Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
2001 BMW 325i e46 Suspension
So I have a 2001 BMW 325i with 140,000. No suspension work has ever been done to my knowledge. Im a daily driver (75-150 miles a day, territory sales rep). When I am driving straight it's fine but any bumps I hear a THUD and then it levels out. I imagine my struts are blown.
What do you recommend I get to have it comfortable ride, lowered maybe an inch, and handle slightly better then stock? I know that's a lot to ask, but if you don't ask you don't get an answer 100% of the time. Im looking at getting these: http://www.ebay.com/itm/251065288242...84.m1423.l2649
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return."
#2 |
I'm sure there are other bushings that need replacing, but the common, thuds due to bumps, noise is often attributed to FCABs(front control arm bushings). You should start there. Struts being blown shouldn't really cause a thud. You would just have a slightly more bouncy ride. Look for leakage around the strut to see if they are in fact truly blown.
#3 |
For a daily driven car, a good choice for a moderate drop and excellent ride / handling compromise would be either stock ZHP springs with Koni FSDs or Hotchkis springs and Koni FSDs. At your mileage you will need FCABs, RTABs, and very likely will also need front control arms. Might as well get it all taken care of while you're in there.
JV
John V
'03 330i ZHP 6sp street car '02 330Ci 5sp race car |
#4 |
For the amount of the Bilsteins you could consider a coilover kit. Here is a thread on the Street Edge Coilovers we offer http://forum.e46fanatics.com/showthread.php?t=932527
Here is the link to our website http://thesuspensionsource.mybigcomm...eries-e46-2wd/
Kristina "Kris" Ash
General Manager The Suspension Source 1-888-230-1288 kristina@thesuspensionsource.com www.thesuspensionsource.com Like us on Facebook for 10% off ![]() |
#5 |
I had the front control arm replaced about 15,000 miles ago, both sides. I hope that's not the problem again
The ride is DEF bouncy though, and yeah the rear struts are leaking everywhere. In regards to the the Street Edge Coilovers im wondering if those are better then the Bilsteins.
#6 | |
Kristina "Kris" Ash
#7 |
okay cool! Other ones i as thinking were... http://www.ebay.com/itm/380547930693...84.m1423.l2649
#8 |
With how much you drive your car, don't you want to put a quality product on it? There's no benefit to coilovers unless you plan to adjust the ride height. You can achieve your goals with higher quality components that will last for the life of your car (Koni shocks and OEM ZHP springs).
Just my $0.02.
John V
#9 | |
Are those Bilsteins any good? Koni seem good too, can I lower the car about an inch with either one of those?
#10 |
Bilsteins and Konis are both very high quality shocks with lifetime warranties. The FSDs will give you a better ride than the Bilsteins, the Bilsteins are arguably a little more "sporty" feeling as they have higher initial compression damping and are less digressive.
Both of those dampers will tolerate a moderate drop. I have the FSDs on my street-car 330 ZHP and it rides and handles better than it did with the factory dampers. I have very expensive coilovers on my race car, and while it's true you can get a budget set of coilovers for your street car, there is no advantage to doing so, while there are a few disadvantages. They are cheap for a reason.
John V
#11 | |
#12 |
In that case, you'd be very happy with the FSDs.
In my experience unless you're willing to buy some really high quality coilovers, they are more trouble than they're worth.
John V
#13 |
Modded ///Member
I just installed those Bilstein's on my 323i and I love them. I'll point out a few things about them:
*You can configure that combo cheaper elsewhere online. I paid $320 for the shocks/struts and another $160 for the associated mounts, gaskets, etc. In total it came out to $480. *The ride is a bit firmer than the stock suspension, but not incredibly so. My old suspension had 153k miles and it rode like crap. The car rides great now and going over bumps doesn't emit any noise in the cabin other than tire noise. *The handling is much improved. Cornering is more controlled and the body roll is much better than before. *According to the Bilstein website, the Touring suspension isn't designed for lowering springs. Installing lowering springs on the car will cause the struts to wear quicker and the warranty won't cover that. I have stock non-sport springs installed on mine and it's fine. It did raise the height of the car a few millimeters if that means anything to you. It doesn't bother me. Overall I'm very happy with the suspension and I would buy it again. However if I did want to go lower than I would buy the Koni's as they are designed for lowering springs from the get-go.
#14 | |
Super helpful, thanks a ton guys. I might try the FSD's. As I drive everyday and still have that inner drive to rip around the corner. I got my eye on an Audi S5 so we'll see
![]() Thanks guys! Im gonna try the FSD's, now another dumb question, will I have to or should I replace the springs? Quote:
#15 |
You do not need to replace the springs but if you want to lower the car then you will need springs.
The Bilstein shocks meant for use with lowering springs are their Sport model.
John V
