Any E46 135i Brembo Calipers, rebuilt with aluminum pistons - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 11-14-2012, 06:49 PM   #1
Chad44
My Ride: 03' Imola 330i ZHP
I have these brakes that I planned to use myself, but I'm not in a place financially to finish building the kit.
What I have: (can choose to take some or all parts)
(2) front 135i calipers, rebuilt with stop tech aluminum pistons(oem ones have ceramic caps that crumble)
A set of lightly used OEM 135i brake pads.
135i caliper brackets, Unmodified, but I have a plan to modify the stock bracket for fitment on e46.
(2) e46 m3 rotor blanks
Set of hardbrakes.com titanium brake pad heat shields
I am into these parts about $1200 so far, but feel free to talk to me about the kit or what is needs to complete it.
Chad44 is offline   Reply With Quote
Old 12-06-2012, 11:06 AM   #2
Chad44
Just for clarification here- this kit is based off the kit available from ECS, however it is rebuilt with StopTech aluminum pistons, high heat dust boots and seals. These parts are $400, plus the titanium het shields are $135... This kit is overkill and incomplete for a street use car- but if you track your car, this setup is much more usable than that kit since the performance rotors, and ceramic tipped pistons are prone to failure under high performance driving use.
New price: $1,000
Old 01-16-2013, 11:20 AM   #3
Halibmw325ci
My Ride: BMW 325ci
Is this kit for e46 non m. Or m only?
Halibmw325ci is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-16-2013, 12:28 PM   #4
SUHLeen
My Ride: 2005 Saleen Mustang
It will fit with the unmodified bracket on a non-m, just the brake pad will be a few mm off (I have ran it this way without a problem lol) If you want it to fit perfect, you have to do what ECS did to align the caliper exactly how it should be. And they just use the M rotors because it is the right size. These are basically 6-piston brembo's branded for BMW, not a bad deal for anyone looking to upgrade. I can stop on a dime AND that is with the crappy stock pads!
- Phil
14 2500 Cummins Daily
11 335is - 6266 Sing Turbo 7 spd DCT
05 Saleen Mustang - forged, stroked, blown,... and on some juice
01 BMW 330ci - Totaled by some bish!
SUHLeen is offline   Reply With Quote
Old 01-16-2013, 11:42 PM   #5
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
good luck chad. what size are the ti heat shields? 0.5mm or 1.0mm?
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
crazyxzer0 is offline   Reply With Quote
Old 01-18-2013, 01:44 AM   #6
Chad44
The heat shields are 1.0mm
Old 01-18-2013, 01:51 AM   #7
Chad44
Glad you're happy with the setup, the alignment isn't off by much- in fact the bracket only needs to be shaved by 6.5mm in one dimension to be perfect. I spent a bit of time measuring and planning this out.
Also, the ECS kit doesn't use m3 rotors, rather they use the performance rotors for the 330 that maintains all the dimensions of a stock rotor, the m3 rotors are also the same dimensions with the exception that the rotor thickness is slightly greater at 28mm vs 25mm.
Old 01-18-2013, 01:53 AM   #8
Chad44
Just realize that you wrote "M rotors" and not "M3 rotors" ... My bad, well I'll leave my mishap up for others to see as it still offers a little nugget of knowledge about 330 vs m3 rotor specs.
Old 01-18-2013, 02:09 AM   #9
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
This is a hell of a deal. Too bad you can't hold onto them.
Sent from my HTC_Flyer_P512_NA using Bimmer App
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 01-20-2013, 07:48 AM   #10
wshgrntd
My Ride: 2007 335i m-sport
pictures?
wshgrntd is offline   Reply With Quote
Old 01-30-2013, 06:21 PM   #11
Chad44
ill be making the brackets, and have decided to keep them for as long as it takes for me to make, fit, test the brackets... then, who knows... i will see at that time if I can live without them, or not... I don't believe I will be tracking my car for a couple years due to financial constraints, so I may still sell when done.
Old 02-19-2013, 10:51 PM   #12
Krystian_E46
My Ride: E46 M3,AA3 ZHP,S544D
Send a message via AIM to Krystian_E46
Are these still available ?
- Krystian
http://www.facebook.com/kgawlak
Instagram : KrystianGawlak
Owner of many E46's :)
[Currently own 2004 M3, 2002 325i S54 M3 Wagon, S54 ZHP, 2004 ZHP HARD MOTORSPORT Flares & Centerlocks, 2005 AA 2.5 Kit ZHP(SOLD), S54 Sedan, 01 330ci and 1 Coupe 1 Sedan 1 E46 M3 parts cars]
Krystian_E46 is offline   Reply With Quote
Old 02-24-2013, 08:32 PM   #13
Chad44
Not currently- I've decided to make a bit more of a project out of them yet... I am selling the pistons/seals/boots to a friend, and will be making my own pistons, as well as stripping and powdercoating them as they show a little abuse... Currently planning to use a high heat powdercoating so they will withstand track abuse...
I may try to start finding/rebuilding and reselling these soon, so keep in touch if you're Interested.
Old 03-21-2013, 09:43 PM   #14
Chad44
I've got a top secret update... I've been playing with the machines at my uncles shop...
I made replacement pistons for these calipers out of stainless steel, and will be producing the mounting brackets very soon as well.
ID:	496562   Click image for larger version
ID:	496563   Click image for larger version
ID:	496564   Click image for larger version
Old 03-22-2013, 10:09 AM   #15
wshgrntd
Are you going to start selling the pistons?
Old 03-22-2013, 10:13 AM   #16
SUHLeen
What would it be worth to you if I send you a set of say..... some brackets that are already made for these that you can 'look at' haha
- Phil
Old 03-23-2013, 12:21 AM   #17
Chad44
Maybe.... Lol. I have a set that will be track tested soon, and a second set ill be rebuilding my calipers with... If I have interest, ill have a batch made. I have a 5 set minimum order to fulfill in order to have them run at the machine shop.
Old 03-23-2013, 12:22 AM   #18
Chad44
Thanks, but I have all the geometries worked out already, and even have a solidworks plan of the bracket.
