Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Old 11-08-2012, 08:00 AM   #341
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Nov.16 weekend Got some Exciting stuff going on!
Old 11-08-2012, 09:44 AM   #342
Viral@ActiveAutowerke
Viral@ActiveAutowerke's Avatar
My Ride: E82 135i N54
Details
Viral Vahia
Active Autowerke | 9940 SW 168 Terrace Miami, Florida 33157
www.activeautowerke.com | viral@activeautowerke.com
Phone: 305.233.9300 Ext. 232 | Fax: 305-253-8921
Viral@ActiveAutowerke is offline   Reply With Quote
Old 11-19-2012, 06:44 PM   #343
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Big night
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 11-19-2012, 07:03 PM   #344
JohnBlaze
My Ride: Black Sunshine
I demand an update!
s54door
JohnBlaze is offline   Reply With Quote
Old 11-20-2012, 07:10 AM   #345
aggieE46
Keep it clean
aggieE46's Avatar
Update. I'm tired.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 11-20-2012, 07:40 AM   #346
JohnBlaze
Hopefully no news is good news!
s54door
Old 11-20-2012, 06:46 PM   #347
TrippinBimmer
I'm tired. I update when I get home to MS tomorrow...
Old 11-20-2012, 08:31 PM   #348
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Safe driving man!
Old 11-21-2012, 12:33 AM   #349
TrippinBimmer
I leave it to this...
Safe driving man!
Thanks Adam!
Old 11-26-2012, 01:39 PM   #350
JohnBlaze
needz moar info
s54door
Old 11-26-2012, 01:54 PM   #351
TrippinBimmer
Originally Posted by vI6ious View Post
needz moar info
Installed ESS FI Cams on the car, Vanos Seals, New Valve Cover Gasket and the 3" Exhaust. I also need to install my newly used M3 Fuel Pump with Baffle with the new Fuel Filter.
-Anthony
Old 11-26-2012, 02:35 PM   #352
JohnBlaze
sweet, good to use the baffle too
s54door
Old 11-26-2012, 04:21 PM   #353
jamex
My Ride: 2005 325Ci
hah. i've been following along and thought that last pic meant "back to the drawing board" after a unsuccessful test drive.
jamex is offline   Reply With Quote
Old 11-29-2012, 02:32 PM   #354
TrippinBimmer
WOOT 85% of my fuel issues has been resolved! My Fuel Pump and Baffle need to get here ASAP!
Exhaust why you so LOUD?
Old 11-29-2012, 06:22 PM   #355
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Ack! My ears!
They are ringing from here.....
Edit: Now that you can tip into the throttle, I bet it's starting to feel a bit like the M6?
Old 11-29-2012, 07:03 PM   #356
TrippinBimmer
Ack! My ears!
Not yet! Have to do some tranny maintenance and VB mod. (Feel mushy)
Old 12-17-2012, 09:07 PM   #357
Steven747
My Ride: 05 330ci
-Anthony
think i missed it if you talked about how you times your exhaust cam sprocket..?
do you think shrick 264's would be a bad idea even if i got a tune for it? prob wouldent make as much power with the exhaust being only 248 but maybe you can elaborate on why bigger exhaust for f/i is better? i would think more intake would be just as good or better to fuel the fire...
btw thanks for showing me silicone intakes
Old 12-27-2012, 10:54 AM   #358
wshgrntd
My Ride: 2001 330i
I am looking to do this in the very near future.... did you use the dinan auto tranny software?
wshgrntd is offline   Reply With Quote
Old 01-08-2013, 03:41 PM   #359
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Good news for you trip:
The GS20-TCU is nearly decoded ... I don't know how long it needs to get the right adjustments for TCC on 1. 2. 3. 4. and 5. gear, but i think this will be able ...
How much boost you're using now? Whats your WOT-AFR at Redline?
Hageee is offline   Reply With Quote
Old 01-08-2013, 04:04 PM   #360
TrippinBimmer
Updates!
I decided to solder the wires that I extended on the MAF Harness. Using 62/36/2 Rosin-Core Solder and some Rosin Soldering Flux. I have yet have time to reset my adaptation but WHAO! Car just woke up. Putting a big smile on my Face. Now sure its just side-effect from working on the car but I'm happy so far. I will reset Adaption tomorrow and drive it some tomorrow to see does it still act up.
PM sent
