Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 01-03-2013, 10:09 PM   #141
jwbeck17
My Ride: 2005 330xi
Originally Posted by eriksen76 View Post
I have tried to search and as you all might know, information is buried in the big threads :p so this might have been answered.. alot..
I seem to have a problem with my wifi (i got the d99+ with original wifi dongle) i can connect to all networks, but only the unsecured networks will work? i get no internet connection from secured once? but they are connected.. wich happen to be a major issue for me :S
I had a connectivity problem with secured networks, not an Internet problem, but my trick may be worth a try. I had to reset the password on my wifi hotspot and it seemed to work.
Also, of you get a connection but no Internet, you should check the source to make sure that it allows for Internet access on the IP that your Dynavin is using. Probably checked that, but it's worth asking.
Also turn the wifi off and on in Android
Unplug the dongle and plug it back in
Test the dongle on a laptop
Just throwing out some ideas to help!
jwbeck17 is offline   Reply With Quote
Old 01-04-2013, 04:52 AM   #142
klinwart
My Ride: Audi TT mk2 coupe
Originally Posted by jeffb325@DynavinSolutions View Post
Yes, all dynaivns do....but it doesnt really do anything on the WinCE unit.....its mostly there for loading software....
Hi Jeff thanks for the reply, but is the USB on GPS side suitable for using with Petruts 3g dongle?
klinwart is offline   Reply With Quote
Old 01-04-2013, 06:36 AM   #143
eriksen76
My Ride: BMW 318D 2004
Can i control the ip that my dynavin is using though?
I've tried the dongle on my computer, and it seem to work BUT, the speed is terrible compared to the built in wifi... look under :p
Dongle:
Built in wifi:
Any ideas? still cant get any respond from secured networks...
eriksen76 is offline   Reply With Quote
Old 01-04-2013, 08:24 AM   #144
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
yeah.....thats what I assumed you were up to. There is no reason to use it on a stock dynavin....
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 01-04-2013, 10:45 AM   #145
klinwart
Hi Jeff
I'm a liitle confused that you say 'no reason to use on a stock dynavin' but if I want the internet on WinCE do I need the USB on GPS side? Thanks
Old 01-04-2013, 10:59 AM   #146
J&T Distributing
My Ride: BMW
I just meant that the only reason to use the winCE USB is if you are going to hack it, which is what you are doing with petruts patch, to my knowledge, yes, petrut's stuff uses the GPS USB for wifi/modem/etc... You will want to direct your questions at him however, im not familiar with his patch beyond what I have seen in passing on the forums.
Old 01-04-2013, 11:07 AM   #147
klinwart
Thanks for your help Jeff, keep up the great work.
Cheers
Old 01-04-2013, 04:01 PM   #148
x13atma17x
x13atma17x's Avatar
My Ride: E46 323i & MK6 Jetta
Just wanted to share this....
GSP works on my D99+ Android after downloading about 1GB of maps on my 8GB SDHC card last night for off-line use. Today, left my phone at work during lunch, opened the Google Maps app, map started loading & few minutes later the GPS started working too. Of course no, Search & Navigation/Direction as those requires an HotSpot connection.
I'm loving this unit!
-omar-
x13atma17x is offline   Reply With Quote
Old 01-04-2013, 06:42 PM   #149
eriksen76
I'm going to use Sygic as my navigation it is amazing! but first i need internet connectivety on the unit... i cant do anything about it being secured, and my unit wont let me use secured ones! o.o
Old 01-04-2013, 07:17 PM   #150
sparky1969
My Ride: 330i m3
Hi Im interested in doing an upgrade on my 2001 330 i headunit
Im prewired but do not have bluetooth pairing button on car but have handsfree feature on steering wheel and stock microphone. Is it possible to do.upgrade myself to have navigation touchscreen ?
