///M3 Forum
Old 01-06-2013, 03:34 AM   #1
ChiefM3
My Ride: 2005 M3 SMG
Question First improvements to M3???????
Hey guys, I am new to this forum and I am looking for some advice. I recently bought an E46 M3 SMG after selling my E36. I am wanting your guys imput on the first improvements/ Modifications that i should make to my new baby.I have a little bit of bread to spend but im not looking to buy everything under the sun. What was or would be the first thing you did to your M3? Thanks for the advice.
ChiefM3 is offline   Reply With Quote
Old 01-06-2013, 04:32 AM   #2
djantlive
My Ride: E46 M3
i would spend the money fixing any issues first. as for mod, i replaced the smg paddles with some alum ones that are bigger. i also stripped the peeling paint on the center console with paint thinner and goo off.
check your tires too. mine were worn due to negative camber in the back
djantlive is offline   Reply With Quote
Old 01-06-2013, 04:43 AM   #3
dinan19
My Ride: 2004 Imola ZHP
But negative camber is good. Haha
Sent from my SGH-T959V using Bimmer App
Old 01-06-2013, 05:35 AM   #4
Bmw0224
My Ride: 2003 BMW 325i
After maintenance, first modification I would do to my m3 would be maybe an exhaust intake or suspension maybe wheels
Bmw0224 is offline   Reply With Quote
Old 01-06-2013, 06:02 AM   #5
LSM3
My Ride: E46 ///M3
Angel eyes + matte black grills or carbon grills + Eiback Pro spring kit.
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
Old 01-06-2013, 08:14 AM   #6
KaliVertBoy
My Ride: M3 Vert 6MT
I say just cruise around stock for a while. Decide what you really want, and wait for it to pop up in the forums for cheap.
Interior Pioneer avic z2--brushed aluminum vinyled trim--wind deflecter
Exterior Csl front bumper--Gold CSL reps--Macht Schnell spacers 18mmf/10mmr--Ebay trunk spoiler
Performance Macht Schnell intake elbow--K&N drop in--Manzo Headers (still in box lol)-- TCKline/Ground Control Coilovers
Lighting OEM LED taillight retrofit w/ amber vinyl--Chris Brown mod--3500k H7's--6000k morimoto D2s's--6000k ccfl angel eyes--LED's everywhere
KaliVertBoy is offline   Reply With Quote
Old 01-06-2013, 08:58 AM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Mileage on car?
+1 on doing the maintenance and if you have cash, then invest it in preventive maintenance...get a new cooling system, or at least wp, therm, and ET. Get new control arm bushings, guibo, csb. Change all fluids...all of them. Pulleys, belts, filters, maybe plugs and coil boots.
If this car is new to you but used, you have to assume little was done, despite what the PO might have said (at least in most cases you need to assume this).
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-06-2013, 11:12 AM   #8
m3e46freak
My Ride: m Twee lol
I would suggest exhaust.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 01-06-2013, 11:39 AM   #9
rjskalet
My Ride: TiAg M3
Depending on mileage and where you live check and make sure the rear springs aren't broken. I just found out over Christmas that this is a problem among m3s from the north.
rjskalet is offline   Reply With Quote
Old 01-06-2013, 11:57 AM   #10
Snik
Snik's Avatar
My Ride: IR M3 Vert.
While M3 water pumps last longer. They still fail, seems most go over 100k miles before the bearings go out.
Here's the kicker. The E46 M3 water pump retails over $350. So. I would make sure u have one replaced if its still the original one. That and the expansion tank and thermostat and the fan clutch.
Smg, I sure hope it doesn't fail on you. But there was talk way back on one of these forums on a theory that E46 SMGs may be failing because they overheat? E60 SMGs or euro E36s don't fail half as often. One theory was maybe making some kind of air duct to the pump to keep it cool. Just. Though. but def upgrade the paddles. They look proper with bigger paddles.
Check your diff. Mine has a bad seal and leaks. Works fine still, but check.
Also don't be afraid to replace all them bushings. And M3 center bearings and thinks don't last as long. Neither do the clutches. Compared to non Ms and previous gen M3s.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 01-06-2013, 03:43 PM   #11
Alan
Alan's Avatar
My Ride: 2006 M3
Make sure maintenance is completely up to date before anything else.
