Differences between genuine & replica - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 01-10-2013, 05:48 PM   #1
brett05
My Ride: 325Ci
What markings or stampings in particular should one look for on genuine vs replica M3 wheels?
Cheers, Brett
brett05 is offline   Reply With Quote
Old 01-10-2013, 06:40 PM   #2
_k
My Ride: e46 coupe
BMW markings. period.
should be pretty easy to spot the difference, most replicas will also have non oem offsets and other specs etc. if you cant already tell the difference, the BMW marking stamp will verify authenticity,
_k is offline   Reply With Quote
Old 01-10-2013, 06:47 PM   #3
brett05
My Ride: 325Ci
Cool. Thanks for that. Just wanted to be certain.
Cheers, Brett
Old 01-10-2013, 07:16 PM   #4
zha50
My Ride: '04 325ci 5MT
Wheel specs as well. M3 offsets do not fit the non-m without a fair bit of body work and stretching.
Stock / OEM offsets for E46 M3 should be
18's
Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47
Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26
And 19 should be:
Front Wheels: 19" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47
Rear Wheels: 19" x 9.5" -- Bolt Pattern = 5x120mm. Offset = ET27
'04 325ci M-sport 5MT
- Bone stock -
zha50 is offline   Reply With Quote
Old 01-10-2013, 07:56 PM   #5
brett05
My Ride: 325Ci
Thanks. I fitted a set of 18x9's on the rear of my 325ci and they fit OK but just slightly protrude past the extent of the guard. I haven't driven with them on but would imagine there would be some rubbing. I'm going to look for another set, so I can run 18x8's all round.
Cheers, Brett
Old 01-10-2013, 10:13 PM   #6
DeclanM3
My Ride: 332Ci
Cheers, Brett
What tyre have you got on there at the moment? I reckon something around a 225/40/18 would be perfect.
The fronts aren't very aggressive though so they may sit in too much. Rear's all round would be nice.
Previous sizes fitted were 235/35/19 on a 19x8.5 et35 & 265/30/19 on a 19x9.5 ET45. Clearance wise I had maybe 2mm on the rear and a fair bit more on the front.
On an 18" you should have a touch more clearance which is why I think you could get away with the 225. If you go to somewhere like Option1 garage and advise you want to buy tyres and think a 225 will work but will want a 215 if not they will probably be happy to fit up a 225, see how it looks then decide if you should go smaller or not.
DeclanM3 is offline   Reply With Quote
Old 01-10-2013, 11:28 PM   #7
brett05
My Ride: 325Ci
Yeah I was thinking that something like a 235/40 would work. They've got 255/40's on there at the moment, but the problem is the edge of the rim looks to physically sit outside the extents of the bodywork. It's slightly hard to definitively tell with the big 255 on there though.
Cheers, Brett
Old 01-11-2013, 12:03 AM   #8
DeclanM3
My Ride: 332Ci
Your rim should stick out 12mm further than this. By 'stretching' the 225 the rim will sit pretty flush with the guards and the tyre will tuck in nicely! I think it's definitely worth trying to fit before you buy another set and run 4 fronts. An 8" +47 will look terrible on the rear!
Old 01-11-2013, 12:20 AM   #9
brett05
My Ride: 325Ci
hmmm..... I might fit them up again on the weekend and take some photos and post them up here.
I spoke to Option 1 and the smallest legal tyre they can fit on it is a 235/40 without stretching a 215 or a 225. I'd prefer to stay fairly legal if I can get it to work. A 235 would buy me an extra 10mm on the outside over the 255.
Cheers, Brett
Old 01-11-2013, 12:56 AM   #10
niiCk
My Ride: E90
ive fitted the 18x9 +26s onto my old e46 sedan. I ran a 225/40/18 and they did no protrude past the guards..they were rolled though and i was lowered..i guess if you play around with camber, you'll get it sitting nice. You can run a square set up easily. a 235/40 should be sweet since you have a coupe which has abit wider guards than a sedan.
i also fitted a 19x9.5 +27 with a 225/35/19 tyre and they was flush as fk! i loved the look.
niiCk is offline   Reply With Quote
Old 01-11-2013, 12:58 AM   #11
niiCk
My Ride: E90
the one thing i hated was the fronts..so get yourself another pair of rears!
Old 01-11-2013, 01:35 AM   #12
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Hey Nick you got any pics of the 19's on your car so we can can compare the 18's vs 19's.
Shannon.
shannon1 is offline   Reply With Quote
Old 01-11-2013, 01:57 AM   #13
brett05
My Ride: 325Ci
Looks great Nick. The 225's don't look too stretched.
Old 01-11-2013, 02:02 AM   #14
DeclanM3
My Ride: 332Ci
Cheers, Brett
This is a 215 on an 8" wide rim. From everything I've read a 225/40/18 should be legal on an 8" rim but I could be wrong.
Even the 215 doesn't look stretched.
Old 01-11-2013, 02:06 AM   #15
brett05
My Ride: 325Ci
225 would be fine on a 8", but on a 9" I think a 235 would be the smallest legal size.
Cheers, Brett
Old 01-11-2013, 02:43 AM   #16
DeclanM3
My Ride: 332Ci
Cheers, Brett
Oh sorry my bad! I put in 8" not 9"
Old 01-11-2013, 04:20 AM   #17
niiCk
My Ride: E90
Took an effort to scrape up the pics but here they are:
when i lowered it abit more lol:
i really loved the fitment on the 19s. But 18s were more conservative..running a 225/40 on the 9" were fine..couldnt even tell it was stretched.
Even the 225/35/19s on the 9.5s were alright but thats probably the most i'd go. *in before hamann wheels*
Old 01-11-2013, 04:21 AM   #18
niiCk
My Ride: E90
also, if you max out the camber it'll fit fine..i just never touched mine
Old 01-14-2013, 06:20 AM   #19
brett05
My Ride: 325Ci
OK so I fitted them all up on Saturday. The 9" rears fill out the guards beautifully, but there was a lot of rubbing in the rear and I even think there still will be with a smaller 235/40. The guard was cutting well into the top of the tyre as soon as any slight lateral load was applied to the car.
These shots show the 18x9" rears with 255/40 tyres.
I think I will go with the more conservative option of 8's all round. Just need to find a couple more 18x8's now.
The 18x8" all round.
Cheers, Brett
Old 01-14-2013, 06:34 AM   #20
DeclanM3
My Ride: 332Ci
They are the first photos I've seen since selling it Brett. Brings back awesome memories. I really do miss that car!
I think the 9's all round would look great but it all comes down to personal preference. I might be interested in your 4 x 9" rears for some track wheels if I have storage at the next house I move to.