Sent from my SGH-T959V using Bimmer App
sparky1969 is offline   Reply With Quote
Old 01-05-2013, 04:57 PM   #151
eriksen76
I have a BIG issue, many apps on android side run in fullscreen, meaning i loose the top bar with the "back" and "settings" button or what i shall call them. So i get stuck in the apps! :O i cant find any way to close them, they rely on phones, wich have the "go back" buttons :S
EDIT: The unit is very unstable... wifi only work sometimes, android locks up alle the time and suddenly my music can stop because the unit start loading a cd that is not there? :'(
Old 01-07-2013, 05:50 AM   #152
tuffyak
My Ride: E39
So i finally installed my D99+ Win CE version in my 523i E39 and everything has been working as expected. I ran into two annoying issue today now. After I plugged in my I phone there is a black status bar that remains on the top of the screen (basically tells what is playing CD, IPOD, radio etc.) but it won't go away now and interferes with reading the screen. Also, and I don't know if this is related or not but happened about the same time, is that the GPS lost satellite reception and won't reacquire even though it had just been working fine in the same place. Nothing has changed with the GPS antenna position so I don't think that is the problem. Any advise?
tuffyak is offline   Reply With Quote
Old 01-07-2013, 07:45 AM   #153
tsawyer
My Ride: e53 x5 2004
I can help with the black status bar issue. Go into the Display settings and turn off the PIP. It is a bit misleading, but in this case, Picture in Picture is really a 'display overlay' option for whatever is putting out audio.
tsawyer is offline   Reply With Quote
Old 01-07-2013, 08:25 AM   #154
tuffyak
My Ride: E39
Thanks tsawyer! I just figured that out a few minutes ago myself ! I have been back tracking the different setting I was messing with but I still haven't gotten the GPS to work properly yet. Hopefully someone will have an idea what I did or can do to fix it!
Old 01-07-2013, 08:26 AM   #155
tuffyak
My Ride: E39
Is the RST (reset?) button on the front something I should try?
Old 01-07-2013, 10:29 AM   #156
sahiilseth
My Ride: BMW 325i
steering wheel controls
Hi I received a D99+ unit and everything works very well except the steering wheel controls. The factory setting sheet which came with it says we have to choose numbers between 00 to 04 for different models. What should be the correct number for E46?
Sahil
sahiilseth is offline   Reply With Quote
Old 01-07-2013, 10:29 AM   #157
sahiilseth
My Ride: BMW 325i
Hi I received a D99+ unit and everything works very well except the steering wheel controls. The factory setting sheet which came with it says we have to choose numbers between 00 to 04 for different models. What would be the correct number for E46?
Sahil
Old 01-07-2013, 10:38 AM   #158
eriksen76
Sahil
Mine is set to "00" and works like a charm :p
Anyone else having trouble with the touch screen? i can actually barely scroll down with it, always just click into programs on the screen, and sometimes when i finally manage to get it scrolling down, it suddenly just pops up
Any suggestions? i can upload a movie clip of it
Old 01-09-2013, 06:47 PM   #159
snownh2o2
My Ride: LT
SWC Steering Wheel Control - Number Setting in Hidden Menu
I was wondering if anyone knew where I could find info about the SWC setting. Searches have left me without any info. In the hidden settings menu, SWC can have 00-20 selected. Having the Universal D99+ and a Metra adapter to my vehicle, I am trying to get them to communicate. The Metra can be programmed for 1-11.
First thought was to just pick a number and set both to that number. No luck. Any ideas? Does the D99 SWC system follows the same as any of the other big name brands. The Metra manual shows the following:
1 Eclipse
2 Kenwood
3 Clarion "Type 1"
4 Sony and Dual
5 JVC
6 Pioneer and Jensen
7 Alpine*
8 Visteon
9 Valor
10 Clarion "Type 2"
11 METRA OE
Also note that Dynavin uses a 2-wire plus GND and Metra uses a 1-wire plus GND. Speaking to them directly they said this should not be an issue with the Dynavin unit.
Any suggestions would be greatly appreciated.
Thanks,
Matt
snownh2o2 is offline   Reply With Quote
Old 01-09-2013, 06:55 PM   #160
snownh2o2
My Ride: LT
Eriksen76,
I have the same issue with the scrolling popping back to the top of the menu. And I have yet to locate a fix. I spent a lot of time trying to figure out if I was pressing too hard or too soft or scrolling too fast or too slow. I concluded that is wasn't me. However, with that said, I have't yet tried it with the screen protector off. Are you also using a screen protector?
Matt
d99, d99+, dynavin, gps, navigation
