Old 01-10-2013, 03:24 PM   #1
HallisterJ1
My Ride: 2001 325i, 2003 M3
Turn car off, turn it on, extreme shaking.
I have no check engine lights.
Example: You're driving pretty hard through the city but not racing, you stop and park at Vons to grab a drink, it takes about 5min. You get back in the car, start it up and you slowly leave and the car starts shaking like it's going to blow up internally, but if I give it gas it will generally go away. This problem has never stalled or stopped my car, it's just given extreme discomfort and worry on what's wrong in my engine.
For some reason my car likes going down hills, when it goes up a hill it will start doing this shaking thing if I give it too much gas.
Quick Parts History (5< miles)
FCAB's
Fuel Pump/Fuel Filter
Cooling System Overhaul (E46 Mango'd)
OFHG, VCG
Air Filter
ICV Cleaned, TB Cleaned
Spark Plugs/Boots
Slotted/Drilled Centric Rotors/Brakes
Both Pre-o2 Sensors
All Air Boots Replaced
I have an engine mount/tranmission mount/rear differential bushing waiting to be installed.
Any thoughts would be SO helpful.
HallisterJ1 is offline   Reply With Quote
Old 01-10-2013, 03:30 PM   #2
lsteg
My Ride: 2001 330ci
Sounds like motor mounts to me.
lsteg is offline   Reply With Quote
Old 01-10-2013, 03:35 PM   #3
HallisterJ1
If that's the case, that is the best thing I've ever heard considering I'm just waiting to slap that on. Any other thoughts?
Old 01-10-2013, 03:42 PM   #4
My Ride: Lexus
Highly doubt it's the engine mounts. worn mounts will just make the drivetrain sloppy. sounds like your car is just idling low or misfiring. that means you have vacuum leaks/ICV malfunction or other running problems.
Old 01-10-2013, 03:52 PM   #5
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
should clean/check maf sensor, double check coils, and scan for codes even though there is no CEL.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 01-10-2013, 03:55 PM   #6
HallisterJ1
No misfires, had that checked along with cylinder tests. I was scared I blew my head gaskets months ago. I'll check the leaks, and check the ICV.
Old 01-10-2013, 03:55 PM   #7
lsteg
My Ride: 2001 330ci
FCAB's
OFHG, VCG
Air Filter
Spark Plugs/Boots
Both Pre-o2 Sensors
missed that part.
Old 01-10-2013, 03:56 PM   #8
HallisterJ1
MAF has been cleaned so much, it's the first thing I clean when I rip my air box off. Coils though...I'll check that out tonight.
Old 01-10-2013, 04:03 PM   #9
GATORSHOES2
My Ride: 2002 BMW 325i
I'm going to +1 the misfires.
It did it once before for me, then again last week.
Car starts up fine, start it up again and it starts shaking horribly.
I misfired on 3 cylinders.
Although for me it's only been when it's cold.
GATORSHOES2 is offline   Reply With Quote
Old 01-10-2013, 04:09 PM   #10
My Ride: Lexus
Misfires won't always show as a CEL especially if it's only the first time it's happened. How long has this been going on OP?
Old 01-10-2013, 04:35 PM   #11
Andy2108
My Ride: SpecE46 & E46 M3
cam position sensor?
Old 01-10-2013, 05:27 PM   #12
MachRc
E46Fanatic
MachRc's Avatar
^^ thats a likely culprit also, when my cps went bad, I had hard time keeping the engine from stalling. I distinctly remember reving while the revs dropped stalled the car.
Old 01-10-2013, 05:57 PM   #13
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
How much gas do you have in your car? Sending units go bad...and if you're not filling the tank up, you could be short when gas drops below half and the sending unit needs to deliver gas to right side of tank with pump? Maybe?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-10-2013, 05:59 PM   #14
Andy2108
Or low fuel pressure. pump going bad.
Old 01-10-2013, 07:04 PM   #15
dmax
dmax's Avatar
He did the fuel pump and filter...so I was thinking about fuel delivery from left to right lobe...the sending unit fails too. But, unless it can fail 'soft' or unless OP never fills up his tank, that wouldn't explain his symptoms if they've been persistent for a while...and it sounds like they have been.
OP...as mentioned, scan for codes. The car will have something recorded about what you've been experiencing.
Oh, and the other thing is that if any of this work you did was prior to these symptoms, and you got them shortly thereafter, consider an issue with aftermarket parts, especially electronic things. You didn't happen to do something else prior that you don't think is in any way related, and thus didn't mention it, did you?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-10-2013, 07:23 PM   #16
BMWespresso
My Ride: 2005 325CI
Vanos may stay on the wrong mode, not sure how you could check for this
For sure not the motor mounts
BMWespresso is offline   Reply With Quote
Old 01-10-2013, 08:22 PM   #17
HallisterJ1
The picture with more codes was taken 10/11/12, and the one with less and after TB, ICV, DISA cleanings was taken last month, 12/15/12.
I always fill my car up, never letting it get to less then 1/4. I've never seafoamed or done fuel injection cleaner, maybe I should?
Name:	Screen Shot 2012-10-05 at 11.50.07 PM.jpg
ID:	485525   Click image for larger version
Name:	Screen Shot 2012-12-12 at 8.43.32 PM.png
Old 01-10-2013, 08:28 PM   #18
HallisterJ1
Mentioned everything, well not exactly...everything's been kept OEM on this car, except Lemforder for FCAB (Shop Recommended)
Angel Eyes 81-LED
Carbon Fiber Emblems
My battery is old though, I'll be replacing it in a bit.
Old 01-10-2013, 08:30 PM   #19
dmax
dmax's Avatar
Have you looked at our exhaust flap? I don't have one, but I hear they rust closed...and there's some famous mod with a golf tee that I haven't heard about in a while...probably for a good reason! But, have 3 of 4 02 sensors with signal to ground problem seems odd...I wonder if it's because half your exhaust is closed...and maybe doesn't open up?
Worth a peak up them.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-10-2013, 08:33 PM   #20
dmax
dmax's Avatar
Angel Eyes 81-LED
...and if it's not the exhaust flap, then I'm betting on battery.
Say you have a known low battery...drive it a bit to the store. Start it up...taking the last little bit of reserve the car has...and maybe your battery is low because the alt is delivering weaker voltage.
Do a cluster test (#9) for voltage both off and on. Check bat connections, grounds...
See me in June!
dmax on Facebook
Mangofy your E46!
