General Off-Topic
Everything not about BMWs. Posts must be "primetime" safe and in good taste. You must be logged in to see sub-forums. Click here to browse all new posts. |
#1 |
Ever Had Cold Start Issue?
My car is a 2005 545I
I know this is off topic but hopefully I can get help from u guys. My car has a cold start issue. It doesn't start under 50 degree weather. It cranks but won't turn over. Anything over 50 degrees it starts and drives normal. No cel. It currently has no codes but had codes when I first scanned it. I've changed battery, spark plugs, cam shaft sensor, and IVM module. We've checked fuel pressure etc.. Any help?
#2 |
crank position sensor
#3 |
#4 |
Cold start sensor - my 02 325i just had the same problem.
#5 |
Dude. Google. C'mon now. Having said that:
http://www.bimmerfest.com/forums/sho...d.php?t=579724 http://www.bimmerfest.com/forums/showthread.php?t=83757 Crankshaft sensor(s) or software. |
#6 |
mine starts right up even at below freezing. maybe try leaving the key in the on position for a few secs to get the fuel pump running, then start
#7 |
The fuel pump only needs to prime for a second or so to provide adequate fuel for ignition, no?
#8 |
Fuel filter would be my guess, it's an 05...
Gutted with a Getrag
