Old 12-30-2012, 02:16 PM   #1
05aazhp
My Ride: 05 330i ZHP
Bad AA Diverter valve?
Hey,
I have been trying to track down a possible vacuum leak. I have been getting a "idle speed implausible, air leakage" code. I clear it and it comes back in a day. I did several boost leak tests without finding anything. Today I did a smoke test with a home made smoke machine (glow plug and mineral oil). The only smoke leak I could find was one out of the back of the diverter valve, the port that vents to atmosphere. My understanding is that that is there to allow the diaphragm/spring to move up and down as necessary. If that is the case and I am getting smoke out of it, could the diaphragm be torn??? Any ideas would help.
Symptoms
Engine Code Idle speed implausible, air leakage
High idle - 1000rpm
Idle hangs once clutch is pressed, hangs at 1300 or so for about 2 seconds before seddling down to 1000rpm.
Set up
05 zhp
aa stage 2.5
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
05aazhp is offline   Reply With Quote
Old 12-30-2012, 08:26 PM   #2
TrippinBimmer
My Ride: Just Fast!
I am about to change my Diverter Valve to a Tial Recir Q Valve. It will be the last thing that AA build/label on my car. (All been replace with better or higher quality parts)
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 12-30-2012, 08:56 PM   #3
05aazhp
Are you changing it as a preventative measure or changing it due to suspected failure?
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 12-31-2012, 02:16 AM   #4
TrippinBimmer
My Ride: Just Fast!
Both...As the valve is adjusted by a screw. So I really don't know what HgV when the valve opening. So I rather go to a spring setup...to me more reliable and proven setup. Personal Preference...
As for your issues. I would hit up Viral hopefully he can help you.
Alpine White M3
MaximumPSI Stage4
Old 12-31-2012, 12:18 PM   #5
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
Just a thought, might your diverter valve not be hooked up properly? I accidentally ran mine backwards for a little bit. Make sure your entry and exit from the valve is right
drumbum624 is offline   Reply With Quote
Old 12-31-2012, 12:24 PM   #6
coinage
My Ride: 02 M3
Have you pulled vacuum on the valve to see if it holds?
coinage is offline   Reply With Quote
Old 12-31-2012, 02:39 PM   #7
05aazhp
The in and out is not changeable on this diverter valve. One side gets bolted onto the intake pipe and the other is round and gets sent back towards the supercharger via a small rubber coupler.
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 12-31-2012, 02:40 PM   #8
05aazhp
I don't have a small vacuum pump to try this. Could I just force open the valve and cover the vacuum nipple. This should hold the valve open correct??
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 01-02-2013, 08:24 AM   #9
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Mine does the same thing. Swap in a new recirc valve from AA...did the same thing.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 01-02-2013, 10:28 AM   #10
05aazhp
So I am assuming that the my valve is working properly. I did email AA about this and am waiting for a response. I will update you on what they say. Im thinking that this may be an issue with the tune. I forgot to mention that this started once I installed my re flashed computer. The computers estimated MPG also way off saying im getting an average of 29 mpg....in winter.....in Wisconsin. Its 12 degrees out today. There is no way im getting that. The little instantaneous gauge also is off saying that I am typically getting 50mpg, which is also incorrect.
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 01-02-2013, 08:56 PM   #11
bigjae1976
bigjae1976's Avatar
I've been told that an exhaust leak with aftermarket headers can cause idle surge and weird idling. The claim was that exhaust air is pulled back up across the O2 sensors between pulses. I guess this is not an issue with the OEM manifolds since the cat is between the precat O2 sensors? I kept burning through gaskets so I just had some V-bands installed.
But my idle still surges a bit but not terrible. I still think the tune is not totally correct.
I plan to get Eurocharged to do my tune in the near future. Remote tuning was such a PIA.
Old 01-03-2013, 10:19 AM   #12
05aazhp
I have heard this as well but I do not think that this is the issue. The idle issue started immediately after I installed the returned AA computer.
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 01-03-2013, 10:27 AM   #13
05aazhp
This is AA's response to my guestion
"The BOV leak seems to be your biggest issue. Do you have the ability to test it with a vacuum pump, or have a local shop that could look the car over? The nipple on the other side should not have smoke coming out of it, and the diaphragm could be torn.
The MPG reading will be off because of the larger injectors that go along with the kit. Instantaneous MPG is calculated by using the injector duty cycle signal. This signal is going to be very different with larger injectors and will therefore register incorrectly."
I am going to test the valve this weekend using a hand held vacuum pump. If it is for sure bad, is there a rebuild kit for this? I would hate to spend a bunch of money on a new valve when I could just replace a molded piece of rubber......
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 01-03-2013, 11:38 AM   #14
TrippinBimmer
My Ride: Just Fast!
Should ask active that question. As its there BOV.
Alpine White M3
MaximumPSI Stage4
Old 01-03-2013, 12:21 PM   #15
05aazhp
I did earlier, I am waiting for a response. I was just wondering if anybody has repaired them before. I have had no luck searching.
2005 BMW 330i ZHP
Black on Black
AA stage 2.5
Old 01-03-2013, 10:40 PM   #16
TrippinBimmer
My Ride: Just Fast!
Is your car an Auto?
Alpine White M3
MaximumPSI Stage4
Old 01-03-2013, 11:51 PM   #17
BrianSpilner
My Ride: Max PSI Stage 2
You should look into running an Alpha-N tune so you do not have to recirculate, and to avoid these problems. Also, upgrade to a Tial Q blowoff valve.
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 01-04-2013, 12:03 AM   #18
bigjae1976
bigjae1976's Avatar
Has anyone got Alpha-N right on an MS45 DME?
Old 01-04-2013, 01:22 AM   #19
TrippinBimmer
My Ride: Just Fast!
Nope...
Alpine White M3
MaximumPSI Stage4
Old 01-04-2013, 04:37 PM   #20
Mormon
My Ride: 2001 330xi
Subbed
Mormon is offline   Reply With Quote
