Is a sway bar upgrade the best bang for buck upgrade to suspension? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 01-08-2013, 09:53 PM   #21
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Originally Posted by zhp43867 View Post
Is this a joke? Wheel lift can be a sign of too much sway bar. The Hotchkis increased my last ZHPs wheel lifting tendencies.
What suspension are you running?
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-08-2013, 10:21 PM   #22
serdar255
My Ride: '01 325ci / '90 325i
Which one? Doesn't Bavauto sell several? And you should either buy upgraded endlinks or fresh Lemfoerder endlinks with bigger sways.
Do you have aftermarket sways?
I had Hotchkis, wouldn't do it again. They certainly give the car a more buttoned down feel, but they don't improve grip as much as you initially feel like they do. Also the endlinks wouldn't stay tight until I double nutted them with red loctite.
I have a 25/20 setup now from the Z4 M-Sport front/E46 convertible/Xi rear, all OEM parts, and it's a nice upgrade and I have no complaints.
Hotchkis bars are hollow- so 30mm isn't what you think it is. For the most part I do agree though.
Turner Motorsport, they certainly increased grip and reduced under steer.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 01-08-2013, 10:25 PM   #23
KrasivataSabine
My Ride: 323Ci
Stiffer sway bars do NOT increase grip. They actually increase weight transfer to the outside wheels which reduces max grip.
Their benefits are 1) reducing body motion for better repsonsiveness/communication from the chassis (this is an important characteristic for me so I went with the Hotchkis set) and 2) adjustable sways can help drivers dial in over/understeer by controlling weight transfer on each axle. Stiffer bars=more weight transfer=less grip on axle in question.
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 01-09-2013, 02:21 PM   #24
Grande D
My Ride: E36 M3
First ZHP: Koni Yellows, Eibach Pro Kit springs, Hotchkis sway bars & endlinks front + rear, and Powerflex RTABs.
This one: PF RTABs, Koni Yellows, stock springs & 25mm front/20mm rear BMW (but not stock) sway bars.
This one is faster than the old one. There could be a number of reasons but ultimate grip really is not determined by the sways.
Other variables are no sunroof on this one, and different tires.
It will change your life!
Old 01-09-2013, 05:15 PM   #25
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
How do you feel about the power flex rtabs? I really like ride comfort so I'd never upgrade engine mounts to poly or solid but I would always welcome more handling response
Old 01-11-2013, 06:50 AM   #26
Grande D
My Ride: E36 M3
Powerflex RTABs have a minimal increase in harshness. It would be imperceptible if you hadn't driven a car for a week- lets put it that way. I originally went with the OE/limiter setup, but for the RTABs Powerflex is a solid choice (pun intended). Everything else I stick to rubber. I'm a stickler for NVH.
Old 01-12-2013, 07:18 AM   #27
Thaniel
My Ride: 06 E90, 01 330
If the struts ans shocks are good I'd go with bars next. But get matched set. As mentioned one stiff bar and one soft will unbalance the car. If the struts and shocks are old start there.
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
