G-Power ASA T3-313 on 330xi M54B30 / GM 5L40-E - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.60 average. Display Modes
Old 05-07-2012, 10:05 AM   #41
NickG
My Ride: 2011 BMW 550i M-Spor
Originally Posted by Hageee View Post
After that i bought a e39 fuel-filter, which has a very nice addon against the e46-fuel-filter: a changeable fuel-pressure-regulator. With a 4 Bar (58PSI) Regulartor, instead of 3.5 Bar (50PSI), the engine gets more fuel.
You're wasting your time doing this. The increased fuel pressure will cause the mixture to be richer than it should be. The ECU will see this richer mixture during part throttle (via the O2 sensors) and lean it back out over time with the lambda adaption. The end result will be the EXACT same mixture as running the PROPER 3.5bar regulator.
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
Old 05-07-2012, 03:01 PM   #42
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
... It works, becouse the stock injectors are not able deliver enough fuel by 3.5 Bar. Running Engine after 5500 RPM, the mixture getting lean, opened the fuel injectors @ 95% PWR by custom tune, but with full time opened, not enough fuel available for Lambda 0,87 ~ 0,88.
With the 4,0 Bar Pressure Regulator, the fuel pressure is higher, and the injectors are delivering more fuel into the cylinder. With the custom tune and a 90% PWR, Lambda 0,83 is able - we only needed 0,87.
Under partitial load, the mapping is running a little bit rich, but lamdba-adaptions are ~ -1,38 on 1-3 and -0,83 on 4-6. Perfect.
Getting ~ 320 HP and a failure-entry in the gearbox "over 400NM"
Hageee is offline   Reply With Quote
Old 05-29-2012, 04:12 AM   #43
Hageee
My Ride: E46 330xiA
Old 07-22-2012, 08:36 AM   #44
Hageee
My Ride: E46 330xiA
Modified the Air-Induction, DME-Software, EGS-Software, More Fuel Pressure and more Pressure
Old 07-30-2012, 10:24 AM   #45
Hageee
My Ride: E46 330xiA
Nissan 370Z ... Done
900RR Suzuki ... Done
165 mph Speed-Test ... Done
Old 01-09-2013, 02:42 PM   #46
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
I did not see any cold range sparkplugs nor bigger injectors in the kit.
Jim
Jim Murphy is offline   Reply With Quote
Old 01-09-2013, 05:10 PM   #47
Hageee
My Ride: E46 330xiA
Spark-Plugs are colder ones and Injectors are Stock, but with higher pressure.
Old 01-10-2013, 12:18 AM   #48
mexsir
My Ride: E46 320 M sport
At what rpm do you start making boost? And at what rpm do you reach half your total boost? Looks like all the power is way up top.
320i M Sport 02 with laughing gas
mexsir is offline   Reply With Quote
Old 01-10-2013, 12:20 AM   #49
WALKD U
My Ride: Just Fast!
it is....
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 01-10-2013, 04:54 PM   #50
Hageee
My Ride: E46 330xiA
Hmm? Please explain to me, what you mean with "...looks like all the power is way up top" ?
Boost is rising constant, from 2000 rpm 0,1 bar; 3000 rpm 0,2 bar; 4000 rpm 0,3 bar, 4500 rpm 0,4 bar 5000 rpm 0,5 bar ...
Old 01-10-2013, 08:54 PM   #51
WALKD U
My Ride: Just Fast!
Talking about Peak/Full BOOST.
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 01-10-2013, 09:40 PM   #52
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
can you please confirm that your pressure regulator from the e39 is indeed a 4.0 BAR regulator. I couldn't find the 4.0 bar regulator on the bmw database. do you have the part number to either the reguator or the entire fuel filter?
Old 01-11-2013, 04:13 AM   #53
Hageee
My Ride: E46 330xiA
i can't confirm, becouse this information is not correct.
e39 530i fuel filter (with pressure regulator) is 3.5 Bar (like E46) - but the pressure regulator is "changable" becouse its secured by a splint. You can release the splint, remove the stock 3.5 bar pressure regulator and replace this one with a bigger one (4.0 bar or more...)
but be careful:
the stock fuel pump is only able to deliver enough fuel @ 4,0 bar. More pressure = less fuel, becouse the stock fuel-pump isn't able to produce so much boost on the fuel rail @ WOT!
Old 01-11-2014, 09:49 AM   #54
dany325tim
My Ride: E46 325 ti
Hi Hageee, I'm also looking to install the G-Power SK Plus RS "Sporty Drive" (ASA T3-313 SC) on my stock 325ti and I'm doing some research.
After almost one year or so from your install, can I ask you how well was your experience with it? Were you satisfied? What about performance, quality, issues, service support? Is it too noisy? any other important thing you can share?
Thanks in advance!
Daniel
dany325tim is offline   Reply With Quote
Old 01-12-2014, 11:05 AM   #55
daniel_f.
My Ride: 330iC
hello Daniel,
Phil sold the car a few month back and currently hes enjoying a Alpina B5S with more then enough hp.
i dont know if hes still watching this forum.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 01-12-2014, 11:10 AM   #56
dany325tim
My Ride: E46 325 ti
Originally Posted by daniel_f. View Post
hello Daniel,
Thanks for the advise Daniel! So I'll pm Phil to see if I can contact him!
BR
Old 01-13-2014, 05:48 AM   #57
Hageee
My Ride: E46 330xiA
Hello,
i'm reading
I've sold my supercharged car at a friend. I've asked him two weeks ago, about any problems: Nothing. He isn't a technician or someone who "knows" what a supercharger-kit is - he is someone who's sitting in the car and only drives
With the kit, the Engine runs about 35.000 miles without any problems. he's only changing the oil with 10w60 shell helix racing, about 7500 - 10000 miles.
Old 01-12-2015, 12:29 PM   #58
BimmaBwoy
BimmaBwoy's Avatar
My Ride: 2003 325i
Send a message via AIM to BimmaBwoy
Guys, I have a SK+ S/c on my 330 and I'm having a ton of trouble trying to get some support for it. Can anyone help me? I'm looking for some maintenance parts, software/tune. I'd love to speak with someone as my car is still running but is misfiring like crazy and sometimes stalls on idle. Hageee I've tried going to G-Power's website and sending them an e-mail but I haven't gotten anyresponses. Is there a phone number which I can call from US? How much do the maintenance kits cost? I see it on their sites but I'm trying to translate the costs to USD. Any/all help appreciated.
-If you look up your nothing close to the rich but if you look down, your way better off than the poor- Yellowmann
Get your Calendar/Poster here:http://stores.lulu.com/bimmercalendars
Release thread: http://forum.e46fanatics.com/showthread.php?p=7663111
BimmaBwoy is offline   Reply With Quote
Old 02-09-2015, 04:54 PM   #59
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
HP motorsports is the US importer for g power. I tried reaching g power directly a few times using google translate but I don't think it did a good enough of a job for them to have any clue what I wanted. I believe the forum member 03_330ci studied german for a semester and then was able to make an arrangement with them.
drumbum624 is offline   Reply With Quote
Old 02-09-2015, 05:42 PM   #60
BimmaBwoy
BimmaBwoy's Avatar
My Ride: 2003 325i
Ive been able to make contact by going thru a company in Florida named psi. They arranged payment for me as GPower would only accept wire transfers. I didnt feel comfortable with that so they made the payment for me. My car has been down about a month now and will probably be down another 4 weeks till payment clears, shipping happens, and then the actual fix.
