Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Old 03-11-2012, 02:58 PM   #1
tommytoyz
My Ride: 1999 e46 323i
Head Gasket Replacement Shortcut DIY
I recently replaced my head gasket on my 323i 1999. But it is leaking again. I think the mistake I did was to scratch some of the new gasket material on the new gasket - the black stuff that goes around the piston hole cut out - and installed it anyway.
Car has not overheated - not even a little. But I know I have water being blown out and some oik in the coolant and a gunky oil cap.
Here's my question:
I know how to replace the head gasket the long way. But having done it once before, I realized there may be a much faster way to do this job and I want to know if anyone has done it like I am about to decribe:
1. Remove the hood
2. Remove the intake manifold
3. Remove the Valve cover
4. Remove the chain tensioner
5. Remove the head bolts
6. Install hoist
7. Gently hoist up the head a few inches
8. Remove old Head Gasket through the gap
9. Clean surfaces through gap as best as possible
9. Install new Head gasket through the gap
10. Lower the head carefully
11. Reassemble
This would eliminate taking off anything on the exhaust manifold side and the Vanos and chains.
Of course you can not inspect and test the head this way, but I recently had that done and am reasonably sure that's not the problem. Anybody done this?
tommytoyz is offline   Reply With Quote
Old 03-11-2012, 03:03 PM   #2
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
So your saying you didn't send the head off to a machine shop to at least be checked?
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 03-11-2012, 03:44 PM   #3
SweetBMW
My Ride: 318CIA
If you're sure anything didnt twist or deform, this will work. But its not the recommended way.
SweetBMW is offline   Reply With Quote
Old 03-11-2012, 11:14 PM   #4
tommytoyz
Yes, the 1st time I did send the head off to have it checked and resurfaced. I know it is not the recommended way, but would make it doable in half the time - or even faster. I only have about 5,000 miles since I did the head gasket and everything was perfect, until a few days ago, when I started using up coolant and a few other signs that - unfortunately - make it pretty clear to me the gasket is not holding for some reason.
I might do it the traditional way, as I was planning on changing the clutch and rear seal, which requires removal of the exhaust and detaching from the exhaust manifold. But not sure yet.
I think a hoist is mandatory in any case - regardless of method - because even with 2 people, it's too easy to nick it on installation onto the new gasket. The head is just too big and heavy.
At least I'll be much faster the 2nd time as I know exactly where everything is and how it comes apart and back together. No more hours of searching for a way to get something off or on.....
Old 03-12-2012, 03:01 AM   #5
My Ride: Lexus
Sounds like you're asking for approval for doing something half-assed. You're going through all that work, don't gamble with your time.
INB4 blockedout
Old 03-12-2012, 09:46 PM   #6
tommytoyz
I was asking if anyone had done it this way once before or not. It seems like I'll do it the long way....again
Old 03-12-2012, 10:47 PM   #7
Brinkley
My Ride: 99 328i, 07 z4 3.0
How is this really a shortcut? You're doing all that work and then instead of removing head and doing job properly you will just save the 60 seconds to hoist head up and remove from car. Did you get the head checked last time? What about the studs were you able to re-torque all to spec? I'm all about saving time/money but I will say that this particular job, if being done, is one that should be done right.
Brinkley is offline   Reply With Quote
Old 01-10-2013, 05:11 PM   #8
DonnieC
My Ride: BMW E46 323i
How much did the head gasket you put in cost you? I just dropped my car off at the mechanic less than an hour ago and it was overheating really bad. I could see there was antifreeze leaking out underneath the hood area of the car but not really smoking from the tail pipe just the hood.
DonnieC is offline   Reply With Quote
Old 01-10-2013, 05:44 PM   #9
WDE46
My Ride: '13 128i, '04 330Ci
Your expansion tank probably blew up. That is the most common thing. AFTER your ET blows up, you lose all your coolant, overheat, and if you aren't fast enough, you can blow the headgasket and warp the head. IF you turned it off fast enough, then you just need to do a cooling system overhaul.
Old 01-10-2013, 06:38 PM   #10
willsbma
My Ride: 99 323i
Could be one of the hard coolant pipes under the manifold too.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
diy, head gasket, shortcut
