Old 01-12-2013, 05:20 PM   #1
arkadur
My Ride: E46 323CI
very weird start problem
in the last 2 weeks, my car wont start in the first try.
- i scanned the car for errors or trouble cods - nothing there.
- the battery inst new, but still have "juice". the Vdroop while starting is around 9V. when the car off - 12.5V, when turned on - ~14.5.
- the starter working great, i cant hear any missing tooth or gear problem, and there is no fading - the battery do the work.
- it isn't fuel problem. i tried different gas stations.
- statistically, it happen more with the door open (internal light - on)
- in the second try - the car start immediately. (every time)
- it happen ~ once a day.
i'm not sure, but what do you think about current leakage? (i have nothing except the OEM alarm)
i have no clue what to look for. please - help me.
arkadur is offline   Reply With Quote
Old 01-12-2013, 05:35 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Let me get my "Easy Button" sounds like a classic ignition switch issue... The tell-tale sign is the dashboard illumination. When it doesn't start you will be missing one or two dashboard luminaries...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 01-14-2013, 05:30 AM   #3
arkadur
My Ride: E46 323CI
i cant find any missing dashboard luminaries,
there is something else that cause this problem?
Old 08-17-2015, 01:26 AM   #4
arkadur
My Ride: E46 323CI
Bump.
Same story again, after along time.
Any clue what can cause this?
Sent from my D5803 using Tapatalk
Old 08-17-2015, 01:41 AM   #5
elel330
My Ride: 330
same thing that is happening to my car. I'm thinking its the EWS or the ignition switch.
elel330 is offline   Reply With Quote
Old 08-17-2015, 03:24 AM   #6
arkadur
My Ride: E46 323CI
The EWS should give a fault code?
There is any way to check this?
Old 08-17-2015, 04:12 AM   #7
paraklas
My Ride: ESS TS2 320ci
Failing intake/exhaust camshaft sensor?
Old 08-17-2015, 04:33 AM   #8
arkadur
My Ride: E46 323CI
No error codes.
I repealed The exhaust sensor 1.5 years ago
Old 08-17-2015, 06:47 AM   #9
Hoebama
My Ride: e46
in before jfoj... fuel pump
Hoebama is offline   Reply With Quote
Old 08-17-2015, 07:04 AM   #10
jfoj
My Ride: 330CiC, M5, X5
^ - too funny!
Assuming this is always a crank, no start condition, then:
Fuel pump - http://forum.e46fanatics.com/showthread.php?t=929501
Watch tach when engine is cranking - https://www.dropbox.com/sh/8bhu1rogj...OzYVu42da?dl=0
Intake cam sensor would be another possibility.
Try another key
Good luck.
Old 08-17-2015, 10:00 AM   #11
arkadur
My Ride: E46 323CI
Its not the fuel pump.
The pressure was stable all night.
Old 08-17-2015, 07:22 PM   #12
jayla
My Ride: E46 2002 4D facelift
I been told camshaft sensor sometimes don't flag code when faulty but mine does come up sometimes. I replaced mine as it was easy job. IF never replaced then clean it? have a look mine had old in the connnectors
jayla is offline   Reply With Quote
