Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 01-05-2013, 04:27 PM   #21
vandyboy
My Ride: 2001 325i
I have the same whistling issue - only happens at cold start-up. I am replacing all the intake rubber and the vacuum hoses on that side. I also have a chirp that is a tensioner - took my mechanic friend's advice and we are going to replace all of the tensioners, belts and pulleys at once.
I do not have any other symptoms of CCV other than a blown VCG. No undue vacuum/suction from oil ports. People on here have told me to go ahead and replace the CCV because that can cause whistling.
vandyboy is offline   Reply With Quote
Old 01-05-2013, 04:28 PM   #22
jtshawtek
My Ride: 2001 330i
here is a link to what i am experiencing :
i was thinking of doing the same. replacing the boots on the intake side was a waste of money for me as the existing one was in okay shape. but for $20, whatever.
but for the rest, i think i am going to follow your same path. my car is old enough to where i think it is worth doing everything now anyways.
i am curious, are you getting the same noises?
jtshawtek is offline   Reply With Quote
Old 01-05-2013, 06:41 PM   #23
tech4tech
My Ride: 2004 325i
It sounds like a bad idler and/or tensioner pulley to me
tech4tech is offline   Reply With Quote
Old 01-06-2013, 10:35 PM   #24
jtshawtek
My Ride: 2001 330i
never. easy diy?
Old 01-06-2013, 10:54 PM   #25
jtshawtek
My Ride: 2001 330i
Thanks man, I just found a great DIY here:
So you had a loud whistle like this one and is was just the water pump? Cool.
Old 01-07-2013, 10:03 AM   #26
dano17
My Ride: 2000 328i
I have a similar problem to all of this. I replaced the intake boots (which werent ripped) and I Still have this whistle. If I hold the rpm's around the 2500 range I can really hear the whistle, but my car doesnt warm up so it doesnt go away. I believe my T-stat is bad... and I dont know if my water pump has been replaced. But when I had someone hold the rpm's around 2500, it sounded more like a pulley problem.. Anyone have problems with their pulleys?
P.s. Im still relatively new to bmw's
dano17 is offline   Reply With Quote
Old 01-07-2013, 11:56 AM   #27
trizzuth
My Ride: 234k, 16yr old B3AST
yikes, that is f'n horrible! definitely not the same noise as the intake boot whistle.
I've heard some people say that you can remove your belts and start the car briefly, when cold, but do NOT leave it running for risk of overheating and that way none of the pullies are involved, so if the sound goes away, it has to be your water pump, PS pump, alternator pulley, idler pulleys, etc. If you've ever removed a belt, this should be a quick, easy way to narrow it down
trizzuth is offline   Reply With Quote
Old 01-07-2013, 11:54 PM   #28
jtshawtek
My Ride: 2001 330i
Cool, thanks for that tip. I ordered the fan tool and should get it any day now. I will do what you suggest. It gets cold anyways here. So my AM start with no belts will not be an issue. The noise is immediate so I will not need to run the engine for more than 10 seconds. GREAT TIP. Thank you.
Old 01-08-2013, 04:33 PM   #29
dano17
My Ride: 2000 328i
How in the hell do you get tension off the belt with the hydraulic belt tensioner? Every DIY I found has dead pics
Old 01-08-2013, 11:53 PM   #30
xjbmx
My Ride: 325i/Cheerokee
Ok so new guy here, and granted I don't have a BM yet, so don't flame.
But, my Jeeps all have the same whistle when cold and being started. I know its a totally different animal And probably isn't made like this at all on a BM but, the way the IAC is in the TB caused it to whistle until the module moved once warmed up.
Like I said, this is probably wayyy of but just a bit of theory.
