Old 01-02-2013, 01:12 AM   #1
thebema
My Ride: 2000 bmw 328i 5 spee
Missin vacuum line
Hello people
I show on the picture the spot with a screw driver; Is anybody can tell where the rubber vacuum line that connect to the silver line that running on the middle of the manifold coming from? Missing rubber line suppose coming from the back and what part in the back of the engine that vacuum hose suppose to connect to?
thebema is offline   Reply With Quote
Old 01-02-2013, 06:23 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you search my thread with 'intake manifold' in the title, you'll see a picture of the back of the manifold. Your other end of hose is behind the intake mani...remove cabin air filter and, if needed, the panel it screws into...an inspection mirror and flashlight should reveal where that hose end is.
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-02-2013, 06:24 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
No picture attached at this point?
Suggest you check the first link below in my signature.
I am guessing it may be a SAP line, but the picture or a better description would be helpful.
Old 01-02-2013, 06:31 AM   #4
dmax
dmax's Avatar
He's talking about the silver tube that runs down the fuel rail. I'm pretty sure it's a hard plastic line with a rubber elbow on it that he's looking for.
Mangofy your E46!
Old 01-02-2013, 09:59 AM   #5
jfoj
Old 01-02-2013, 01:21 PM   #6
dmax
dmax's Avatar
Okay...happened to be back there today...that silver pipe connects to a short section of rubber vac hose maybe 4" long...then into a hard vacuum pipe...a thin hard plastic pipe that's flexible...like that hard section of the sap valve outlet. Mine is black and I presume yours is too. It should be floating back there somewhere under cabin air filter housing.
GL...hth
Mangofy your E46!
Old 01-03-2013, 06:43 PM   #7
thebema
Missing vaum line
I'm showing on the picture the spot with a screw driver; Is anybody can tell where the rubber vacuum line that connect to the silver line that running on the middle of the manifold coming from? Missing rubber line suppose coming from the back and what part in the back of the engine that vacuum hose suppose to connect to?
Old 01-03-2013, 06:47 PM   #8
thebema
Old 01-03-2013, 06:58 PM   #9
thebema
Exclamation vacuum line
ID:	484492   Click image for larger version
ID:	484493   Click image for larger version
ID:	484494   Click image for larger version
Old 01-03-2013, 07:48 PM   #10
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It is very short length ( 2-3 inches) of rubber hose that makes a 90 degree bend and connects to a hard or metal hose. This hose is right next to the gas lines and is actually clipped to the gas line.
The end on the front of the fuel rail connects to the cvv.
Take a look behind the manifold and in front of the firewall.
BMWCaptain is offline   Reply With Quote
Old 01-04-2013, 12:42 AM   #11
thebema
send some pic so you can see better what i am talking about
Old 01-04-2013, 01:03 AM   #12
thebema
where is that short section of rubber vac hose maybe 4" long exactly comig from?
Can you show me a pic of that ?
ID:	484540   Click image for larger version
ID:	484541   Click image for larger version
ID:	484542   Click image for larger version
Old 01-04-2013, 06:28 AM   #13
dmax
dmax's Avatar
As I said above, the short section of vac line, on my car, connects to a 'hard plastic vac line' which should be visible underneath the cabin air filter housing...should be.
Mangofy your E46!
Old 01-04-2013, 11:42 PM   #14
thebema
Oh ok so you mean that the vacuum hose suppose to connect to the silver tube is coming from hard plastic located underneah the cabin air filter housing
Old 01-05-2013, 05:39 AM   #15
dmax
dmax's Avatar
Yes...silver tube--short rubber vac line--hard plastic vac line
Connected in that order. If you have the vac line, then you're looking for a hard plastic (mine is black) vac line...maybe 3/16" diameter. Mine comes up vertically from the fire wall...I don't know where the other end goes to, but believe it's part of fuel supply or preparation.
Mangofy your E46!
Old 01-05-2013, 06:15 AM   #16
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Since u have an m52tu, your fuel rail has two vacuum connectors
The one in front (toward bumper) conxnects to your CCV
The one in the rear (toward cabin) comnects to your fuel pressure regulator
The vacuum sys for m52tu and m54 r different
I hope this helps, good luck
Old 01-05-2013, 06:20 AM   #17
dmax
dmax's Avatar
Originally Posted by flashmeow View Post
Since u have an m52tu, your fuel rails have two vacuum connectors
The one in front (toward bumper) connects to your CCV
Well, meow, flash!
You sure you want to include all that private info in your sig? Just asking.
Mangofy your E46!
Old 01-05-2013, 06:27 AM   #18
flashmeow
Banned User
Well, meow, flash!
Meow to u too Dougy
I am a big girl n i think i can defend myself.
Old 01-05-2013, 09:29 AM   #19
dmax
dmax's Avatar
With a FN enhanced paveway II! That's not defending yourself...that's more than putting men in their place. Betty, that's total and utter annihilation, and honestly, I think it's quite a few steps up from proportional response.
Couldn't you just send some anti-radiation missile zooming over their heads as a shot across the bow? Play fair!
Mangofy your E46!
missing valve, vacuum line, where the going to
