Rating:
Display Modes |
#41 |
on my car the headlight washer motor died (well the impeller in the motor broke) so i need a new motor, but i suspect that the telescoping arms (part 6 in the diagram on realoem.com) are leaking as well and if this is the case im not going to bother wasting my money.
My question is does some fluid leak out of anyone else's telescoping arms at the when you manually pull the nozzle out? I put an arrow on the attached picture where the fluid leaks out of |
#42 |
Yes, had some fluid leaking out while pulling the arms out (while installing angel eyes).
#43 |
and your system works fine?
#44 |
I replaced both pump seals/strainers recently and the leak is still there!
I presume the tank itself has a crack or is it possible brand new seals wopuld also leak? The system seems to work fine, just intermittently leaks fluid! Any tips for further trouble shooting when the obvious fix fails?
^°^ ><((({º>°° °°° H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs |
#45 |
#46 | |
![]() Another washer ordered! |
#47 |
Where you getting these from and for what price? Are the windshield and headlight pumps the same thing?
#48 |
Got my washer jet from the dealers, ~£41. Tried the breakers yard first, but the only one they had leaked when i fitted it! Grrrrrrr
#49 |
#50 |
Anybody actually tried to fix a leaking telescopic washer?
Is it just a seal that fails, or something more serious? |
#51 | |
#52 |
Fixed mine by replacing the pump. Was lucky enough to find a pump on eBay for $12 shipped.
The pump had the older part number I think that's why I got it so cheap as all the others I found were $35+. Spilled some fluid while changing as my container was fully but it's just washer fluid.. Was pretty straight forward swap. Regarding the leak on the white connector, try rotating the connector so it locks itself on. |
#53 |
for a retrofit what a wiring hardness and conector i must buy can help with a part number for wiring harness for a retrofit headlamp cleaning system in e46?
#54 |
Hey guys..not sure if the answer to this question has already been answered in this thread, if it is I apologize, but here goes...
I recently replaced the headlight washer pump on my car because the washers would not spray so I figured the pump was bad. Today I activated the washers and yes...the system now works. However, only the passenger side washer sprayed. Nothing came out of the drivers side. What do you think is damaged? The telescopic arm ? Thanks |
#55 |
325 XIT washer fluid leak question
OK, so I found my washer fluid leaked out within a day after filling the reservior. I have read numerous posts. It looked like my front (headlamp washer pump) had just raised up in it's seal and that's where the leak is from. Could it be this simple? I am wondering if the pump (also the rear one) just slides down into their respective seals? Should I just put some silicone sealer in the seal and put it all back together? I have tested both pumps, each works fine. I do not see any cracks or leaks in the reservior or either pump. I use winter grade washer fluid year round in my car so i do not think there is a freezing/expanding water issue. Also, what is strange that when I reassmeble the entire unit, the front hose with the clip going forward to the headlamp washers is too short now?! I have added a shot of the front pump attached to the hose. If I install the reservior and push this pump into it's spot, the hose pulls the pump forward so it does not seal correctly.
Thanks in advance for your help! Last edited by denvermgb; 12-30-2012 at 01:10 PM. |
#56 | ||||
#57 |
Thanks dcaron999. am going to try to put it all back together now....
#58 |
I think I found the issue. The cap on the reservior was dimpled in - I think the vent on the cap was blocked, which caused the seal around the front pump to break lose. I cleared out the vent on the cap. The washer fluid is not leaking now - I will give you guys an update to see if this was the culprit.
#59 |
A few days of sub freezing weather, holding up fine, all aspects of the system workinng fine! Thanks!
#60 |
Thx dcaron999 for your post....very helpful...removed my headlight nozzle and no doubt the air was going straight through it.....bought new nozzle online($35) and I'm waiting for it to arrive.The problem is the little plastic cover broke(the 2 ears around the nozzles) and I cant find a replacement one online.If u know where to find one (besides dealer which is my next try),please let me know....THx again
