How much does VANOS do? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2013, 02:09 PM   #1
Weste46
My Ride: 2001 330ci
I'm trying to eliminate some possibilities of a problem I've been having. Yesterday, I unplugged, cleaned, and tightened the connections of the VANOS solenoids, both exhaust and intake side. I drove it afterwards last night with no change, and this morning with no change. Then, before leaving work I turned in the car and got a CEL (P1525), which is apparently a bad VANOS intake solenoid connection. This is supposed to therefore put me on a pre-determined VANOS mapping, which will reduce power, correct? I felt absolutely no difference in power and MPG was exactly the same.
Could this mean I've had a problem with the solenoid and cleaning the connection just finally showed there was one? I checked the connection, and unless I somehow damaged the wiring there's nothing wrong.
Thanks!
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, 95a FCA, 75d rear subframe, 95a RTA, 95a RCA, 88a diff., 75a swaybar mounts, ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, intake, headers, x-pipe, open-loop EU2 tune, ~180lbs weight reduction.
Weste46 is offline   Reply With Quote
Old 01-13-2013, 02:35 PM   #2
WDE46
My Ride: '13 128i STX
No you definitely did something to cause this.
Old 01-13-2013, 02:38 PM   #3
Weste46
My Ride: 2001 330ci
Yes I did, already solved.. shouldn't have made a thread. The connections were fitted tightly outside, but the pins on the wire-side connection had actually sunk into the connector so they were not in contact.. weird. I just pushed them back up and all is well.. dumb mistake, my apologies!
Sponsored Links
Advertisement
Old 01-13-2013, 02:47 PM   #4
Weste46
My Ride: 2001 330ci
Still, very odd that a disengaged VANOS felt exactly the same as normal driving.. hmm.
