Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 11-29-2012, 10:16 PM   #81
Hornung418
My Ride: '04 MB ZHP
ETA 12/03/12.
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 12-01-2012, 05:43 PM   #82
Hornung418
My Ride: '04 MB ZHP
Just got a B30 throttle body for $40. New gasket thrown in for free! Just waiting on delivery and some new intake boots from the dealer when the time comes to do the swap.
Old 12-03-2012, 07:26 PM   #83
Hornung418
My Ride: '04 MB ZHP
Got a package today full of fun things Thought I was getting the whole engine harness on the cold side for the MAF, TB, etc. but that didn't come with the supplies.
Need Intake boots and some MQS contact bushes and the special crimp and I'm ready to make a my very first wiring harness.
Old 12-26-2012, 04:05 AM   #84
Angelic0-
My Ride: BMW E34, E46 & E38
Send a message via MSN to Angelic0-
Okay, this thread has been very enlightening for me...
Hope i'm not being rude threadjacking you guys a little bit?
I'm doing a M62TU swap into a E46 that had a M43B19 engine prior...
Both have what i beleive is referred to as A6000 style DME... (MS42,43,45 are A6000 style?)
I'm not sure which, and that is why i'm here
The M62TU utilizes wich DME ?!?!
Looking at electronics from the car, and the X60001, X60002, X60003, X60004 and X60005 connectors, it seems that apart from having to ship my ECU to RPM motorsports for a EWS recoding, the DME will plug up perfectly and i will only need to wire up the accelerator pedal...
Can anyone confirm this for me and answer the above mentioned questions, i have been basing my knowledge on my research of MS42 and MS43 schematics...
Thanks in advance you guys, all help is really appreciated....
Angelic0- is offline   Reply With Quote
Old 12-26-2012, 02:31 PM   #85
Hornung418
My Ride: '04 MB ZHP
Looks like the last M62tub44 utilized Bosch Motronic ME7.2. Not much I can do in the way of help. Only familiar with Siemens ECUs.
Old 12-26-2012, 06:39 PM   #86
Angelic0-
can you see if the M62TUB35 utilized a different unit ?
and where can i see the pinout for a ME7.2 DME ?
I only need to know if the input from a E46 will have the same pins as the input from a E39...
If everything is the same, i can just plug up and wire in the throttle pedal....
Old 12-26-2012, 07:47 PM   #87
Hornung418
My Ride: '04 MB ZHP
Probably the same motronic unit.
Try spaghetticoder and see if you can pull up the info. Start your search on bmwfans.info using the vin from your donor engine.
Old 12-30-2012, 03:49 PM   #88
Hornung418
My Ride: '04 MB ZHP
Bump for me...
Thinking about saving the cash on the engine management tuning part and just having the MS43 unit coded to EU2 330 specification. Part number: 12 14 7 552 618.
Thoughts? Besides the intake camshaft and the .2 displacement difference, the engine would essentially be the same. MAF, TB, Manifold/DISA, Fuel Injectors, Headers and O2 sensors. I have a set of stock 330 cams in my basement collecting dust and can throw the intake cam in if necessary. I think it will adapt for the missing displacement and make some great numbers. Looking to get this project moving as soon as I receive the engine harness promised to me by Bavarian Motor House.
Happy New Years!
Old 12-30-2012, 07:41 PM   #89
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by Hornung418 View Post
Bump for me...
Happy New Years!
Might be okay.
I could try studying the maps in the MS42 and MS43 and help you port them over. I've been learning a lot with the MSS54. Another ECU might be fun
Old 12-30-2012, 08:55 PM   #90
Hornung418
My Ride: '04 MB ZHP
Would be great if you have time. Thanks TP.
Old 12-31-2012, 11:33 PM   #91
TerraPhantm
My Ride: M3 & ZHP
Honestly I would see how it runs with a stock 330 tune before making any other decisions. It might run a bit rich, but it'll probably actually be more appropriate than the 328 tune, simply because you're getting a good bit more air flow than with the stock manifold.
I definitely wouldn't spend several hundred on a tune in your shoes though. I'd rather put the money into getting a 3.0 rotating assembly.
Old 01-01-2013, 01:05 AM   #92
Hornung418
My Ride: '04 MB ZHP
I don't want to go that far. I'm quite happy with my lil 2.8. I want to see how much I can make with that before I get into internal swaps. Next step is to get that LSD and replace all the rear end bushings with the AKG 90A and weld in the TMS kit, because I'm certain that there has to be some kind of damage back there, although I'm hoping it's clean. Checked out okay with the Class Action Lawsuit, but I don't think they really looked at it that much to really be able to tell if it was cracking.
No matter, if you're still outside of DC for your internship we could meet up and do some coding. Engine harness is on it's way should arrive by the 7th. Need to get boots and I'm done.
Old 01-01-2013, 11:32 AM   #93
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Hurry hurry. I am waiting for u to finish your ms43 swap.
sent from my HTC EVO+ using Bimmer App
Old 01-01-2013, 12:56 PM   #94
Hornung418
My Ride: '04 MB ZHP
its coming!
Old 01-02-2013, 04:09 PM   #95
HakenTT
My Ride: 323i with S54
delete
HakenTT is offline   Reply With Quote
Old 01-02-2013, 04:13 PM   #96
flashmeow
Banned User
Originally Posted by HakenTT View Post
RPM motorsports in Victoria Canada are scam artists, his name is Zach and he is a scammer, don't send your ecu to him.
Can u please elaborate? He wanted to charge me $400 just to flash my dme
Old 01-02-2013, 04:26 PM   #97
HakenTT
delete
Old 01-02-2013, 04:35 PM   #98
Hornung418
My Ride: '04 MB ZHP
So how can you align the EWS and the DME? Have you found a solution? I think its best to just get them as a pair.
Old 01-03-2013, 09:11 PM   #99
TerraPhantm
My Ride: M3 & ZHP
Fair enough - I understand not wanting to get too crazy with building up the engine. I only mentioned it since a good tune would cost about as much as a good condition rotating assembly anyway.
I'm not in DC at the moment, but I'll probably be back late spring.
Old 01-05-2013, 06:14 AM   #100
Angelic0-
They are overpriced on everything. It is one man company, his name is Zach, he charged my credit card right away and did not ship the DME. After 4 days I asked to cancel my order because I can't wait more, he said he will ship within 3 days. He also charged me canadian sales tax and their terms and policy says US buyers don't pay tax.
It took him 20 days to do partial refund, he charged me %30 restocking fee and he never shipped the DME. I am in credit card despute now, zach is totaly not honest person, don't do bussiness with these bums.
I'm talking to Chris @ RPM Motorsports Ltd,.
He's going to be charging me 350$ for coding and 40$ for shipping each way, he's going to be making a claim invoice to avoid taxes for me...
But i like your input, not really sure if we're dealing with the same company though...
I've only heard good stuff about Chris @ RPM, this is the first horror story...
