Old 01-06-2013, 05:08 PM   #1
kdr24
My Ride: 325ci
Help!!
Hey guys need your help on figuring out what's wrong with my car. While driving, the gauge lights went off and the windows stopped working too. After 2 days it started working but today all of a sudden it went off again. Bad thing windows are down now. The mechanic told me it might be the alarm system since he checked all the fuse and wires already. Is it possible that it's the alarm system? Thanks in advance!
kdr24 is offline   Reply With Quote
Old 01-06-2013, 05:12 PM   #2
jfoj
My Ride: 330CiC, M5, X5
Disconnect the battery for 30 minutes.
See the 3rd link in my signature to bring up the Hidden OBC Menu and display the battery Voltage on the OBC.
You should have at least 12.3-12.4 Volts displayed on the dash with engine off.
With engine running you should have 13.5-.14.3 Volts displayed.
Old 01-06-2013, 05:33 PM   #3
kdr24
My Ride: 325ci
Sorry i'm a newbie. I don't get it. So i just need to disconnect the battery for 30 minutes? I don't know how to operate the OBC...
Old 01-06-2013, 05:36 PM   #4
kdr24
My Ride: 325ci
I just had the fuel pump replaced. Does it have anything to do with it? The window constantly going down everytime i open the door. Thanks
Old 01-06-2013, 06:10 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Search cluster test...solidjake has a youtube video of how to do it...that'll give you your voltage of the car when off and on.
Give the battery disconnect a try...but first, see if the cables on it are tight or not...shop might have disconnected them and forgot to tighten them up...who knows?
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-06-2013, 07:04 PM   #6
My Ride: 2016 Lexus
Basically what we are saying is that you just might need a new battery. if your battery is 5years +, you just might need a new one. what kind of battery do you have? take a picture and show us.
Old 01-06-2013, 07:32 PM   #7
jfoj
I assume you do not have a Voltmeter?
If not, you need to see the 3rd link below in my signature. You will not see my signature if you are using a smart phone or tablet.
Old 01-06-2013, 08:25 PM   #8
kdr24
My Ride: 325ci
I tried to check it, it says 120 when off and 140 when engine is on. Car's alarming every 30 minutes so removed one of the wires on the battery. Thanks again guys!
Old 01-06-2013, 08:41 PM   #9
jfoj
120 = 12.0 Volts with the engine off means your battery is low and/or bad. This means your battery is only about 25% charged. Either it is low or likely has a bad cell.
You need to get your battery charged and tested, however, if it over 4 years old, time to likely replace it!
Low batteries in these cars makes them go crazy.
Probably time to buy a battery.
DL49 is what many claim fit most everything except convertibles or M3.
Old 01-06-2013, 09:32 PM   #10
My325XI
My Ride: 03 325XI Sprt Prem
Battery, voltage regulator, and altenator will be your main culprits.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-06-2013, 11:23 PM   #11
kdr24
My Ride: 325ci
Ok i'll do that tomorrow... Appreciate all your help!
Old 01-06-2013, 11:25 PM   #12
kdr24
My Ride: 325ci
Hope it's just the battery. Thanks anyway
Old 01-07-2013, 02:09 AM   #13
dmax
dmax's Avatar
Check the connections. You said the lights went off when you were driving...and since your alt is putting out 14V, I don't think it's the battery.
I think maybe just your cable connections might be loose...cable, or ground...and I wish I could see a connection besides that with them doing the FP...but I'm not seeing it. Pull up on the cable connections to the battery to make sure they're tight. Simplest explanation is that they disconnected the battery when doing FP and didn't tighten it back on.
We'll see.
Mangofy your E46!
Old 01-08-2013, 11:53 PM   #14
kdr24
My Ride: 325ci
I changed the battery yesterday and everything worked fine until tonight the car alarm went on and off. Then I tried to check the gauge light it's off again. I checked the battery voltage from OBC it says 125 (off). I don't know what's going on with this car now...
