Old 01-15-2013, 07:14 PM   #1
Drehmacht
My Ride: 325
Tips for driving in traffic with a manual?
Traffic sucks in the Boston area, bad enough where I don't like taking my e46 to work because of it.
Any advice/ recommendations (besides getting an automatic)?
Drehmacht is offline   Reply With Quote
Old 01-15-2013, 07:20 PM   #2
customisbetter
My Ride: 02 325xi
If you are a natural manual driver, traffic is no problem. I've never even considered it and I've never owned an automatic vehicle. I like having the option of always being in 1st gear for quick passes or opening opportunities in dense traffic.
customisbetter is offline   Reply With Quote
Old 01-15-2013, 07:23 PM   #3
Guest021715
Account closed.
Remove your CDV.
Leave a bit of room in front of you so you're able to creep in 1st gear.
Don't burn the crap out of your clutch by reving it up to 2k every time you need to move foreward.
Old 01-15-2013, 07:24 PM   #4
katu
My Ride: '04 330ci ZHP
As mentioned above, practice makes perfect. Things like a CDV delete or a clutch stop might help a little. Not sure what you're really looking for...
katu is offline   Reply With Quote
Old 01-15-2013, 07:27 PM   #5
wildirish317
My Ride: 2004 325Ci vert
Stay off the clutch. If you are going to be out of gear for more than 5 seconds, drop it in neutral and release the clutch. It saves wear and tear on your throwout bearing and your knee. It's a pain, but you get used to it. 1st gear is your friend. You can creep along pretty slow in 1st at idle.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-15-2013, 07:30 PM   #6
dknightd
My Ride: 2002 330 cic
get used to it, or, move
dknightd is offline   Reply With Quote
Old 01-15-2013, 07:31 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Comes with experience. Just learn how to drive the car in traffic nothing else to say.
Old 01-15-2013, 07:32 PM   #8
Guest021715
Account closed.
Says the proud owner of an automatic
Old 01-15-2013, 07:41 PM   #9
katu
ORLY? Next you're going to say mango's cooling system is still the original!
Old 01-15-2013, 07:55 PM   #10
Guest021715
Account closed.
It is. He's the biggest troll on this forum.
Old 01-15-2013, 07:58 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Whatever man. Come to NYC and suffer. I'd rather have my hand(s) free for the lady if you know what I mean.
Old 01-15-2013, 08:02 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, drive it like it's a truck. Keep your distance, don't feel like you need to keep spaces tight to prevent others from getting in...just let them pass.
I've been driving a manual longer than most here I'd bet.
Also, when you're off the gas, remember that those behind you assume everyone has an auto and uses brakes to slow down...in faster traffic when I 'lift' off gas, if someone is close behind, I'll tap brakes lightly a few times...just to make sure the guy behind sees a brake light.
You know, you can cruise in 1st without giving it any gas, right? Maybe 3-4 mph...if not slower. Even in NYC traffic, with enough distance in front, I can usually stay in gear a lot of the time.
HTH
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-15-2013, 08:07 PM   #13
Stinger9
My Ride: '04 330Ci
Vote YES on that mass transit bond initiative!!
Old 01-15-2013, 08:23 PM   #14
BluBurry
My Ride: 01' Topaz 330i
Get an automatic! Sorry had to...every auto trans thread is flooded with dumbasses saying "get a manual or manual swap" if I wanted one, I would have bought one.
But, I agree with the above. Leave some room between you and the car in front, put it in 1st and let the car drive itself. If traffic starts to stop, throw it in neutral. I hardly ever brake in traffic. I'm usually always rolling, variating between neutral and 1st.
BluBurry is offline   Reply With Quote
Old 01-15-2013, 08:23 PM   #15
repoman89
My Ride: 2003 330i Sedan
Go into work earlier and avoid traffic altogether
repoman89 is offline   Reply With Quote
Old 01-15-2013, 08:31 PM   #16
Stinger9
My Ride: '04 330Ci
Get rich and promoted in the process for your extra work. Get the beauty pagent winner as a consequence of success. All because you have a weak left leg.
Old 01-15-2013, 08:37 PM   #17
Zell
Zell's Avatar
My Ride: so turbo wow
Start working out.
Old 01-15-2013, 08:40 PM   #18
choxor
My Ride: JDM
Yup.
Practice makes perfect and it'll get easier as you figure out when you can rest your clutch leg by coasting, etc. There will always be some element of suckage, though, but you get used to it.
Old 01-15-2013, 09:37 PM   #19
mikeetastic
My Ride: lots of 3
play some good music!
mikeetastic is online now   Reply With Quote
Old 01-15-2013, 11:16 PM   #20
Drehmacht
My Ride: 325
Remove your CDV.
CDV? How much to remove? Andddddd clutch is probably burning every time i drive already
Moving.. not the worst idea haha maybe i'll just buy an automatic instead of moving
HTH
I tried keeping my distance today and 4 cars cut in front of me in a 3 second span. Masshole drivers. If I don't move right away when the car in front moves I get honked at
Will do
It's leaving work that's the problem
Originally Posted by Zell View Post
Start working out.
Already do
Nothing decent except sports radio at 5pm
