Old 01-09-2013, 04:33 PM   #1
yonny325xi
My Ride: 325 XI
Question upper radiator hose problem
hello everyone, so i am replacing my upper radiator hose and upon putting it back in it will not go back in no matter what i do. I have all the clips up and it goes in just fine on the side for the engine. I have no idea whats wrong and it's driving me nuts. any ideas???
yonny325xi is offline   Reply With Quote
Old 01-09-2013, 04:36 PM   #2
TurnersInOz
My Ride: 2004 325i
Did you lubricate the o-rings with coolant first?
TurnersInOz is offline   Reply With Quote
Old 01-09-2013, 04:38 PM   #3
yonny325xi
My Ride: 325 XI
i did everything as they told me to do but it will not slide on. I just think its weird that the side for the engine slides in fine but not the radiator side
Old 01-09-2013, 04:38 PM   #4
WDE46
My Ride: '13 128i, '04 330Ci
Did you lube it up a bit? Also, what brand is the hose?
Old 01-09-2013, 04:40 PM   #5
yonny325xi
My Ride: 325 XI
I did lube it up a little but the plastic will not go on to the radiator no matter what i do. and I got the one from the dealership
Old 01-09-2013, 04:40 PM   #6
TurnersInOz
My Ride: 2004 325i
Post a pic, too.
Old 01-09-2013, 04:42 PM   #7
WDE46
And the oring is seated evenly inside? You cleaned off the radiator part?
Old 01-09-2013, 04:47 PM   #8
yonny325xi
My Ride: 325 XI
yeah the oring seems fine and i cleaned off the surface as much as I could
Old 01-09-2013, 04:58 PM   #9
yonny325xi
My Ride: 325 XI
[attach]Click image for larger version
Old 01-09-2013, 04:59 PM   #10
yonny325xi
My Ride: 325 XI
theres the pictures
Old 01-09-2013, 05:26 PM   #11
TT330i
My Ride: 2003 330i
Just clean the expansion tank side well and keep working it. Make sure both ports are lined up well, maybe try attaching the the expansion tank side first before the engine side. There is no secret you're missing or anything.
TT330i is offline   Reply With Quote
Old 01-09-2013, 05:29 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I vaguely remember the same problem and don't know if the solution is any more than persistence. Also, check the orientation of ET and radiator...and then, finally, what I might have done is moved backwards and started with that fitting...then did the end on the therm...again with lube...I used coolant.
Also, for some reason I'm thinking that you put them on with the clips down until they click...I believe it's made for an easy on, but then the clips hold them. Don't force it if I'm wrong...I'm old...someone will remember.
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 01-09-2013, 05:29 PM   #13
BimmersGarage
My Ride: E46 330i
First, you DO NOT need to have the clips pulled up.. Leave them in their respective grooves, they will "click to lock" when you push/mount the couplings to their appropriate depths.
Is the expansion tank "new"?
BimmersGarage is offline   Reply With Quote
Old 01-09-2013, 05:48 PM   #14
yonny325xi
My Ride: 325 XI
expansion tank is not new the radiator part just will not go in. I lubed it and still nothing
Old 01-09-2013, 06:04 PM   #15
tcphoto
My Ride: E92 335 MT Coupe
I did my cooling system refresh on Monday and both radiator connections refused to fully seat. I had to just walk away for a moment, clean up the engine compartment and come back to the hoses. I swear that I put coolant on all the surfaces maybe half a dozen times. They eventually clicked and are solid now. Take a little time and wipe down all the pieces and get it cleaned up, you want it clean so to confirm that the connections are good.
tcphoto is offline   Reply With Quote
Old 01-09-2013, 06:22 PM   #16
taibinhvuong
My Ride: E46 99' 328i
First, try with the old hose again to see it can fit it easily, if it does, then look at inside of the old hose fitting to see any sign of sanding or enlarging, it could be that your radiator was an after market item that it wouldn't fit the old hose and someone just sanded the old hose to make it fitted.
Other thing you can try is temporary removed the O-ring inside the new hose to see it can fit into the radiator neck, if it does fit with no problem, then you may have an incorrect radiator hose O-ring (it could happen even it's a dealer item).
If it doesn't fit with the O-ring removed, then you probably had the after market radiator with a slightly thicker diameter, indeed if this's the case then you can use a sand paper slightly and carefully sand around the radiator neck until it fits, remember to sand it a little by little and don't over sand it then lube with coolant for both radiator and hose before trying the fitting.
Note: try to do the fitting with just the radiator and without the expansion tank by turning the hose 90 degree upward.
Edit: the stuff described above applied to the hose fitting to the ET as well.
Last edited by taibinhvuong; 01-09-2013 at 07:35 PM. Reason: Edit: The stuff aboveEdit: the stuff above applied to the fitting of the ET as well if the broiler is at the ET fitting.
taibinhvuong is offline   Reply With Quote
Old 01-09-2013, 07:34 PM   #17
BimmersGarage
My Ride: E46 330i
I would NOT advise you take out the O-ring(s) from the New upper rad. hose.
Also, couplers are notched to ONLY fit one way, so if you were to turn it 90 degrees it will not go on.
Old 01-09-2013, 07:40 PM   #18
taibinhvuong
Thank you for pointing out, you could be right about this, I have not paid attention to this and will check it out when I have chance, and I'm meaning try the fitting without the clip, does it fit without the clip?
Old 01-09-2013, 07:47 PM   #19
dmax
dmax's Avatar
OP...check the make of radiator and ET if you can...I really don't think you ought to be sanding down the radiator neck as I'd be concerned that you wouldn't get a good seal afterwards.
Usually with things like this, you'd figure it out 5 mins. after you give up.
Mangofy your E46!
Old 01-09-2013, 08:06 PM   #20
taibinhvuong
If OP found out that indeed it's the slightly thickness of the radiator neck of the aftermarket radiator, what will be your advice to him in this situation? putting in a new radiator?
If you sand the neck carefully little by little with fine sand paper, it won't be problem if you have a decent skill.
connector, hose, problem, radiator, upper
