Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Cost estimate for brake pad replacement??
My brake pad sensor went on a few weeks ago so I'm trying to get an idea on how much it's going to cost to replace them. Last time I paid $730 for new pads and rotors. Looking back at some past threads, I think I paid too much. Anyway, I'm going to be getting rid of the car next year so I need the lowest cost replacement. I'm assuming I won't be needing new rotors since the light just went on and probably on have about under 200 miles since the warning light went on. Can someone give me a rough idea on the cost? I don't have the tools or garage to do a DIY, so I'll have to take it to a mechanic. Last time they charged $240 for labor (brakes and rotor). Thanks.
#2 |
Dude people sell new and used pads on here. I have a set of sensors brand new and used pads..
#3 |
Check the sponsor vendors, a set of pads and a new sensor should cost approx $60-$100... not 5 times that.
![]() 2003 325XI 5-speed ZSP ZPP |
#4 |
look on craigslist or kijiji for afterhour mechanics... I charge $50 for labour to do front or back brakes.. $100 for both with pads and rotors.
Sent from my SGH-I727R using Bimmer App |
#5 | |
Word to the OP. You don't feel any sense of responsibility to the poor sap who ends up with your car? Put some decent brakes on her. Doesn't matter whether you are selling her. |
#6 |
Stay stock my friends!
OP...textar pads are OE...see bmaparts.com around $50...sensor is cheap...you probably don't need rotors, you know.
Cost, as said, about $60...plus maybe 2 hours of reading time so you know what to do.
#7 |
THanks. Is that $50-60 for each? So about $100-120 for all 4? Also, what would be a reasonable amount to pay for labor? Perhaps a range would be nice? Thank you.
#8 | |
Get it off the ramp and road test = 15 minutes. Total 1 hour 30 minutes. |
#9 |
$60/axle...but, if you did all four corners, pads and rotors, I'd bet you anything that all you need is the front pads and sensor. The rear pads would be fine for almost twice the miles...all rotors should take another set of pads fine.
You might add some time to Ray's estimate...no need to race...and clean up the mating surfaces well...clean/grease guidepin bushings...anti-squeal cream on the back of pads...that's about it. BTW, bmw tis says 'don't' grease the guidepin bushing, but many here do...and my rebuilt calipers came greased...just use brake grease!
#10 | |
Weagle Weagle
Oh and if you replaced the rotors last time, then you don't need to get new ones. Just do the pads and have the rotors turned on a lathe if they are uneven. Last edited by WDE46; 01-11-2013 at 07:56 AM. |
#11 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
The hardest part of the whole job is removing the caliper carrier. Mine always gets seized in there really good. I almost want to use anti-seize in the bolts, but I'm afraid of doing that. I stripped my bolt with a breaker bar. Now I need to use an impact wrench and bolt extractor kit.
E46Fanatic's resident mathemagician
#12 | |
I've seen some tricks on youtube for popping fused rotors off using some bolts and the caliper mounting bracket - any of you guys have other tricks for separating a fused rotor from the hub? I've got this job coming up in the spring/summer - which is why I ask. Thanks! -G |
#13 |
Since you don't have the ability to DIY your labor costs might be about $100/hr all depending on the shop. My guess would be 2-4 hrs of labor depending on the shop(try searching in here for some actuals to have #'s to compare it to). So add that to the cost of parts that you buy and you should have a rough estimate.
#14 |
I paid 560. 360 for Zimmerman rotors and Pagid pads and 180 for installation. I would by the stuff and have someone install it just ask for a quote beforehand.
oem Clears/35% Tint/ECIS Intake/Eibach Pro-System/Bimmian Interior Light Kit/oem Pedals/EAS 4500k HID/oem Mtech II Front, Side Skirts/19 OZ Superturismo GT
#15 | |
Weagle Weagle
#16 | |
#17 |
Just do it your self so easy
#18 |
How about for someone that's never done this before so I'd be following instructions while doing the repair work. Also, can this be done with a simple jack one wheel at a time? I'm thinking about searching for afterhours mechanics vs. DIY but if I do it myself, then I'd have to make sure I have all the tools and extra parts in order. Do you think an afterhours mechanic (say from Craigslist) can do all four wheels (just pads and sensors, not rotors) for say 2 hours labor? Thanks again for the replies.
#19 |
I paid 600$ including labor. Brembo pads and rotors.
#20 |
My Ride: 1999 323i 5-SPD
What part of VA are you in? I can do the replacement easily. I live in MD. PM me if you want to try and work out details. I've done it on my car and my brothers e46.
MODS P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter Last edited by moiz21; 01-11-2013 at 05:34 PM. |
