Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 12-29-2012, 12:54 PM   #41
diablorojo
My Ride: Supercharged 330i
Supercar: http://en.wikipedia.org/wiki/Supercar
Per definition, the ZR1 falls into that classification. Even supercars have a low and high price range, but the minimum range had to be above the average consumers means (which a zr1 is). And I doubt that anyone would argue the performance and eye catching package that was created in this car.
The other part for me, pull up to a nice venue in one and see if you get the same reaction as a 1000hp m3. Doubt it!!!
But who knows...
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 12-29-2012, 05:21 PM   #42
acpstunts
My Ride: E46 330ci / E53 X5
Planning on an LS1 swap late next season if all goes well. Will keep people posted on that if/when it does happen.
acpstunts is offline   Reply With Quote
Old 12-29-2012, 08:21 PM   #43
BMW E465
My Ride: 1dirty5
Originally Posted by JiMMyM3 View Post
No, the 46 and 36 are basically the same up front. The biggest thing is getting the wiring to work, but there are pre-fabbed kits out there with wiring harnesses, headers, motor mounts. The rest is moving things like abs etc around to make a 6.2 fit. The power is insane, no s54 2jz or w/e else your thinking will produce the numbers an ls will for a reasonable price. Parts are cheap and readily accessible, maint is cheap, and the engines are strong. Also you dont need FI to make over 600hp/550tq, and the engine is lighter than an s54.
I've only seen the motor mount kits from a German tuning company... I didn't know they had wiring harnesses too?! Do you mind sharing details on where to find these?
BMW E465 is offline   Reply With Quote
Old 01-02-2013, 12:42 PM   #44
wanganstyle
My Ride: 1998 e36 M3
Wiring harness you can buy from Holley brand new
ECU you can buy Holley Auto-tuner brand new.
install; enter in modifications and drive away as it auto-tunes!
Billet LSD retrofit to E46&E39 NON-M
http://forum.e46fanatics.com/showthread.php?p=14989087
S54B32 E36 1997 M3 Sedan Street car swap + DTA S100:
http://forums.bimmerforums.com/forum....php?t=1437471
1987 E30 + 2006 e46 320D ZF 37DZ- 6 speed conversion
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 01-03-2013, 12:48 PM   #45
Elvin123
My Ride: 328i
sr20? really? good swap for an e30, wont be worth it in an e46 though
Elvin123 is offline   Reply With Quote
Old 01-03-2013, 05:40 PM   #46
BMW E465
My Ride: 1dirty5
Thanks mate.
Old 01-04-2013, 11:55 PM   #47
millerj69
My Ride: 04 M3 SMG
Give me a cammed lsx all day long! I would really love to see it.
millerj69 is offline   Reply With Quote
Old 01-20-2013, 11:07 PM   #48
E46inthe206
My Ride: 2003 BMW 330Ci
Wow it's been a while since I've been on here.. lol. So.. I have no plans for the BMW anymore. I'm trying to pay it off and sell it within the next few months.
I'll be purchasing an s2000, buying RPF1's, J's Racing exhaust, and some sort of suspension for it. Next year I'll be doing either a turbo or a SC.
I'll most likely go with a turbo, I want to push more power. ~450+whp off PTuning's turbo kit w/ fuel & engine management.
I would do it all before this summer, but I'd rather save up a little first. Hence why I'll be building the F20 motor next summer instead. Stock internals can hold 700 on those motors.. it just sucks that they have the compression that they do.. I want to run 15psi -__-
5-Speed 2003 330ci - Sport, Premium, Winter packages.
Name of Owner: David.
E46inthe206 is offline   Reply With Quote
Old 01-20-2013, 11:30 PM   #49
zaharias
My Ride: Now has a 3lt :P
Any more info on this..??
Is this their site http://www.holley.com/ ??
zaharias is offline   Reply With Quote
Old 01-21-2013, 03:57 PM   #50
wanganstyle
Holley is the famous muscle car aftermarket- ie 4 barrel holley carb etc
Its a great option for one who has no desire to breakdown a used unfamiliar american car wiring harness or mess with flash tuning and has a built up setup in mind
The hot setup now is:
Lq4 escalade iron small block
Gm new ls cylinder heads
Cam of your choice- tons avail
Bolt on edelebrook or fast lsx intake manifold
Headers custom to fit
Holley wiring and auto tune
Good for about 600 horsepower no turbo or blower invited
Sent from my GT-N7100 using Bimmer App
Old 01-24-2013, 04:42 PM   #51
M3 2 NV
My Ride: 2001 M3
Wouldn't the LQ9 be better since its a bit higher compression...and even better yet a LS6 block that is aluminum as opposed to cast iron to help in the weight department Iron block isn't needed unless you're putting a couple snails or giggle juice on it making huge power, IMHO.
