Sponsored by BimmerWorld
Old 01-10-2013, 11:01 PM   #1
AC Yate
My Ride: BMW E46
Cost estimate for brake pad replacement??
My brake pad sensor went on a few weeks ago so I'm trying to get an idea on how much it's going to cost to replace them. Last time I paid $730 for new pads and rotors. Looking back at some past threads, I think I paid too much. Anyway, I'm going to be getting rid of the car next year so I need the lowest cost replacement. I'm assuming I won't be needing new rotors since the light just went on and probably on have about under 200 miles since the warning light went on. Can someone give me a rough idea on the cost? I don't have the tools or garage to do a DIY, so I'll have to take it to a mechanic. Last time they charged $240 for labor (brakes and rotor). Thanks.
AC Yate is offline   Reply With Quote
Old 01-10-2013, 11:54 PM   #2
trentcdrums
My Ride: BMW 323i Sedan
Dude people sell new and used pads on here. I have a set of sensors brand new and used pads..
Old 01-11-2013, 12:02 AM   #3
My325XI
My Ride: 03 325XI Sprt Prem
Check the sponsor vendors, a set of pads and a new sensor should cost approx $60-$100... not 5 times that.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-11-2013, 12:12 AM   #4
pawelgawel
My Ride: 330CI
look on craigslist or kijiji for afterhour mechanics... I charge $50 for labour to do front or back brakes.. $100 for both with pads and rotors.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 01-11-2013, 06:42 AM   #5
RayPooley
My Ride: 320i SE Coupe
You would really put USED pads on your car? Pads that have been formed to different rotors? You might want to cheap out, fair enough, but stopping the car is not the place to do so. You can buy pads all round for what? $120? You can spend that on a night out on the piss.
Word to the OP. You don't feel any sense of responsibility to the poor sap who ends up with your car? Put some decent brakes on her. Doesn't matter whether you are selling her.
Old 01-11-2013, 07:00 AM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP...textar pads are OE...see bmaparts.com around $50...sensor is cheap...you probably don't need rotors, you know.
Cost, as said, about $60...plus maybe 2 hours of reading time so you know what to do.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-11-2013, 07:09 AM   #7
AC Yate
My Ride: BMW E46
THanks. Is that $50-60 for each? So about $100-120 for all 4? Also, what would be a reasonable amount to pay for labor? Perhaps a range would be nice? Thank you.
Old 01-11-2013, 07:14 AM   #8
RayPooley
Get it on the ramp. Jack it up = 15 minutes. 15 minutes per wheel = 1 hour.
Get it off the ramp and road test = 15 minutes. Total 1 hour 30 minutes.
Old 01-11-2013, 07:31 AM   #9
dmax
dmax's Avatar
$60/axle...but, if you did all four corners, pads and rotors, I'd bet you anything that all you need is the front pads and sensor. The rear pads would be fine for almost twice the miles...all rotors should take another set of pads fine.
You might add some time to Ray's estimate...no need to race...and clean up the mating surfaces well...clean/grease guidepin bushings...anti-squeal cream on the back of pads...that's about it. BTW, bmw tis says 'don't' grease the guidepin bushing, but many here do...and my rebuilt calipers came greased...just use brake grease!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-11-2013, 08:55 AM   #10
WDE46
My Ride: '13 128i, '04 330Ci
I bought Zimmerman rotors and ATE pads from BMAParts.com for about $300 total. Labor shouldn't be more than 2 hours. I can do the job myself in about that time and I don't get to use a lift like the mechanic will. It should be $500 total for the job I would guess. I should note that there isn't anything "BMW special" about our brakes, so it's a very easy DIY if you have a jack and stands, but you already said you don't.
Oh and if you replaced the rotors last time, then you don't need to get new ones. Just do the pads and have the rotors turned on a lathe if they are uneven.
Old 01-11-2013, 09:19 AM   #11
Zell
Zell's Avatar
My Ride: so turbo wow
The hardest part of the whole job is removing the caliper carrier. Mine always gets seized in there really good. I almost want to use anti-seize in the bolts, but I'm afraid of doing that. I stripped my bolt with a breaker bar. Now I need to use an impact wrench and bolt extractor kit.
Old 01-11-2013, 09:23 AM   #12
GSherbs
My Ride: 2002 330 xi
Yeah - about right assuming the rotors aren't fused to the hub. If they are, could be a much longer and more frustrating job I think?
I've seen some tricks on youtube for popping fused rotors off using some bolts and the caliper mounting bracket - any of you guys have other tricks for separating a fused rotor from the hub?
I've got this job coming up in the spring/summer - which is why I ask.
Thanks!
-G
GSherbs is offline   Reply With Quote
Old 01-11-2013, 09:28 AM   #13
Miko_10
My Ride: 330i 5 Spd
Since you don't have the ability to DIY your labor costs might be about $100/hr all depending on the shop. My guess would be 2-4 hrs of labor depending on the shop(try searching in here for some actuals to have #'s to compare it to). So add that to the cost of parts that you buy and you should have a rough estimate.
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 01-11-2013, 09:32 AM   #14
Manny330
My Ride: 02 330i
Send a message via AIM to Manny330
I paid 560. 360 for Zimmerman rotors and Pagid pads and 180 for installation. I would by the stuff and have someone install it just ask for a quote beforehand.
Stock
Manny330 is offline   Reply With Quote
Old 01-11-2013, 09:42 AM   #15
WDE46
Thanks!
-G
They should come off quite easily with a hammer assuming you can get the rotor screw out. Just smack the top edge with a hammer and keep your toes out of the way.
Old 01-11-2013, 10:07 AM   #16
Jesse M
My Ride: 05' ZHP
Most shops charge around 1.5-2 hours to do a brake job. That's about $150-200. Try going to the dealership and talk to one of the techs, he might know someone who is willing to do it on the side or after the shop closes. Saves you money and puts cash in his pocket.
Jesse M is offline   Reply With Quote
Old 01-11-2013, 10:38 AM   #17
omg A e46
My Ride: 323i
Just do it your self so easy
omg A e46 is offline   Reply With Quote
Old 01-11-2013, 06:11 PM   #18
AC Yate
My Ride: BMW E46
How about for someone that's never done this before so I'd be following instructions while doing the repair work. Also, can this be done with a simple jack one wheel at a time? I'm thinking about searching for afterhours mechanics vs. DIY but if I do it myself, then I'd have to make sure I have all the tools and extra parts in order. Do you think an afterhours mechanic (say from Craigslist) can do all four wheels (just pads and sensors, not rotors) for say 2 hours labor? Thanks again for the replies.
Old 01-11-2013, 06:27 PM   #19
Snapasaurus
My Ride: 2005 325i SULEV
I paid 600$ including labor. Brembo pads and rotors.
Snapasaurus is offline   Reply With Quote
Old 01-11-2013, 06:32 PM   #20
moiz21
My Ride: 1999 323i 5-SPD
What part of VA are you in? I can do the replacement easily. I live in MD. PM me if you want to try and work out details. I've done it on my car and my brothers e46.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
