///M3 Forum
Old 01-16-2012, 11:23 AM   #1
R3LL
My Ride: E46 M3
Fluctuating temperature gauge?
Recently my temperature gauge began to fluctuate between the half way mark and 1/4. I changed the thermostat and it's still doing the same thing staying half way between the two and sometimes rising up to half, is this normal or anything else I could be missing?
2001 Jet Black M3 l Comp Wheels | KW V2 | RE RTAB l Headers l CSL Trunk l
R3LL is offline   Reply With Quote
Old 01-16-2012, 11:36 AM   #2
Verooom
My Ride: 2005 M3 Cabrio
I had the same issue. Took it to the dealer and had a sticky thermostat. Replaced it now it is fine. Sometimes it does go below half a bit but I think that should be normal. Reaching 1/4 is a bit too much IMO.
2005 Carbon Black M3 Convertible
2005 Mercedes-Benz SL55 AMG (SOLD)
2007 Ferrari F430 F1
2012 Nissan GT-R Black Edition
Verooom is offline   Reply With Quote
Old 01-16-2012, 02:13 PM   #3
R3LL
My Ride: E46 M3
ID:	432642 the temp stays like this most of the time
Old 01-16-2012, 02:23 PM   #4
Verooom
Originally Posted by R3LL View Post
Attachment 432642 the temp stays like this most of the time
I had that same problem but mine was a bit more to the left. A new thermostat did the job for me. I am not sure what else is causing it in your case. Have you taken it to the dealer?
Is your oil gauge doing the same thing or is it smack in the middle?
Old 01-16-2012, 03:30 PM   #5
BWOODM3
My Ride: 2002 M3 convertible
Looks normal to me...
Did you do the thermostat job yourself?
BWOODM3 is offline   Reply With Quote
Old 01-16-2012, 04:33 PM   #6
Verooom
Any one of you fellow M3 owners oil gauge stay in the center all times or does it like to dance back and forth?
Old 01-16-2012, 05:57 PM   #7
R3LL
My Ride: E46 M3
yeah did it myself, my friend is a BMW tech he said its normal but just wanted to make sure
Old 01-16-2012, 10:46 PM   #8
BWOODM3
I think my thermostat sticks at times. I was thinking about doing the work myself. How difficult was it? Did you end up replacing anything else?
Sent from my PC36100 using Bimmer
Old 01-16-2012, 10:49 PM   #9
R3LL
My Ride: E46 M3
It's pretty easy my first time doing it and took me about 30 mins, only thing is the space is tight so it gets fustrating. Only parts i changed were the thermostat and the two o rings
Old 01-17-2012, 12:36 AM   #10
Vox Populi
My Ride: 2001 BMW M3
sounds like your oil level sensor needs to be replaced. Very straight forward and you can do it the next time you're in there doing an oil change.
Vox Populi is offline   Reply With Quote
Old 01-10-2013, 10:37 AM   #11
jakemuscan
My Ride: E46
temperature gauge below 1/2
Hi folks, I've owned more than 10 bmw cars so far and the temperature gauge always stays on 1/2 or the 12 o'clock position after 10-15 minutes of driving (it can fluctuate slightly below the 1/2 mark a tiny bit which is normal but not down to the 1/4 mark). Just purchased another 2004 E46 yesterday and the temperature gauge stays on the 1/4 mark on the highway and may go up to the 1/2 point when sitting in traffic. I suspect the thermostat or air in the radiator ? Any thoughts ?
-thanks for your help
jakemuscan is offline   Reply With Quote
Old 01-10-2013, 12:05 PM   #12
///M Powerd
My Ride: 2003.5 M3 Coupe
Mine does the same. I heard its normal.
///M Powerd is offline   Reply With Quote