'92 Jeep Cherokee
'97 Jeep Cherokee
xjbmx is offline   Reply With Quote
Old 01-09-2013, 11:30 AM   #31
crapshooter
My Ride: 03 330i, 3 e24's,
faint whistle noise
Hey guys, I'm a rookie e46 owner, just bought a nice black/black '03 330i with 63k on the clock....super tight and clean! Car has a couple of minor things I'll need to take care of, such as the windshield cowl cracking - she also has a faint whistling or whining noise coming from somewhere under the hood, I was thinking at first it was characteristic of the 3.0, but now I'm not so sure after reading this thread. I'll pay attention to some of your replies and see if I can track down this noise.
Looks like I've found the right place for answers! Thanks.
Bob G
crapshooter is offline   Reply With Quote
Old 01-09-2013, 11:50 AM   #32
FastHackem
My Ride: E60 M5
Originally Posted by jtshawtek View Post
I uploaded a video to YouTube of what the noise is from a COLD start. Car has been sitting for over 12 hours.
Thanks in advance for ANY feedback...
That sounds like a pulley to me.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-09-2013, 12:57 PM   #33
wildirish317
My Ride: 2004 325Ci vert
See this.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-09-2013, 03:08 PM   #34
MJLavelle
My Ride: 2001 BMW 330ci
I totally am hearing the noise from there! And I DID put in an aftermarket alternator! Holy Crap! I am going to check it in the AM and listen closer to that area...I really did not enjoy that job I may be doing my alternator again....I totally tried to go cheap and get a rebuilt alternator....I am so sorry to my fellow fanatics, I deserve what I am getting for trying to go cheap....I think I saw a quote on here once that went something like "If you can't afford to maintain a BMW, then don't own one..." ....now I understand what that jerk meant...
The people who rebuild alternators use cheap Chinese bearings, rather than the F.A.G. or other high quality bearings that are in the original alternator. They are notorious for failing early, and making horrible noises.
I have an old alternator that I took apart to see how hard it is to rebuild, for a post I was going to write up. I got stuck trying to find a quality brand bearing to replace the ones that are in there. I can find plenty of Chinese made ones, but that defeats the purpose. I found one supplier of F.A.G. Bearings in the size needed, but there was a minimum order of 1000 units. Since I don't want to get into the alternator rebuilding business, I gave up. It is a shame too, because it is relatively easy to get these alternators apart, and if you do it before the bearing completely fails, the shafts are really durable, and seem to be in good shape.
Old 01-10-2013, 08:34 PM   #35
trizzuth
Any update?
Old 01-12-2013, 10:03 PM   #36
dano17
My Ride: 2000 328i
Originally Posted by wildirish317 View Post
See this.
That's a manual tensioner. I has hydraulic.
Old 01-12-2013, 10:15 PM   #37
bratliff
My Ride: 330i
Put the hex socket into the center of the tensioner pulley and turn it clockwise. Use a long ratchet so you have some leverage.
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 01-18-2013, 10:38 AM   #38
ecfrankyboy
My Ride: 325ci 2005
Same problem here, with my 325, at cold starts, usually when the temperature is under -3 Celsius. I'd be curious if there's a easy way to fix this!
It's a bit weird to drive a whistling BMW...
ecfrankyboy is offline   Reply With Quote
Old 07-27-2014, 11:10 AM   #39
HotRod72
My Ride: 2002 325Ci Conv
I realize that no one has posted in this thread for over a year but, I have the exact same problem as the video and I want a definitive answer on what the actual problem is and what was done to repair it. I am a new BMW owner and so far in the 3 short months that I have had this car it has some issues that need to be addressed. This one however just started a couple of days ago and it is really annoying. Could someone that has had this exact sound and repaired it to where it no longer makes this sound please tell me what they did to repair it? I do not want to just start throwing parts at the car. Thank you for your help in advance.
HotRod72 is offline   Reply With Quote
Old 10-11-2014, 08:37 AM   #40
Canadian_325i
My Ride: Soon - 2001 325i
Same noise here...
Sorry for bringing up an old thread, any chance anyone has found a solution?
Mine just started with this noise in the cold and I too don't want to just throw parts at it.
Canadian_325i is offline   Reply With Quote
