Old 01-13-2013, 11:43 AM   #1
Kris.R
My Ride: 2012 Dodge Charger
Question HID Fog Light install: question about ground wire
Hey guys I just received my TRS 9006 morimoto kit for my fogs and I'm not really sure as to where I should mount the ground wires. Each ballast has a ground wire and its not that long in length.
I've attached a pic to show what I'm talking about.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 01-13-2013, 12:25 PM   #2
christiandflores
My Ride: BMW M3 E46
Loosen up a nearby bolt that's connected to themetal on the frame. Then tighten back up
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | ZCP | SMG | 40% Tint | LED Interior/Exterior
Join Us at the San Diego North County Monthly BMW Meet
christiandflores is offline   Reply With Quote
Old 01-13-2013, 12:28 PM   #3
Kris.R
^ Do you think the bumper carrier itself be a good source for ground?
- Kris -
-Abraham Lincoln-
Old 01-13-2013, 12:36 PM   #4
RKiepper
My Ride: 1999 E46 328I x2
No.
Run an extra wire with the fog light harness to a ground point that is part of the frame.
RKiepper is offline   Reply With Quote
Old 01-13-2013, 12:50 PM   #5
Kris.R
^ Ok sounds good. Thanks guys!
- Kris -
-Abraham Lincoln-
Old 01-13-2013, 01:01 PM   #6
BWOODM3
My Ride: 2002 M3 convertible
Lets us know how it's turns out
BWOODM3 is offline   Reply With Quote
Old 01-13-2013, 01:53 PM   #7
loffa
My Ride: 2001 330ci
There is an easier way you can just unplug the harness at the hid ballast (on the other end of the gnd wire you are holding in the pic) and plug the hid ballast directly to your OEM fog light harnesses connector. And then you can throw away the harness you removed from the kit, it is meant for cars that do not have 9006 bulbs to begin with.
If anything was unclear, throw me a message and I'll draw you a pic in paint
Sent from my HTC One S using Bimmer App
loffa is offline   Reply With Quote
Old 01-13-2013, 05:04 PM   #8
Kris.R
^ would you mind drawing a diagram?
- Kris -
-Abraham Lincoln-
Old 01-13-2013, 06:43 PM   #9
Kris.R
UPDATE:
Ok guys so what I ended up doing was joining the two ground wires from each harness and ran a longer wire to the negative battery post to the terminal. Everything fired up!
P.S. I tried loffa's method (of which I appreciate the input) but in my case, I got the infamous instrument cluster light flicker/blip. If you have ever experienced this you know that the cluster's high beam icon flickers once very quickly, and in turn can possibly cause damage to the ECM.
- Kris -
-Abraham Lincoln-
Old 01-16-2013, 11:29 PM   #10
Tchleung
My Ride: 02 M3
UPDATE.S. I tried loffa's method (of which I appreciate the input) but in my case, I got the infamous instrument cluster light flicker/blip. If you have ever experienced this you know that the cluster's high beam icon flickers once very quickly, and in turn can possibly cause damage to the ECM.
And that's precisely why one should never wire HIDS directly to both positive and negative leads of the factory fog harness. Everyone always tries to go the easy way about things but it usually doesn't pay off :p
Glad you got it working well!!
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi
4.10 / Headers / ESS VT2-550+ / Tuned by Evolve
Tchleung is online now   Reply With Quote
Old 01-17-2013, 01:43 AM   #11
loffa
My Ride: 2001 330ci
The instrument cluster flick happens because of a bad connection in one of the connectors (possibly connector not correctly seated or oxidized. Could also be on the other end of the factory harness (oxidized OEM ground)). In theory, the factory harness has enough wire thickness to deliver the needed amount of current to start up the hids correctly. I have managed to get all the hid kits working with the OEM harness (I've installed them on about 5 different E46) by cleaning the OEM connector and ensuring that it is seated properly.
But if you got it working with a separate ground its all good
Old 01-17-2013, 04:19 PM   #12
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
UPDATE:
I used the ground from the bumper carrier(reinforcement), there are 2 13mm nuts on each side of the carrier.
I have the same issue with the high beam icon flickering.
Sent from my ADR6425LVW using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 01-17-2013, 10:41 PM   #13
Tchleung
My Ride: 02 M3
It's not the wire gauge that is the issue, it's the LCM not being able to handle the fire up of HIDS.
Old 01-18-2013, 11:42 AM   #14
rizwan1377
Thats why i used a relay to handle the fire up.
Old 01-18-2013, 12:06 PM   #15
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Shouldn't be running HIDs in the fog lights period.