1. Tires
2. Brakes
3. Suspension (if you need it)
Alan is offline   Reply With Quote
Old 01-06-2013, 04:29 PM   #12
d'ray18
My Ride: E90 335
I would get your stance right with wheels and susp/lower the car first
2008 E90 335i
d'ray18 is offline   Reply With Quote
Old 01-06-2013, 04:34 PM   #13
dinan19
^ This.
Old 01-06-2013, 04:50 PM   #14
Westrace
My Ride: 06 G35, 04 M3 Coupe
Second that. I would make sure all the major maintenance are up to to date -- water pump, cooling, transmission/diff fluid, steering fluid, fuel filter, spark plugs, RTAB ...
Then get a Mason rear strut tower bar to stiffen up the rear so you can add better either coilovers or lower springs as the stock chassis may flex under hard corner loads. I plan get get the Mason myself because my after market springs probably pushes the stock chassis more than I would like.
After that it's all up to you.
Westrace is offline   Reply With Quote
Old 01-06-2013, 06:36 PM   #15
CW23
My Ride: E46 M3
Do the maintenance first. Don't worry about the other things for a bit until you know your M3 is in top notch shape.
///M
CW23 is offline   Reply With Quote
Old 01-06-2013, 07:17 PM   #16
Snik
Snik's Avatar
Oh yeah. And if you want something to worry about besides smg and rear floor failure. Go read up on M3 forums about the vanos failure.
I will be selling a set if DPE wheels here soon tho. At a good price too.
Yes. That was a shameless plug.
Old 01-06-2013, 08:45 PM   #17
Active 2
My Ride: 02 E46 m3
Maintenance first. Make sure to check RTABs and subframe.
After all my maintenance was taken care of, I went ahead and put on AA exh, headers and a tune
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 01-06-2013, 08:48 PM   #18
Broach><330
My Ride: 330CI -E30 325 (S52)
Maintenance first for sure! Coilovers, exhaust.
High-line catback
Kosei K1's
Headers
3.15 Differential
Koni FSD, eibach sports
AA software
205k (9/16/13)
E30 S52B32 100,xxx
5spd ZF, JB LW fly, Megan Coils, OBD1 conv. Mishimoto with low temp stat, TRM 15x8, Black vinyl sport seats, MOMO mod 08, 2:93 LSD, Custom single 2.5" exhaust, SS headers, M3 rack, basically new everything on driveline.
Broach><330 is offline   Reply With Quote
Old 01-06-2013, 11:37 PM   #19
nofar
My Ride: 2006 M3 ZCP 6 SPEED
Do all the maintenance first. Then drive it stock for at least 6 months before you do anything/modifications. Honestly, these cars are really really great stock from the factory. You should really learn to drive this car well and see all it's nuances before modifying it immediately. Honestly, the more and more I have my M3, the less and less I want to modify it; I just want to enjoy it as much as possible as it is because the BMW engineers did a great job with it.
2006 M3 ZCP. Interlagos Blue on Dove Grey. 6 speed manual.
Eibach Pro-Kit / Koni externally adjustable F&R shocks / DDM Aluminum Pedals / BMW Performance Short Shift Kit / Clutch Delay Valve (CDV) removed / Painted reflectors / Stealth bulbs / Turner 15mm/10mm front/rear spacers.
nofar is offline   Reply With Quote
Old 01-07-2013, 05:17 AM   #20
ChiefM3
When i purchased the car, I had a full maintenance done at Mercedes Benz.(I know but have a connection and purchased the car there). The car was a weekend driver from an older gentleman and has 27k MI. Their is zero maintenance issues and all fluids were replaced. Tires are good. Its amazing how well this guy maintained his car. As a bimmer enthusiast, I can respect the love someone has for their car but it seems like this car was never driven out of the driveway. I have some time before i will be able to drive it due to me waiting for the vehicle to ship from my home to my military duty station. I plan on driving stock for a short period of time but wanted to see everybody's input when i do decide to do certain modifications. Thank you everybody for the input, I am getting alot of good advice.
Oh you drive a mustang??? Thats cool....
improvements, m3, modifications
