast20's Avatar
My Ride: 01 325i 3.0 Swap
I swapped the 3.0 ZHP motor from my dads totalled sedan years back. DME tune to the motors factory specs and presto. 3 years and running strong. I have a 2001 325 so it was a tad easier. No messing with the throttle nor DSC.
E46Enthusiast20 is offline   Reply With Quote
Old 03-06-2013, 04:00 PM   #13
HakenTT
Cheers.
M54 and M52TUB is basicly the same exact long block. So what do you want to do exacly?
Old 03-07-2013, 07:31 AM   #14
///Mpower3357
My Ride: 00' 323i
Sounds like u want to know if u can adapt the TB or entire head to the zhp longblock? Also, Ive heard of 3.0's running on 2.5 dme. Tuning would maximize ur gains tho
///Mpower3357 is offline   Reply With Quote
Old 03-22-2013, 09:08 AM   #15
Elephant1
So in simple terms, I have a '99 323i and have access to a low cost 2004 ZHP motor and 6spd trans. I want to put that into my car.....how hard is this? I've heard/read everything from wiring issues to DME/security, ABS, etc....all major issues. But then I've heard that it's as simple as dropping it in, swapping to the 323 throttle body and using the 323 ECU/wiring and you're good to go. My thought is that if I simply drop the motor in and swap back to the 323 TB using all the stock 323 electronics and wiring I'm going to give up something, even if it is just that easy.
So first question.......is it just that easy to drop it in and hook up various 323 stuff to use all stock electronics/wiring? If so, what am I giving up powerwise...no way it's free. This a track car only so I don't have AC, don't care about it. I don't care about EWS or security except that car obviously needs to start and run properly. I'm removing the ASC so I don't care about that either. If it's easier I'm much prefer to keep the 323 "maunal" throttle pedal but am willing to switch if that's better, need quantification of what "better" means though.
Hopefully that's more clear. Thanks.
Jack Money
E30 M3
E46 323i
Old 04-05-2013, 02:05 PM   #16
Elephant1
No further comments?
Jack Money
E30 M3
E46 323i
m54 into 323/328, m54 to 323/328 swap
