Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 89 votes, 5.00 average.
Old 01-06-2013, 01:36 PM   #2381
Serbonze
Master of his domain.
My Ride: My wife
Originally Posted by HiHoBrian View Post
I have a long and short regular. I really just want two shorts.
sent from my ATARI sc1224
Send back the long, he'll send you the short.
Serbonze is offline   Reply With Quote
Old 01-06-2013, 11:09 PM   #2382
david05111
My Ride: drei hundert dreißig
Tried using the Daniel Defense build your rifle thing at midnight. Barely moved along...that's how many people are signing on to try and get an order in.
Anyway, its cool but it sucks. You can't build an NFA weapon...everything is either 14.5 or 16 inch. I wanted to build a modified MK18, but they wouldn't allow me to select the right barrel length.
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
Follow me on Instagram: yippee_ki_dave
david05111 is offline   Reply With Quote
Old 01-06-2013, 11:50 PM   #2383
Rush4theYehO
My Ride: XI fts(now)
Website hardly even works for me when I tried it....can't imagine how many people are on it! Was going to build a "filthy 14". Although in practice that should be a BCM.
Rush4theYehO is offline   Reply With Quote
Old 01-07-2013, 10:08 AM   #2384
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Anyone know what would be involved to take my DDM4V2 and turn it into the short barrel mk18? Or is that just nonsense idea?
Timeless Motor Group
Old 01-07-2013, 10:23 AM   #2385
Serbonze
My Ride: My wife
Check local laws to ensure that you can own an SBR.
Create an NFA Trust or Corporation or send out paperwork to CLEO, get fingerprinted, have him sign off on the Form 1.
Send out lower reciever for engraving.
Send out Form 1 to ATF with a check for $200, wait seven months for it to come back approved.
Send out barrel to be cut down.
Purchase a new handguard (I don't recall what length yours is now, I think it's too long for a 10.3" barrel) and gas tube.
Purchase new buffer/spring combination if you don't get a Switchblock or some other adjustable gas block.
Mount upper/lower.
Enjoy SBR.
Old 01-07-2013, 10:27 AM   #2386
2000_328CI
2000_328CI's Avatar
hahahah screeeewww that. Not worth it
One other question. Can I remove the sights on my DD V2 altogether and just run a red dot scope?
BTW, my cabelas pmags shipped today at 16 bucks a pop
Old 01-07-2013, 10:33 AM   #2387
Serbonze
My Ride: My wife
You can, but people will laugh and question why you are not running back up sights.
They will then specifically ask "what happens when the battery runs out or the red dot breaks".
Then Tailo will post a picture of a dude that has a hole in his Aimpoint with the caption "this is why you learn to use irons first".
That's all just a guess though.
Old 01-07-2013, 10:35 AM   #2388
2000_328CI
2000_328CI's Avatar
Haha.. gotcha. So iron sights with the red dot in line like was suggested earlier.. The one thing I don't really get though is the advatnage gained by having a red dot in line iwth irons.. at that point, why not just use the irons? I'm sure this is uber noob question
Or, even better... get the troy armories folding sights, use those instead of the fixed sights on my dd, and then run an aimpoint.. total win right?
Old 01-07-2013, 10:38 AM   #2389
david05111
Chase, your irons are integrated. They're not just simply attached to the rail, or at least the front isn't. Could you remove them? Yes. Is it a pain in the ass? Yes. If you get the correct mount for a red dot, it should line up nicely with the front sight anyway.
Did you pick it up yet?
Old 01-07-2013, 10:44 AM   #2390
2000_328CI
2000_328CI's Avatar
Nope... I'm waiting for a call from the shop but it should be this week for sure
Just want to make sure I have it all ready to go. Can't wait to head to my buddy's farm and shoot milk jugs, cans, and other stuff
Old 01-07-2013, 10:53 AM   #2391
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
The 10.3" and 10.5" barrel lengths used on the Mk18s are the most problematic and finicky setups of any DI AR configuration. If they're built right, they will run fine. The problem is that the gas port diameter must match the barrel length. The last thing you want to be doing is chopping down a barrel to get a Mk18 setup, because it will cause problems.
Don't chop the barrel down. Instead, pick up a specific Mk18 barrel and Mk18 rail like the 9.5" Mk18 RIS II.
You can, but it's not recommended. If they are bothering you, swap them out with a set of folding sights.
If you are running an EOTech, keep the BUIS on the rifle. EOTechs have poor battery life and I've seen several go down on the range. Running without BUIS on a red dot is not recommended, but with a sight with a longer battery life, like an Aimpoint or a Trijicon SRS, you can get away with it.
If you're just going to the range for a little bit, it doesn't really matter so long as you bring extra batteries. Just bring the sights so that you have something to use if the optic takes a dump.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 01-07-2013, 10:56 AM   #2392
2000_328CI
2000_328CI's Avatar
Gun ban.. won't accomplish anything because kids will just build bombs instead http://forum.e46fanatics.com/showthread.php?t=964329
Old 01-07-2013, 01:55 PM   #2393
2000_328CI
2000_328CI's Avatar
So guys, you think Delta3 tactical will ever ship out the orders we placed weeks ago? I just got notification that my 5 non-window pmags shipped from Cabelas and am considering putting them up on GB hoping to make 225-300 on the 5 pack of them.
Old 01-07-2013, 02:26 PM   #2394
HiHoBrian
My Ride: 05 M3
I don't think they actually will,but I hope they might. Haha. JJ said he talked to him and made him feel good but I'm not convinced he even has any to sell or a date he would expect them.
HiHoBrian is offline   Reply With Quote
Old 01-07-2013, 02:32 PM   #2395
Reedo302
Reedo302's Avatar
Delta3 isn't a Magpul featured retailer, so they're likely not going to be high up on the list for distribution. Just a thought.
Glock Armorer
Old 01-07-2013, 02:41 PM   #2396
2000_328CI
2000_328CI's Avatar
What to do... take the 200 profit or keep them in the event the ban passes... argh
Old 01-07-2013, 02:50 PM   #2397
king kong
My Ride: mid-engine
sell me one at normal price
king kong is offline   Reply With Quote
Old 01-07-2013, 02:55 PM   #2398
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
I'm going to give him a call
JonJon is offline   Reply With Quote
Old 01-07-2013, 02:56 PM   #2399
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Sell me some for cheap....
You have more than one ban you gotta worry about dodging
Old 01-07-2013, 03:11 PM   #2400
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
I got disowned by guys on this thread for selling my lower at a $250 profit...
Sooo get ready for that, but I say fvck it, profit off of this. I also have 10 pmags coming in soon from cabelas and will for sure be selling them at the highest price possible...
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is offline   Reply With Quote
Rate This Thread
