DIY Thermostat Replacement WITHOUT DRAINING The Coolant! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-09-2013, 04:32 AM   #1
KH0
My Ride: 323i
Cool DIY Thermostat Replacement WITHOUT DRAINING The Coolant!
Hello All,
I am in the process of doing a Thermostat Replacement on my 2000-2001 BMW 323i Manual.
I was just wondering if I would encounter any issues if I were to do the Thermostat Replacement Without Draining The Coolant as the temperature outside is below freezing and I don't want to go through all the trouble.
How much Coolant would it actually spill upon opening the Thermostat and the Hoses?
I would also appreciate any tips / tricks / pointers.
Thank You.
KH0 is offline   Reply With Quote
Old 01-09-2013, 05:02 AM   #2
TurnersInOz
My Ride: 2004 325i
T-stat and hoses?
Between the bottom hose and t-stat you'll be draining pretty much all of it any way you look at it.
TurnersInOz is offline   Reply With Quote
Old 01-09-2013, 05:06 AM   #3
mkodama
mkodama's Avatar
If it's just the thermostat and not the hoses, you'll probably only lose a quart of coolant.
Sponsored Links
Advertisement
Old 01-09-2013, 05:15 AM   #4
KH0
My Ride: 323i
Hello,
But don't I need to remove the hoses to get the Thermostat out?
Thank You.
Old 01-09-2013, 05:15 AM   #5
KH0
My Ride: 323i
Few people here did it without Draining...
http://forum.e46fanatics.com/showthread.php?t=219433
Old 01-09-2013, 05:17 AM   #6
mkodama
mkodama's Avatar
Originally Posted by KH0 View Post
Hello,
Thank You.
No, just disconnect the ends of the hoses connected to the thermostat.
Old 01-09-2013, 05:24 AM   #7
KH0
My Ride: 323i
Hello,
Yes, that's what I ment
THANK YOU.
Old 01-09-2013, 10:10 PM   #8
KH0
My Ride: 323i
Very disappointed to find Partially Shorted 10mm Bolts on the bottom.
Halted the process of replacement and the car.
Any Advice?
Thank You.
Old 01-09-2013, 11:23 PM   #9
mkodama
mkodama's Avatar
No clue what you just said or what that picture is of.
Old 01-09-2013, 11:26 PM   #10
KH0
My Ride: 323i
LOL
Picture of Bolts that has no thread
Old 01-10-2013, 02:32 PM   #11
dino71
My Ride: 2003 BMW 330i
Do not use crappy cell phones to take pictures, use a big boy camera.
dino71 is offline   Reply With Quote
Old 01-14-2013, 07:57 PM   #12
KH0
My Ride: 323i
Finally Done
A simple straightforward work that turned into some unexpected issues especially when working below freezing temperatures.
Majority of the unexpected issues will arise when taking apart the old Thermostat.
2 Bolts at the bottom (Rusted, Seized, & Striped)
At first decided to do the work without removing the Electric Fan as I mentioned earlier as the temperature outside was below freezing and I don't want to go through all the trouble, but finally decided to remove it as it was getting harder and harder to disconnect the bottom hose from the Thermostat. I also had a minor issue while removing the fan http://forum.e46fanatics.com/showthr...280&highlight=
When the old Thermostat was out everything went real smoothly.
BTW: You can do it without draining the coolant as it only spills out a handful, but a safe practice would be to washing off the area of the spill before starting the vehicle.
Thank You.
Old 01-14-2013, 08:39 PM   #13
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Please consult with Mango for all of your cooling question. he is the forum's subject matter expert and should be able to help you more effectively
I hope this helps. Good luck
Old 01-14-2013, 11:02 PM   #14
tcphoto
My Ride: E92 335 MT Coupe
I did this project a week ago and not removing the fan and shroud would make it nearly impossible. There is only a few inches between the components and you certainly don't want to damage the fan.
tcphoto is offline   Reply With Quote
Old 01-24-2013, 04:06 PM   #15
KH0
My Ride: 323i
Not Impossible, But Hard LOL
