Old 01-15-2013, 07:58 PM   #1
beattie_03
My Ride: 2002 318i
Quad Projectors from OEM Halogen
Hey,
I have a few questions about this retrofit in a quad setup. I noticed a fair few people in this forum have done it..
In order to go from stock OEM Halogen, I simply do the Morimoto H1 DIY, but twice, for the inners aswell, correct?
Secondly, when doing the inners, you can wire the H1's to your high beams using the bi-xenon function of the projector, which will make your inner become your high beam (by opening the cut off). Is this correct?
If so, it seems the bi-xenon functionality of the outers is wasted, or can you wire both sets to become low beams, and then open up for high beams?
My final question would be about wiring options, but I guess I will wait till someone can set me straight regarding the above to questions!
Thanks everyone!
beattie_03 is offline   Reply With Quote
Old 01-15-2013, 09:16 PM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Lightwerkz is your friend
PICS
Caesar is a member here and might jump in shortly. One on the members here that has had this done to their car might jump in also.
There is a DIY thread also.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-15-2013, 09:19 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes it can be done. Do you want each pair of lights to turn on separately? That is what I haven't been able to do yet.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-15-2013, 09:23 PM   #4
beattie_03
My Ride: 2002 318i
Great, just wanted to make sure it would work the with H1s.
Basically, I would have liked my wiring to be:
Outers/Headlights wired up as regular headlights.
Inners/Parkers to be wired up as regular parkers (parkers stay on when headlights are on)
So then, first turn of the dial will have the innter projectors on, second turn will have both sets on.
Obviosuly you do not NEED both sets on all the time, so I was simply going to wire a switch to the second second set, to provide an on/off override for the inners.
Is there any problems with this setup?
My only question is about the high beams, and if you can splice the bi-xenon wiring for both sets into the OEM highbeam wiring?
Old 01-15-2013, 09:40 PM   #5
FastHackem
My Ride: E60 M5
I haven't really looked at how the stock halogen headlight wiring looks but I imagine there is a positive wire for the low beam and a positive wire for the high beam on each side. I would run a separate relay harness for each low beam HID kit with the stock low beam wire on the right and left side as an input signal for each harness and the high beam wire on either the left or right side as the input signal for the third harness. Then hook the output from the low beam harness' to your HID kits and the high beam harness to the projector high beam motor. Does that make sense? Total of three harnesses, two HID kits, and four bi-xenon projectors.
To add two bi-xenon projectors on the models with stock xenon, I imagine you would need to tap the the stock high beam xenon motor signal and the low beam positive, then run two relay harnesses. One for the HID kit low beam and one for the new projector high beam motors.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-15-2013, 09:47 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well in my case I have OEM projectors and just added the mini's to my high beam bowls. For me to run them properly I still need to get a wiring harness, run a trigger wire so switched power and run a wire into the cabin to a switch.
Old 01-15-2013, 09:48 PM   #7
FastHackem
My Ride: E60 M5
Well yeah to have them come on separately you could kinda do what Beattie is talking about. Wire the input signal of the outer hid kit to the turn signal/parking light positive and then the inner hid kit harness input to the low beam positive.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-15-2013, 09:51 PM   #8
beattie_03
My Ride: 2002 318i
Wiring decisions aside, could you guys just confirm that all I will need is:
2 x Morimoto Mini H1 Prokectors Sets (with shrouds)
2 x Morimoto or any other H1 HID Kits
And thats it? Apart from relay harnesses for wiring?
Old 01-15-2013, 09:52 PM   #9
FastHackem
My Ride: E60 M5
Looks good. Jake?
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-15-2013, 09:52 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
2x morimoto mini projector sets
2x h1 ballasts with bulbs
2x shroud sets
2x wiring harnesses
Old 01-15-2013, 09:55 PM   #11
beattie_03
My Ride: 2002 318i
Sounds good! My only other question is if anyone has any experience with the Umnitza Mini H1 Projectors? They claim they are the same manufacturer I belive, they are $90 as opposed to $120 Morimotos from TRS. Thoughts?
Old 01-15-2013, 09:57 PM   #12
FastHackem
My Ride: E60 M5
TRS stands behind their products. You will have no issues with them. Plus the support is unbelievable. Umnitza.....read some reviews.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-15-2013, 09:58 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
Not too sure but I bought my projectors from ebay for 100 shipped. Looks like they are the latest version.
Old 01-15-2013, 09:59 PM   #14
beattie_03
My Ride: 2002 318i
True enough, it is only $30 a set I guess! Well I think these will have to be ordered soon then.
Morimotos Jake from ebay?
Old 01-15-2013, 09:59 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
Btw, to avoid the issue I have (not sure if it pertains to halogen only headlights) is do the following
Buy only ONE pair of projectors. Put both of them in one headlight, level them on a flat surface and see if both are lined up at the SAME height.
My issue is that my oem lows are leveled perfectly but my inner set of morimotos are pointing too low. I do not think I can fix that unless I cut into the bowls which I am NOT going to do.
Old 01-15-2013, 10:01 PM   #16
FastHackem
My Ride: E60 M5
Can you not just add some like 6/32 or 8/32 washers to the lower mounting screws to bring them up a bit?
Maybe not, never mind. I take it the stock angle adjuster is maxed out?
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-15-2013, 10:01 PM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
I have these ballasts
http://www.ebay.com/itm/Xentec-XENON...ac96e4&vxp=mtr
Old 01-15-2013, 10:01 PM   #18
beattie_03
My Ride: 2002 318i
Interesting. And your inner set on OEM projectors is infact just a regular halogen reflector like mine would be correct?
Old 01-15-2013, 10:02 PM   #19
beattie_03
My Ride: 2002 318i
Great, those are the ones I had planned for!
Old 01-15-2013, 10:02 PM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
It's a rather significant height. I will take pics tomorrow after work if I remember.
The projectors are held in tight with the back nut to the oem frame so that is a no go. I do agree with you on adding washers but that will make the cutoff extremely bad because you are pretty much beveling the light pattern
