Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Canada > BC, AB, Saskatchewan, Manitoba
Find other members from your area in the enthusist directory.
AB BC Saskatchewan Manitoba
Old 01-09-2013, 06:19 PM   #1
Euro604
My Ride: 2002 330Ci
Best BMW shop in the Lower mainland?
Hey guys, I do some of my own maintenance, but theres some stuff I dont have the patience to try and figure out.
What shops in BC does everyone reccomend to take their BMWs too which wont kill your wallet and do quality work?
2002 330ci, Scwartz Black, AFE Intake, Muffler Delete, 18" CSL Replicas
Euro604 is offline   Reply With Quote
Old 01-10-2013, 02:13 AM   #2
Fidget
My Ride: BMW
Im a big fan of CG in Richmond. Good quality and prices.
Chris knows his stuff and the quality as I said is top of the line. They are my go to shop.
Fidget is offline   Reply With Quote
Old 01-10-2013, 12:06 PM   #3
///M Powerd
My Ride: 2003.5 M3 Coupe
I go to Nixon, they have treated me well. Always willing to take you into the shop and show you what is going on. Pretty busy though, it can take a while to get an appointment.
///M Powerd is offline   Reply With Quote
Old 01-10-2013, 02:03 PM   #4
taylor192
My Ride: 2003.5 M3
The PO of my car used Nixon and gave them a lot of praise for actually diagnosing problems rather than throwing parts/money at them.
What are you trying to fix? I find this car very easy to work on.
Old 01-10-2013, 02:55 PM   #5
white46
My Ride: e46 323ci
What kind of work are you looking to get done?
white46 is offline   Reply With Quote
Old 01-10-2013, 07:08 PM   #6
Euro604
My Ride: 2002 330Ci
My front brakes need to be done, my vanos oil line is leaking and soon enough Im gonna need my cooling system done
Old 01-10-2013, 08:54 PM   #7
Hockeyguy02
My Ride: E46 m3
i would recommend Nixon as well. Very good experiences
CarbonBlackCinnamon
30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners
Hockeyguy02 is offline   Reply With Quote
Old 01-11-2013, 12:40 AM   #8
taylor192
My Ride: 2003.5 M3
Brakes are the biggest rip off in the automotive industry. Order the parts for 1/2 the price from the US and DYI. Super easy to do, no special tools required. Also measure your rotors, often they only need to be replaced every second set of pads.
Cooling system doesn't need to be replaced till it fails, unless you like throwing away money. Only exception is the water pump, replace it as soon as it starts making noise.
Sent from my Nexus 7 using Bimmer App
Old 01-11-2013, 06:21 PM   #9
BeFresh
My Ride: 2004 M3
sorry to hijack this thread, but what do you guys think is reasonable to replace the flex disk assembly (guibo) and the center support bearing? Apparently that is the cause of my rear end clunking (whew, not subframe)...
BeFresh is offline   Reply With Quote
Old 01-11-2013, 10:04 PM   #10
Euro604
My Ride: 2002 330Ci
Every single person on this forum says to replace the cooling system before it fails so you avoid damage to your engine.
And I am ordering the parts from the states. I have a very good discount at lordco and they quoted me 400 dollars for front rotors, pads and a wear sensor.
Old 01-12-2013, 01:28 PM   #11
taylor192
My Ride: 2003.5 M3
That's false. Search. There's lots of great advice from those with 200K+ still on the stock cooling system. It's your money, spend it however you want, just don't spread lies.
You might want to contact Nixon and CG before ordering parts. Most of the better shops won't install customer supplied parts. I ran into this headache with my Mercedes and my GF's Volvo. For brakes you can go to any shop. Budget Brake and Muffler on Marine will definitely install customer supplied parts for a rate less than the BMW shops.
Old 01-12-2013, 01:34 PM   #12
taylor192
My Ride: 2003.5 M3
I'd say 2-3 hrs shop time plus parts, so probably $500+. To do this the exhaust and drive shaft have to be dropped, which should be easy with a lift and air tools.
Old 01-12-2013, 06:28 PM   #13
BeFresh
My Ride: 2004 M3
BJ BMW wanted $2,008.73
Nixon quoted my $705+tax so i'm taking it there...
Old 01-16-2013, 08:39 AM   #14
drbworld
My Ride: BMW E46 Coupe
honestly, Nixon's is a rip off. that's all i'm going to say about them.
break it down and you'll see it doesn't add up to 705.
buy the parts and take it to any of the hundreds of shops around.
I can get you OEM flex disc for $80 local. either febi or lemforders. no crappy beck arnley parts from lordco. its more expensive than online in the states, but you don't have to pay shipping charges or a run to the border. that's just how it is in Canada. parts are just more expensive up north.
and about 1 hours depending on the shop at $80/hr. looking around before going to that indy. its not something you need a BMW specialist for. its 6 bolts and depending on how good the guy is, you might not need the exhaust dropped.
drbworld is offline   Reply With Quote
Old 01-16-2013, 11:19 AM   #15
taylor192
My Ride: 2003.5 M3
To be fair he did ask about the guibo and CSB. The guibo is easy, I'd DIY, yet the CSB requires dropping the exhaust and driveshaft which is a PITA without a lift.
You are correct in that this is a repair any shop can do. The only gotcha is marking the driveshaft before splitting it, which hopefully most shops would know to do.
Old 01-16-2013, 06:39 PM   #16
drbworld
If in doubt, print out a good DIY with pictures and give it to the shop guys to look over. Any mechanic who's been to school should knows to mark it. It would cost much extra either way.
Old 04-18-2013, 06:21 PM   #17
valenti
My Ride: Rated M
buy everything online, do it at home.
If you need to take it to a shop, I highly recommend The Speed Syndicate in Burnaby. I get all my work done there.
http://www.thespeedsyndicate.com
Ask for Alex, say M3 Leslie sent you =D
valenti is offline   Reply With Quote
Old 04-27-2013, 02:44 PM   #18
ohyesyoucan
My Ride: 2003 m3
ya i wanna know a good place too. I took my car to Nixon for a transmission problem. Hooked the car up to read codes $200. yes you heard right. Get a call you need need a new tranmission they say its a bent fork. $8000 (new) Not beleiving them with all the reading about the problem on here took to bimmertek in langley hooked up computer for free just i thought gear postioning sensor. $1000 later good to go. So NEVER take your car to nixon scammers Plus they did my tranny oil and put atf in a mt
And anybody at Nixon read this get back to me look to get my money back you ripped off from me i have my receipt still bent fork in an smg tranny inpossable
ohyesyoucan is offline   Reply With Quote
