Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now! |
#1 |
Nest: Learning Thermostat
Just picked one if these up. I haven't installed it yet, we are closing on our new house end of this month so I'm just going to wait. Any one have one of these?
http://www.nest.com Combine that with the Phillips HUE lighting system and you've got basic home automation at 1/25th the cost! |
#2 |
It is an attractive thermostat, but what does it do that any other programmable thermostat does not do ?
"The grand essentials to happiness in this life are something to do, someone to love, and something to hope for."....Joseph Addison
#3 | |
Either way it is gorgeous! Hal 9000 ?!?! -Keegan Last edited by KeeganB; 01-08-2013 at 08:41 AM. |
#4 | |
I saw the video but I didn't get that much from it. Interesting.
#5 |
I like several things about it:
-The looks and build quality of it. Very cool looking for a thermostat -The "learning" capability so that it basically programs itself once it understands how you routinely adjust the thermostat, though I admittedly don't touch mine a whole lot. Things I wouldn't use: -Smartphone interface to adjust the temperature....I would never use this, though I know the capability will give some people a stiffy
![]() ** Removed ** |
#6 |
Does it have apps?
If it can SIRI your voice commands & respond with voice confirmations, plus integrate with other major home appliances - water heater, dishwasher, home alarm etc. That would be something. |
#7 | |
the SIRI integration would have to be via an API that Apple would have to allow the NEST developers to use. The stuff you are asking about with the other appliances is called Home Automation, and no, this thermostat is only a thermostat. True home automation runs in the $10k and up range usually. |
#8 |
Just taking a jab at Nest.. However, since it does have Wifi.. All you need really is a Raspberry Pi board $57 and compile your own code to control Nest or any other home appliances, in this case garage door opener via SIRI. ![]()
