Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#41 | |
#42 | |
2001 LSB M3 Coupe
#43 |
Saad Racing and HPF stage 3 both require built engines, we are comparing stage 3 builds correct?
#44 | |
Go stick it in your ass. And I was comparing basic setups on a non-built motor. With or without EMS it's half the cost...
#45 |
I think if prices don't change. Max PSI is going to sell a lot of kits...
#46 | |
If we are talking basic setups then the Saad Racing kit is only $9,999. If we are comparing stage 3, Saad Racing is still thousands cheaper than the HPf kit. Only comparison i see is that the Saad kit is not only the best kit on the market, but also the most competitively price kit too. Im sorry you are mislead on your information on the market but please educate yourself before posting up. Thanks |
#47 | |
But i don't think you get everything you need for 9.999. If so i am very interested! |
#48 | |
The cool thing about Saad Racing is the they use the same components on the stage 1 tuner system as the stage 3 system Stage 1 comes standard with: 3.5" stainless steel down pipe directly off the turbo with waste gate plumbed back in! Tubular pyramid merge stainless steel manifold 4" x 7" long air filter element Stainless steel motor mount bracket and billet aluminum engine mount Stainless steel charge pipe from the turbo to the intercooler for durability Gravity oil drain system World record setting turbo system The quality of all of their components are top notch. Garrett intercooler core, Tial bov and waste gate, Precision turbo, billet components used throughout. No one else has these components as standard in their kits. Recent dyno numbers put their kit at 940 hp to the tire on e85!!! Also, the Saad Racing e85 add-on system is $750 (not $1,200) which includes the sensor, bracket, custom mandrel bent stainless steel fittings, adapter fittings for the sensor, wiring harness for the Pro EFI and Teflon braided lines. It is also adaptable to either stage1 or stage2 fuel systems |
#49 | |
And a DME tune...well that'll be impressive if it's true. Either way looking forward to seeing some of these builds come to life...can't wait till I run into one at a runway event
#50 |
A few more pictures of product going into our build
Pauter I beam Forged Connecting Rods w/ ARP Hardware ![]() Pauter_BMW_E46_M3_Rod_1 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_2 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_3 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_5 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_6 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_7 by Redline Speed Worx, on Flickr ![]() Pauter_BMW_E46_M3_Rod_8 by Redline Speed Worx, on Flickr
.: Redline Speed Worx :. 908.223.7477
Tri-State's Premier APR Installation Center German Automotive Repair, Performance & Fabrication Shop Life - Click Me ! | We Complete Specialty Alignments ! ![]() |
#51 | |
#52 |
great to see other s54 turbo kits. good to see s54 platform move forward.
8 seconds 1/4 mile & sub 3 seconds 60-130 mph AWD M3X coming soon
4,23 s 60-130 mph E46 M3 TT 4,49 s 60-130 mph E36 M3 TT, 3,49 s coming soon RWD mode 8,45 s 60-130 mph 997 Turbo |
#53 |
I'd have to spend some time adding components/etc together to make a direct cost comparison.. but a HPF Stage 3 includes quite a few little bells n whistles like the gauges, meth kit, etc..
The best comparison would be a HPF Stage 2.5 vs a Saad Stage 3. The difference being Flex Fuel vs Meth. Saad's flex fuel setup being significantly less than HPF's meth setup. Ignoring that though and just going Stage 2.5 vs Saad Stage 3 without doing the math I think the HPF kit is still cheaper.. and more refined.. Saad builds race cars.. and he's rather good at it.. its just hard to beat the HPF Stage anything kit as far as refinement.. and thats not a knock against Saad, or anyone for that matter.. simply put JP built an incredible turbo setup for HPF and it shows in every nut, bolt and screw.. FSR is not far behind though, after spending some time with them I'm really impressed with their attention to detail. Source: Been there, done that.. a year and a half ago. If you're looking for wild, and lots of custom stuff.. I'd go Saad/FSR/ProEFI. If you're looking for an off the shelf kit that just works and can be installed by just about anyone... I'd go HPF... if you start deviating from the off the shelf setup thats where the HPF kit starts to deteriorate.
#54 | |
In my opinion all 4 vendors mentioned here build quality stuff, but like with everything in life they all have their good and their bad. It'll be up to what the customer wants in the end and how much they are willing to pay.
#55 |
Don't mean to jack the thread, but I have been looking for SAAD pricing for a while, even PM'd/Emailed the OP about it and no response. Where can I find the pricing/power outputs?
#56 | |
![]() Or: http://www.redlinespeedworx.com/ Last edited by E85head; 01-16-2013 at 03:20 PM. |
#57 | |
email me at JR@redlinespeedworx.com |
#58 | |
http://www.redlinespeedworx.com/saad...harger-system/ If you do the HPF tubular "upgrade" (yet to see results showing if this is even making more power than their cast manifold), add their intercooler, their piping, their BOV setup, their intake, etc.. you are in the same ballpark for pricing.. Kinda pointless to compare the companies other "stages" as they both accomplish their power figures through different components. HPF uses methanol to achieve higher power, thus they don't need a very extravagant fuel system (can get by with a tiny pump inline/small injectors). Saad Racing looks to E85 to achieve higher power, thus they need a much larger fuel system than stock which to do properly requires much more lines/fittings. The other "required" pieces aren't really needed unless you are pushing the setup to the max and want it very reliable. On your car that makes 800hp+, did you change out your driveshaft, differential, add a diff brace, add flex fuel with all sensors, etc..? If Saad is really coming out with a DME tuned setup, their Stage 1 kit would be in the same price range and offer similar components as MaxPSI's kit. I do like the fact that Saad's kit routes the intercooler piping up and over, uses a oil drain sump that appears plug/play and easily removable (MaxPSI posted a picture of their kit drain drilled/tapped in to the stock pan), etc.. Of course it would be nice to see more installed pictures of both setups to really draw a conclusion as to which kit one would go with. |
#59 |
Something to think about.. The vast majority of these known problems/trouble shooting scenarios come from the fact that the kit is almost overly complicated when above a Stage 1. The multiple trouble shooting threads or issues are almost always related to the meth system and it's pump/sensors/lines/fittings, the oil scavenge system and it's pump/lines/fittings, etc.. This is of course my opinion (been around a lot of tuner cars over the years) but looking at MaxPSI's kit, Saad's kit, and FSR's kit.. I highly doubt you will run in to many reliability issues that require extensive trouble shooting.
#60 | |
