Old 01-14-2013, 09:27 AM   #61
FastHackem
My Ride: E60 M5
You can get the clamps at Autozone. Also, go ahead and grab a fuel pump relay form BMA.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-14-2013, 09:39 AM   #62
jfoj
My Ride: 330CiC, M5, X5, E93
Autozone or what every your local auto parts store has.
Once your BMA part order is stamped, do not be surprised if it is not on your door step the next day!
Old 01-15-2013, 08:32 PM   #63
jpbutler1983
My Ride: 2001 325Ci
So my parts should be in tomorrow!
I'm thinking about taking pictures and posting a step by step "how to" but I'm hesitant because I think quite a few exist already...
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 01-15-2013, 08:43 PM   #64
NJFF26
My Ride: 02 325xi
people make diagnosing a fuel pump harder than it is. Put a test light to the connector on the fuel pump. Have someone turn the key. If the test light goes on you are getting power to the pump and all the relays are fine. If the light goes on and you don't hear the pump prime its a bad fuel pump. If it doesn't light you aren't getting power to the pump. I just used standard hose clamps not the BMW crimp clamp. Just don't tighten it to much u risk breaking the plastic on the fuel pump that the fuel line goes on.
NJFF26 is offline   Reply With Quote
Old 01-15-2013, 09:17 PM   #65
always-there
My Ride: 2002 BMW 330I
Had the same problem in parking lot, stranded. It was the fuel pump the whole way. I replaced the filter/hoses/pump.
Old 01-15-2013, 10:23 PM   #66
Blueandwhite85
My Ride: E46
Nvm.
Blueandwhite85 is offline   Reply With Quote
Old 01-15-2013, 10:52 PM   #67
jpbutler1983
My Ride: 2001 325Ci
Test light sounds like a good troubleshooting tool... Where do you get one?
Old 01-15-2013, 10:52 PM   #68
jpbutler1983
My Ride: 2001 325Ci
Originally Posted by Blueandwhite85 View Post
Nvm.
Why the nevermind?
Old 01-15-2013, 10:53 PM   #69
jpbutler1983
My Ride: 2001 325Ci
That will be me tomorrow! Hope all goes well...
Old 01-16-2013, 08:33 AM   #70
Blueandwhite85
My Ride: E46
Originally Posted by jpbutler1983 View Post
Why the nevermind?
I responded to someone's post and decided against it afterwards.
Old 01-16-2013, 08:37 AM   #71
DHK
My Ride: 2002 BMW 325Ci
Lots of people think fuel pump when they are just flooded. Its very easy to flood these engines if you don't let the car warm up at before you shut it off.
DHK is offline   Reply With Quote
Old 01-16-2013, 09:13 AM   #72
jfoj
True, especially when outside temps are near or below freezing.
To clear a flooded engine on almost all modern fuel injected engines, before you turn the key to crank the engine, push accelerator to the floor and hold it to the floor while cranking the engine.
This puts the engine into "clear flood mode" fuel injectors do not spray fuel while accelerator is floored.
Once engine comes to life, quickly remove or reduce throttle angle and keep engine at fast idle (1500 RPM) for about 30 seconds to stabilize engine idle.
Old 01-16-2013, 09:15 AM   #73
jfoj
Test lights are actually very useful tools and most tool boxes should have one.
Any auto parts store should have them typically for under $10.
Here is an example - http://www.amazon.com/Advanced-Desig...rds=test+light
Old 01-16-2013, 02:07 PM   #74
jpbutler1983
My Ride: 2001 325Ci
The BMW is alive!
ID:	486316   Click image for larger version
ID:	486317   Click image for larger version
ID:	486318   Click image for larger version
ID:	486320   Click image for larger version
ID:	486321   Click image for larger version
ID:	486322   Click image for larger version
ID:	486324   Click image for larger version
ID:	486325   Click image for larger version
ID:	486326   Click image for larger version
ID:	486328   Click image for larger version
Old 01-16-2013, 02:19 PM   #75
FastHackem
My Ride: E60 M5
The BMW is alive!
EXCELLENT BUD!! Nice pics as well.
Edit: I will add a couple too:
Old OE VDO Pump:
New OEM VDO Pump
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-16-2013, 02:21 PM   #76
Blueandwhite85
My Ride: E46
The BMW is alive!
Great news. Glad we were all able to help!
Old 01-16-2013, 02:28 PM   #77
jpbutler1983
My Ride: 2001 325Ci
I could NOT have competed this task as completely, confidently, or as quickly without all of your input...
So kudos to you all! Fantastic install that was quite fun.
The biggest pain was putting the retainer ring back on... But that was my own fault.
I want to add something here...
The "bad" pump still ran when I plugged it in while it was out of the tank, so I guess it just wasn't supplying adequate pressure.
Another note, I can't hear the new pump running... So it's not as loud as suggested.
I'm pretty sure it was the original pump... So it lasted 167K miles! Not bad.
Lastly, I think this pump did a slow fail because my rpms are more stable now and it just drives better!
Old 01-16-2013, 02:31 PM   #78
Blueandwhite85
My Ride: E46
I could NOT have competed this task as completely, confidently, or a quickly without all of your input...
I wasn't to add something here...
The "bad"pump still ran when I plugged it in while it was out of the tank, so I guess it just wasn't supplying adequate pressure.
You can't hear it running from the inside or the outside of the car?
Old 01-16-2013, 02:32 PM   #79
FastHackem
My Ride: E60 M5
I second that notion. I was expecting it to hum loudly like I read all over the forums. I even watched a DIY on youtube and their new one was pretty loud. Mine is almost completely silent even without the sound deading material and seat still off.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-16-2013, 02:32 PM   #80
jpbutler1983
My Ride: 2001 325Ci
I tried all of the "flooded"protocols with no avail.
