Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 12-24-2012, 07:12 PM   #681
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Cheapest you can do is $100 shipped for the projectors from ebay, $32 for the hid kit with bulb, $15 for the shrouds $30 for the wire harness if you want to use one
So $147 or $177
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-24-2012, 07:14 PM   #682
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
I'm talking about complete kits that have HIDs, projectors, angel eyes, harness, shrouds
lllRazorlll is offline   Reply With Quote
Old 12-25-2012, 03:41 AM   #683
Solidjake
Zero. Leaks.
Solidjake's Avatar
Umnitza has for 170 but they don't offer the correct shrouds
Old 12-29-2012, 12:25 PM   #684
effay
My Ride: 323Ci
solidjake: good write up , just a question do think having shrouds flat black decreases output in any way?
effay is offline   Reply With Quote
Old 12-29-2012, 03:31 PM   #685
Solidjake
Zero. Leaks.
Solidjake's Avatar
Shrouds don't make any difference, they might just look better when the lights are off.
Old 12-29-2012, 03:32 PM   #686
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 12-31-2012, 10:58 AM   #687
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
So Jake I'm thinking about doing quads too... What is the set-up? Do you leave the cutoffs out of the high beams? Or do you just have 4 lights with cutoffs and not really have high beams?
Schlag96 is offline   Reply With Quote
Old 12-31-2012, 12:27 PM   #688
Solidjake
Zero. Leaks.
Solidjake's Avatar
I actually ran into a problem with my quad setup so I might revert back. The low beams are leveled properly, but the extra projectors cannot be aimed properly.
Old 01-01-2013, 07:29 PM   #689
cruzer7
My Ride: 2003 325i
Quick questons.
Is glue really needed for the shrouds?
How do you aim the projectors? I searched, but couldn't any info.
cruzer7 is offline   Reply With Quote
Old 01-03-2013, 08:48 PM   #690
Kevinheidari
My Ride: 2002 325i
Originally Posted by cruzer7 View Post
Quick questons.
I just completed mine with the H1 projectors with the E46-r shrouds and I gotta say I wish I would've done this a while ago. I tried to shave down the centric rings that came from TRS but I couldn't get the shrouds to stay over the projector so I ended up using glue to get it to stay put (make sure to wipe any excess off the projector glass).
As far as aiming, I just turned the adjuster (looks like a little spiked wheel) on top of the headlight assembly just like I would with my previous halogens. Just make sure not to put it too high, you don't want to blind anyone.
Thanks again to everyone on here!
Kevin
Kevinheidari is offline   Reply With Quote
Old 01-07-2013, 09:57 PM   #691
trentcdrums
My Ride: BMW 323i Sedan
Did the black painting of the shrouds effect the lighting? Like distance of the beam?
Old 01-15-2013, 07:51 AM   #692
beattie_03
My Ride: 2002 318i
Edit: Moved.
beattie_03 is offline   Reply With Quote
Old 01-15-2013, 08:10 AM   #693
trentcdrums
What do you mean the correct shroud?
Old 01-15-2013, 08:16 AM   #694
beattie_03
My Ride: 2002 318i
They offer it with a standard shroud, not the E46-R one that is best suited for E46 look.
Old 01-15-2013, 08:55 AM   #695
trentcdrums
Crap.. I was gonna order their headlights today... Can you show me a difference in two pics.. I'm doll confused a bit. Don't know there are different shrouds.
Old 01-15-2013, 09:02 AM   #696
beattie_03
My Ride: 2002 318i
On the first page of this thread, you can see the projector on its own (no shroud) as he installs it.
As you go down, he gets to the part where he is spray painting the shrouds black, and in the new few photos you will see the shroud around the projector (camera lens looking thing). That is the E46-R shroud that alot of people use.
Otherwise the lights comes with a much smaller shroud as you would see with the kit you were looking at buying.
Basically, the standard one is alot smaller, and wont cover the projector (and your old silver reflector) properly or as well as the E46-R will. But it will still work and fit..
Old 01-15-2013, 09:19 AM   #697
trentcdrums
Does it effect performance?
Old 01-15-2013, 09:20 AM   #698
beattie_03
My Ride: 2002 318i
no
Old 01-16-2013, 07:51 PM   #699
beattie_03
My Ride: 2002 318i
I am confused about which harness I need, some people are saying 9006? TRS told me H7?
2002 Sedan (Facelift), OEM Halogen, just upgrading to one set of Morimoto H1s for now.
I am ordering:
Mini H1 projectors
E46-r Shrouds
Wiring Harness
Already have H1 HID kit.
Just need to confirm which harness? Cheers.
This one?
http://www.ebay.com.au/itm/MORIMOTO-...ht_3027wt_1397
Old 01-17-2013, 05:27 AM   #700
beattie_03
My Ride: 2002 318i
Anyone?
Rate This Thread
