Sponsored by The Tire Rack
Old 01-10-2013, 11:21 AM   #1
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Style 130 Wheel on 325i?
Hey guys,
I found a really good set of style 130's, for an amazing price (Yeah the X5 wheel) and, I want to know, if it will fit on a bone stock 325i. and If it won't, what would I need to make it fit? Thanks guys
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 01-10-2013, 02:57 PM   #2
trj
My Ride: 325Ci
Yes, they should fit.
You might want to run some spacers 10~15mm to get to the right offset of e46. The wheels on e46s are generally at 40mm offset. The wheels you are considering, if I am not mistaken has 48mm offset.
So to widen the stance a little more and to reduce the gap between the outer fender well and wheel 15mm spacers would be perfect.
So, to sum up; You can use the wheel without spacers and right tires: 225 45 17. However to make it look right(or better) you will need to run spacers with extended lugs.
