Old 01-01-2013, 07:36 PM   #1
denvermgb
My Ride: 2002 325XIT
Alarm DIY question
I have a few questions:
1) Can I use the piezio buzzer instaed of the OEM alarm horn with the other two OEM alarm components?
2) I see some threads alluding to a DIY for the E46 Touring, but I can't actually locate it. Can anyone direct me to this DIY or does it exist? I think the tilt sensor is the only part that is different from the sedan and involves the removal of one of the side panels in the rear area?
Thanks in advance
denvermgb is offline   Reply With Quote
Old 01-01-2013, 07:58 PM   #2
e46dinan
My Ride: E46 M3, E53 4.6is
http://e46fanatics.com/faq/alarminstall/index.html
e46dinan is offline   Reply With Quote
Old 01-01-2013, 08:05 PM   #3
denvermgb
This is great! I found it previously, but I am still wondering if there is a different procedure for the tilt sensor on a wagon? This DIY is a sedan.
Old 01-01-2013, 08:22 PM   #4
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Thanks in advance
I.actually have some experience with this. The oe alarm horn was broken so we played around with it. This is what I found.
1. The BMW alarm siren is not a maintenance item. There are there Philips screws on the back but there is no way u can remove the siren. U have.to.dremel it open. The siren was welded together via ultrasonic
2. The alarm siren has a battery. The siren will still go off if someone.decides to.cut your main battery. The battery is connected to the alarm PCB via a 2pin plug. The battery is.removable.
3. The siren is insolated so there r no magnetism. The siren is.connected.to the PCB via a 2 pin connector. However, the siren is not.removable without some surgery.
4. The alarm has a PCB(printed circuit board) that provides the audio tones to.the.siren among other.things. the audio tones are programable.
As for me, I unplugged the defective siren and mounted an external speaker. I just drilled a hole on the plastic.cover and connected the speaker wires.to the PCB. We then gorilla clue the oe.alarm siren housing together. U can use JB weld too.
I hope this helps. Good.luck
sent from my HTC EVO+ using Bimmer App
Old 01-08-2013, 01:23 AM   #5
CrazyOneToo
My Ride: 1999 328i 4dr
How do you get the motion sensor unplugged?
Is there a trick to it? When removing the motion sensor case some of the tabs broke off.
I was gonna unplug the sensor and take the plastic piece out and glue them back on but cant since the wires wont allow it.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