Regarding the Holley auto tune stuff, i don't think it is as simple as build your motor plug it in and away you go. I've been dealing with LSX engines for 10 years. I have a LS1 & 700R4 in my TJ and a LS6 & T56 & 8.8 in my FD RX-7 and a LQ9 for . I use HP Tuners for both and got both of my harnesses from Howell Engine Developments, there are a lot of options out there for complete plug and play harnesses (which means you need to hook up 4 wires).
Love the LS series engines. Its pretty crazy when you yank a 38" tire 12" off the ground
2001 M3 - Phoenix Yellow - 03/01 production
M3 2 NV is online now   Reply With Quote
Old 01-25-2013, 01:14 AM   #52
wanganstyle
Holley auto tune you enter in your modifications and it does the rest: read up on it- its full can bus and increibly smart. Japan had a product like this in the 90's called apexi power fc: it was like a game boy and even had options for popular modifications all built in (4 different air intake options etc)
I grew up in Detroit and have been around american muscle as long as anyone else
The hot setup due to cost/avail at least here in nor cal is lq engine + whatever heads you like brand new and whatever cam you desire
My client here running holley auto tune also has a ls7 fd3s (900rwhp turbo). Another with ls7 e36m has a na 800rwhp lsx fd3s.
Id be guessing you will probably think pretty similar to him if you really look into the holley product - its that impressive. Cab bus full modern control in a box for you!
Old 01-27-2013, 02:41 AM   #53
02PRUV
My Ride: E46 M3 Turbo
Watch this space for a turboed 440ci alloy blocked LSX. Should be somewhere between 1400-2000hp depending on the size of the turbo/s that will be used.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 01-30-2013, 10:36 PM   #54
E46inthe206
^ ... dafuq O_o
Old 02-01-2013, 01:55 AM   #55
v8 5
My Ride: 6 speed BMW
okay sure
Gutted with a Getrag
v8 5 is offline   Reply With Quote
Old 02-16-2013, 10:21 AM   #56
02PRUV
Originally Posted by v8 5 View Post
okay sure
Yep sure. When I say I'm going to do something I do it.
This is what we are looking at now:
Sorry for the delay, been super busy. Anyway, I have a pretty good idea how to do this project as a 427. If we use an RHS block, I come up with a total of $19,700.00 from intake to oil pan, completely assembled. It would include the best of every component for the power level you are looking to do.
Lunati crankshaft 4.000 stroke
Oliver billet rods
Diamond custom pistons
Total Seal AP steel ring set
Comp hyd. roller cam / lifters / timing set
RHS Pro Elite CNC 12 deg. heads
Moroso oil pan / pickup
Cometic MLS head gaskets
FAST 102 intake manifold
Anyway, you can give me a ring to discuss other details etc.
Got the S54 removed yesterday, the LS engine and box in and the gearbox crossmember already made. Already worked out that single turbo on the left side of the engine bay is the go for me (I have steering on the right), J Pipe coming round the front of the engine and found a spot for a 4" dump pipe. So it's all going to work well.
Rides:
Old 02-21-2013, 10:41 AM   #57
E46inthe206
^ Looks sick man, definitely keep us posted!
I change my mind too often... still can't figure out which car to get. S2k is out of the question.
Debating between a 2j swap or an ls1 swap. Just stock motors for now.
I know they're both amazing motors, just depends on what you want.
I want the JZ but I've heard the LSx motors are more reliable and cheaper (cheaper to maintain too).
How much cheaper are they?
Eventually I'll want to see 450hp, then 550, then 650, etc.. step by step lol.
I think that'll be easier and less expensive in a JZ, no?
The rumble of the V8 is nasty (in a good way) but I'm still in love with the JZ's sound..
Also, I think the overall cost for the swap (including labor) will be more with the 2JZ, right?
At least that's what I've heard.
Thoughts?
