///M3 Forum
Old 12-24-2012, 07:15 PM   #1
Ballerbrian4u
My Ride: 2004 BMW m3
2004 smg
Hey guys I have a 2004 m3 with smg and for the past 100 miles the car shutters from a stop. The car just hit 45,000 miles. The problem only come when the car is warmed up and I have done the smg reset witch helps for a second but then it come back. Please help me fix this problem!
Ballerbrian4u is offline   Reply With Quote
Old 12-24-2012, 09:18 PM   #2
roadtrip1098
My Ride: 04 M3 SMG LSB
What setting are you in? Are you using sport mode?
roadtrip1098 is offline   Reply With Quote
Old 12-24-2012, 09:47 PM   #3
Ballerbrian4u
S4 and s5 no sport mode.
Old 12-24-2012, 09:55 PM   #4
Arock1092
My Ride: Bmw M3
You used "witch" out of context.lol
Arock1092 is offline   Reply With Quote
Old 12-25-2012, 01:18 AM   #5
Ballerbrian4u
Lol sorry
Old 12-25-2012, 04:28 PM   #6
roadtrip1098
How about TC? Also how are your tires, and conditions that you're driving in? As of right now, it sounds like a clutch relearn for the SMG at the very least and maybe you have some air in the hydraulics. Kinda tough to tell. You might want to have someone hook up a GT1 and see if there are any errors that may not have generated a CEL yet.
Old 12-26-2012, 03:19 AM   #7
Ballerbrian4u
Tc on! Tires brand new. Normal socal whether.
Old 12-26-2012, 04:55 AM   #8
roadtrip1098
Just for shits and giggles, try it with TC off and see if it's improved. I'm still thinking your going to need to get it plugged in and scanned though, possible have the adaptation run.
Old 12-27-2012, 06:47 AM   #9
steve bettencourt
My Ride: 2003 m3
try a transmission fluid change and a soft ware up date
steve bettencourt is offline   Reply With Quote
Old 12-27-2012, 08:41 AM   #10
devincox
My Ride: 2006 BMW M3 ZCP
I have noticed that mine will shudder from a stop if I'm applying very little throttle from a stop.
devincox is offline   Reply With Quote
Old 12-27-2012, 08:21 PM   #11
0asis2007
My Ride: 2004 BMW E46 M3 SMG
Pretty sure you this points to you needing to do an SMG clutch recalibration, using the diagnostic software (INPA, I think?). The only proviso is that it must be done when the car is cold.
0asis2007
2004 M3 SMG
TiAg/Black
0asis2007 is offline   Reply With Quote
Old 12-29-2012, 12:14 AM   #12
NICKBRUM
My Ride: 2004 M3
What he said, has been the best advice. Before you get there have you left the battery unplugged for a few hours? I have had the same problem come and go, but not enough for me to do more than a soft reset. Just in case that is 40 MPH, stick to "N", hold both paddles for 10 seconds.
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|
NICKBRUM is offline   Reply With Quote
Old 01-02-2013, 02:27 PM   #13
Ballerbrian4u
I have done the soft reset many time. It did not help.
Old 01-02-2013, 02:28 PM   #14
Ballerbrian4u
This only happens when the car is fully warmed up. When it's cold the car is perfect. Where can I get the clutch software?
Old 01-02-2013, 02:30 PM   #15
Ballerbrian4u
Do I go to the dealer to get the clutch recalibration software? How much dose it cost?
Old 01-02-2013, 02:39 PM   #16
Ballerbrian4u
Why dose it only happen when the car is hot?
Old 01-02-2013, 04:56 PM   #17
Myah
My Ride: CB ZCP
Hey BallerBrian,
Unfortunately I don't have good news for you, but I'll offer my opinion of what I think is happening. I have the same thing that developed in my car about 8 months ago. Mine is a 2006 SMG w similar miles as yours.
I would get the shutter in first gear only when "hot" or "warmed up"; and I always suspected hot spots on the clutch. It drove me insane...
The first time I took it in the techs blew me of telling me you have to "drive the car more carefully" and that it was just "touchy" - I was furious; but put up with it until it got worse only because I didn't want to go back to those clowns.
The second time I took it to a different dealership; I asked them to adjust the SMG properly (using a hard reset / adaptation that they can do with their software). He agreed to do this but on the test drive he agreed with me that it felt like the clutch was slipping / had hot spots- and the reset would likely not fix the shutter.
To shorten the story; the software reset (not just pulling the paddles back at 40mph ect) did nothing, and the tech agreed that it likely needs a clutch.
I have no idea what the standard clutch replacement interval is in these cars; but 40k seems a bit on the light side... either way; I'm going to get mine replaced in the next month as it has progressed from the problem that you are currently experiencing to an overall slipping under harder shifts which I KNOW is clutch slippage, unfortunately.
Anyways; I'm curious to see if a new clutch was the solution to this problem for any other members?
Best Regards,
Jeremy
Myah is offline   Reply With Quote
Old 01-02-2013, 05:16 PM   #18
Ballerbrian4u
Thanks for the explanation. I hope that when you change the clutch it will resolve the problem. Please let me know. Also how much dose it cost to get a new clutch? Can I get it resurfaced? Also is the clutch the only thing that needs to be replaced?
Old 01-02-2013, 05:43 PM   #19
voidopolis
My Ride: 2004 M3 SMG Vert
have you replaced the salmon relay yet? I'd do that as a first step before doing much else... is the dash SMG COG light on? is the car throwing any codes?
voidopolis is offline   Reply With Quote
Old 01-02-2013, 05:53 PM   #20
Ballerbrian4u
No lights on the dash. Took the car in for service 1 year ago and they said the previous owner had change the salmon relay. Should I Change it again? Where can I buy it from?
