Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 12-24-2012, 10:54 PM   #141
stevenluczynski
My Ride: Is Steel Blue
Originally Posted by verg64 View Post
Just installed the coilover and so far so good. I'm on 17's (square) with 42mm offset. FYI the front wheels were a bit close to the springs with less than half a finger room to breath so I added a 5mm spacer.
Question, the top nut on the front coilovers seems be a special nut that requires special driver. It's hex shape on the outside with a allen type hole in the middle. Anyone know what I need to do to tighten this? It clunks when I hit a decent size bump.
You put a socket on the outside and an Allan in the middle, then hold the Allan while tightening the socket
stevenluczynski is offline   Reply With Quote
Old 12-31-2012, 10:49 PM   #142
chapel
My Ride: E36 328i
So, long term reviews? How they going?
anyone have them in a northern region? I wanted to see how they resist corrosion. I've never seen ones that are powdercoated. Most of them use a coating over the threads to keep them from seizing up.
I'm torn between these and the Solo Werks S1 coils right now.
chapel is offline   Reply With Quote
Old 01-01-2013, 02:02 PM   #143
daveion2002
My Ride: 2001 330i
I just bought a set of these yesterday, will i need spring compressors to install? im going to buy new strut mounts so i will be leaving the old struts alone
daveion2002 is offline   Reply With Quote
Old 01-02-2013, 11:49 AM   #144
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
We are offering a 45 day money back guarantee for Street Edge. Basically you have 45 to try the suspension. If you don't like it you can return the kit and receive your money back.
We are that confident in Street Edge that we can do this.
We are coming up on our first full year of Street Edge. Since these are zinc coated there should be no issues with weather elements.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 01-02-2013, 04:38 PM   #145
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
I'm still undecided myself on what suspension & wheels i wanna go with. Are they zinc or galvanized? Also, can someone chime in on what's best in coatings for these coil over kits? Galvanized, powder coated, or zinc???
STREETFIGHTER50 is offline   Reply With Quote
Old 01-02-2013, 04:53 PM   #146
Sales@TSS
Sales@TSS's Avatar
Street Edge housing are galvanized with a coating to prevent corrosion. If you are in an area where your suspension will see the snow throughout the winter months I would highly recommend the KW coilovers that have a stainless steel housing.
Fresno, CA 93727
1-888-230-1288
Old 01-03-2013, 11:30 AM   #147
Sales@TSS
Sales@TSS's Avatar
Just a heads up the FREE shipping offer expires tomorrow.
Fresno, CA 93727
1-888-230-1288
Old 01-09-2013, 12:03 AM   #148
ericslife
My Ride: 1999 323i 4dr 5-spd.
As for a coating, I used the tech wax from Turner and sprayed the springs and body of the shock, then wiped off the excess. We get mostly rain in Nanaimo so don't worry to much about snow or even salt but a few days a year..
ericslife is offline   Reply With Quote
Old 01-14-2013, 12:01 PM   #149
daveion2002
My Ride: 2001 330i
I just Installed them and the springs are clunking. What did I do wrong?
Old 01-14-2013, 12:13 PM   #150
Sales@TSS
Sales@TSS's Avatar
Did you use OEM top hats? Did you torque to factory specs?
Fresno, CA 93727
1-888-230-1288
Old 01-14-2013, 12:17 PM   #151
stevenluczynski
Is the helper spring on top or bottom? And check your sway bar links, top hats are all tight
Old 01-14-2013, 12:21 PM   #152
daveion2002
My Ride: 2001 330i
Yes I did. torque on the top mounts
Old 01-14-2013, 12:23 PM   #153
daveion2002
My Ride: 2001 330i
They are on the top. Sway bar links are tight, but the strut sway bar mount is not strait when the steering wheel is strait. Does that matter?
Old 01-24-2013, 03:15 AM   #154
mksu19
My Ride: 04 325ci / 99 328i
Send a message via Yahoo to mksu19
I have a wagon with the sport pack, how much lower will these kit drop my car? Thanks!
Mona Bee!
Originally Posted by infinite012 View Post
I can see that I'm no longer needed in this thread, since mksu19 seems to be the expert in all things.
mksu19 is offline   Reply With Quote
Old 01-24-2013, 11:09 AM   #155
Sales@TSS
Sales@TSS's Avatar
Did you get this resolved?
Fresno, CA 93727
1-888-230-1288
Old 01-24-2013, 11:10 AM   #156
Sales@TSS
Sales@TSS's Avatar
Originally Posted by mksu19 View Post
i have a wagon with the sport pack, how much lower will these kit drop my car? Thanks!
front 1.2"-2.8" rear 1.2"-2.0"
Fresno, CA 93727
1-888-230-1288
Old 01-28-2013, 04:44 PM   #157
trj
My Ride: 325Ci
Kris, I sent you a PM about these sometime ago and we had a conversation about the drop being lower than sports suspension. Or lets say, on the highest setting, these will still lower the car by 1" than sports suspension setup.
I am planning to get a set of these in summer. I will be out of the country for a couple of months.
I would like to know from the long term users, how did it fare in winter?
Not just the tires but Suspension also plays a good part in handling in the weather, also the durability on the weather will also be my concern since I am in Colorado and we do see a fair amount of snow.
My factory sport dampers are still pretty good. But I am doing a refresh of suspension in summer so was thinking to get these instead of some other spring/strut combo.
My main objectives:
1) Ride comfort equal to factory sports suspension.
2) A little lower than factory sports suspension(not too much).
3) Better handling.
4) No bouncing of rear or too much feedback.
5) What is the maximum(lowest) and minimum(highest) drop compared to sports suspension on the coupe?
6) If someone makes a DIY with some key points, like how the top washers from the factory suspension are placed and torque values that will be great.
Old 01-29-2013, 01:32 PM   #158
Sales@TSS
Sales@TSS's Avatar
My main objectives:
3) Better handling.
The housing is galvanized steel. It can hold up to the elements of weather. If your E46 spends most of its time under snow then KW might be a better option because they are STAINLESS STEEL.
Looks like you need an actual customer to answer the rest of your questions
Fresno, CA 93727
1-888-230-1288
Old 01-29-2013, 02:25 PM   #159
trj
My Ride: 325Ci
I dont care about the rust (I wash my car very rigorously) but I am more worried about the performance in cold. Metal shows different properties when the temperature changes. Being in Colorado, we do see a fair bit of snow but unlike other places, the snow doesnt stay on the ground for weeks. Snowed 4 inches yesterday and tomorrow we have forecast of mid 50s.
You got it right Kris, I am looking for the actual customers who are running these in snow.
I want to know about the drop and comfort level. I would hate a bouncy ride. Still deciding between Koni shocks or these coils. And I am on stock 17s, if I do change the wheels, I will not go over 18s.
Old 01-29-2013, 04:12 PM   #160
Sales@TSS
Sales@TSS's Avatar
You should find your answers shortly. There's a good amount of people running these now.
Fresno, CA 93727
1-888-230-1288
Rate This Thread
