Old 01-12-2013, 10:58 PM   #1
evo7
My Ride: 330i
Drove without oil cap. Now getting SES codes
Silly me! Did the OFHG today. Forgot to put the oil cap back on after adding some oil. Drove about 2-4 miles to a store. Noticed the engine was having few hiccups along the way, and idling was a little abnormal. So after putting the oil cap back on, the car ran like normal. But after about 15-20 mins of driving, SES light came on and gave the following codes....
CURRENT FAULT CODE:
P0174 (System too lean Bank 1)
PENDING CODES:
P0171 (System too lean Bank 2)
Misfiring cyl 1,2,3,5,6
I assumed the P0174 and the pending codes are a result of driving without the oil cap. I dont think I did any harm to the engine and clearing the codes should be fine. I just want to get a second opinion. Any thoughts?
evo7 is offline   Reply With Quote
Old 01-12-2013, 11:08 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Our engines go hundreds of thousands of miles...it won't care that you drove without the oil cap for a couple of miles. Clear the codes and I'm sure you'll be fine too.
If not, can I buy your amp for cheap?
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 01-12-2013, 11:15 PM   #3
BimmersGarage
My Ride: E46 330i
You should be fine now.
Clear the codes, good to go.
BimmersGarage is offline   Reply With Quote
Old 01-12-2013, 11:20 PM   #4
Zell
Zell's Avatar
My Ride: so turbo wow
Yes that's probably all it was.
Old 01-13-2013, 09:01 AM   #5
lmr2wil
My Ride: '00 328Ci
You were undoubtedly pulling some unmetered air through the CCV system causing the car to run lean. As said, clear the codes and you should be good to go.
Luke
lmr2wil is offline   Reply With Quote
