///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#21 |
I got a alinement t some cheap tire shop for 40 dollars. And I think this problem started after that. I think. Could that be the problem??
#22 | ||||
The SMG soft reset won't really help the "shudder from standstill" problem. Yours is a clutch-related issue, not an SMG gearbox-related issue as such.
But a clutch recalibration is something best left to someone who has some knowledge of what they're doing with the software. If you're new to it, there's a risk of messing things up..... Quote:
Not sure why this is, but someone else may know? Quote:
It is a clutch calibration issue! Hope this helps!
0asis2007
2004 M3 SMG TiAg/Black |
#23 | |
0asis2007
#24 |
Repost
#25 |
You guys are really helpful and all this info is really appreciated!!!!! I really dont like doing anything my self so where can I get my clutch recalibrated ? Indi shop? Also should I update my smg software?
#26 |
Maybe it's no sport mode.
Wholesale Ralph Lauren Women Polo from Online Store; Discount Electronics; China Wholesale
; Discount Polo Ralph Lauren Tees |
#27 |
Where an I get my clutch recalibrated? Will that solve my problem? How much dose it cost around?
#28 |
Are you refering on smg calibration?
#29 |
Yes
#30 |
No, not quite.
I thought SMG calibration was something different to clutch calibration (biting point reset?)
0asis2007
#31 |
So do I need a clutch calibration or a smg calibation?
#32 |
Please help me guys!!!!
#33 |
Clutch.
Someone local to you must be able to help? Either try a good BMW specialist, or someone who knows how to use the diagnostic software. And it's best done when the car is cold.
0asis2007
#34 |
Will this clutch calibration solve my problem 100%? Around How much dose it cost ? Thanks for the help!!!
#35 |
My Ride: 2 pedals - 2 paddles
Ok if you own a SMG M3, you should always have at least 1 spare salmon relay in the car at all times. you can get the relay at any BMW dealership, but I would check around and get it at the lowest price (including shipping & tax).
Now to address your issue. Will a clutch adaptation learn-in fix your problem. Yes, if your problem is clutch engagement. Maybe or no if there are other issues. A SMG clutch should last in excess of 100k miles under normal usage. (now anything man made can fail at any given point in it's life span) Check your regional forum section for someone with a INPA/DIS/GT1 computer that is willing to do a clutch learn-in. You're going to need a heavy-duty battery charger also. The cost will be based on the hourly rate of whomever is performing the work. A fanatic might charge you $60 and a dealership might charge you $250 ( all prices are guesses as I don't know what the person performing the work's hourly rate is and how long they perceive the work to take.)
In order to finish FIRST, you MUST first FINISH !
Joy is future proof Get your "M" on . . . Reading is FundaM3ntal ![]() CAR: 2003 TIAG Coupe / Blk Interior / SMG / HK Premium MODS: EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB BMWCCA NCC Last edited by turbo_f22_pilot; 01-06-2013 at 11:04 PM. |
#36 |
Hey, first post ever, thought I'd give my 2 cents.
I drive a 2005 M3 SMG and I've been having this same shuddering problem. But mine has ~72000 and it shudders when it's both hot and cold. I took it to my mechanic (we are very good friends) and he said it needs a new clutch, but I can wait a little longer before changing it. He said it will cost about $1500. Not the greatest news, but I trust him. This could possibly be the same issue for you. |
#37 |
Usually a new clutch isn't needed. The clutch needs to be re-learned (adaptations). Sometimes it's the slave cylinder. Very seldom is it a damaged / worn out clutch until you're closer to 100k. But failure has happened before 100k.
Also, if he replaces the clutch, the relearn process has to be run after installation to ensure proper inital engagement.
Joy is future proof Get your "M" on . . . Reading is FundaM3ntal ![]() CAR: 2003 TIAG Coupe / Blk Interior / SMG / HK Premium MODS: EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB BMWCCA NCC |
#38 | |
#39 |
Sorry guys should I ask for a smg adaptation or a smg teach-in?
#40 |
Ask for smg clutch teach in. this will let the computer know when the clutch is engaged. same as when you would drive a manual and feathering the clutch. The teach in will let the smg know how far the clutch is until full engagement. Where as the manual you can feel it and start pressing the accelerater
