General Off-Topic
Old 01-09-2013, 03:42 PM   #1
beemerfreak
My Ride: 05' 545I, 03' 325I
Ever Had Cold Start Issue?
My car is a 2005 545I
I know this is off topic but hopefully I can get help from u guys.
My car has a cold start issue.
It doesn't start under 50 degree weather.
It cranks but won't turn over.
Anything over 50 degrees it starts and drives normal.
No cel.
It currently has no codes but had codes when I first scanned it.
I've changed battery, spark plugs, cam shaft sensor, and IVM module.
We've checked fuel pressure etc..
Any help?
beemerfreak is offline   Reply With Quote
Old 01-09-2013, 04:05 PM   #2
pakman3
My Ride: piece
crank position sensor
pakman3 is offline   Reply With Quote
Old 01-09-2013, 04:08 PM   #3
beemerfreak
It should throw a code right?
Old 01-12-2013, 03:30 PM   #4
crime
My Ride: 2002 325i
Cold start sensor - my 02 325i just had the same problem.
crime is offline   Reply With Quote
Old 01-12-2013, 04:06 PM   #5
Grande D
My Ride: zhpppppp (o-m-g!)
Dude. Google. C'mon now. Having said that:
http://www.bimmerfest.com/forums/sho...d.php?t=579724
http://www.bimmerfest.com/forums/showthread.php?t=83757
Crankshaft sensor(s) or software.
Old 01-12-2013, 05:24 PM   #6
rsxstock
My Ride: 2001 325ci
mine starts right up even at below freezing. maybe try leaving the key in the on position for a few secs to get the fuel pump running, then start
rsxstock is offline   Reply With Quote
Old 01-12-2013, 06:39 PM   #7
AfghanScarface
My Ride: Debadged M3
Send a message via AIM to AfghanScarface
The fuel pump only needs to prime for a second or so to provide adequate fuel for ignition, no?
Originally Posted by Bimmer4Lyfe View Post
Either pursue her and risk getting Mono, or don't pursue her,...stay home and use your Mano.
It's either Mono or Mano .... You decide
AfghanScarface is offline   Reply With Quote
Old 01-12-2013, 06:44 PM   #8
v8 5
My Ride: 6 speed BMW
Fuel filter would be my guess, it's an 05...
Gutted with a Getrag
v8 5 is online now   Reply With Quote
