Old 12-14-2012, 11:55 AM   #1
zhenkaaaM3
My Ride: Fst'r then your e46
Clean my engine bay
I have a good powerwasher at work. Would this be safe hosing the whole engine down? What needs to be covered?
Does it need to fully dry to start it?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-14-2012, 02:22 PM   #2
SamDoe1
My Ride: 4cyl of fury
Just use a hose without any attachment. Using a power washer is asking for it.
You don't need to cover anything up but make sure you're not using any sort of pressure to wash it, not even a hose nozzle.
Way I do it is to soak the engine bay down with degreaser, agitate a little with a brush, hose it down, turn car on and drive around to dry off any remaining water.
Old 12-14-2012, 04:10 PM   #3
zhenkaaaM3
Its dusty on top. No grease anywhere
Alternator doesnr need covering?
Eugene
Old 12-14-2012, 10:09 PM   #4
Sofresh2Clean
My Ride: ...
Rofl so this is where you've been hanging out
Sofresh2Clean is offline   Reply With Quote
Old 12-14-2012, 10:12 PM   #5
Sofresh2Clean
My Ride: ...
The alternator DOES need covering or when water hits it, it will short out the battery (which is what happened to me). To clean my engine bay I just take a slightly wet rag and do a preliminary wipe down and get some armorall extreme tire gel and use another rag (dry) and wipe everything down again. Sometimes I apply it twice and within 5 minutes it settles down to a really nice shine. It looks even shinier when the engine bay is hot
Old 12-14-2012, 10:14 PM   #6
Arock1092
My Ride: Bmw M3
Powerwash it then drive around for 20min!
Arock1092 is offline   Reply With Quote
Old 12-14-2012, 10:38 PM   #7
Zardoz33
My Ride: 2001 325xi
I'd just stick with a normal hose, nozzle and buy some P21S Total Auto Wash. Use saran wrap with rubber bands to cover the alternator & any electrical connections that are visible. Spray the P21S all over the place, wait a couple minutes, then rinse with the hose and say goodbye to any dirt/grime/oil/etc. that's in your engine bay. Finally, use some 303 Aerospace Protectant to dress-up all the black plastic in the bay.
I'll get around to ordering more P21S sometime, so I'll show you before/after pics when I'm done.
Edit: Actually, the more I look around in our engine bay makes me not even want to use a hose, even on a low setting. Apply whatever degreaser/cleaner (careful what you use - some aren't safe for rubber hoses) to the affected area, then use a wet microfiber towel to wipe it off. Dry with another microfiber towel.
Zardoz33 is offline   Reply With Quote
Old 12-15-2012, 01:41 AM   #8
serdar255
My Ride: '01 325ci / '90 325i
Pics of engine bay, it will make it easier to assess what is really needed.
If it is just dust on the top use quick detailer and a rag.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 12-15-2012, 04:00 AM   #9
TOGWT
My Ride: Jaguar XKE
Avoid the [I cleaned engine and now it won't start] scenario by covering electrical / electronic and various other parts prior to using any cleaning products, sprays or water. If you’re unsure either protect with a covering and /or use WD-40 water repellent
The most important electrical components are sealed to be ‘water resistant’ or splash proof to resist water ingress that is to say against low pressure, water splashing upwards from the road that is encountered in the course of daily driving conditions, despite their coverings they are not ‘waterproof’. Rain or water splashed up into the engine is at very low pressure, very different from a pressurised hose or steam
“Engine Bay Detailing” - http://www.autopia.org/forum/autopia...ml#post1448628
I hope the information in these articles is of some help to you. If you have any further questions please let me know
TOGWT is offline   Reply With Quote
Old 12-27-2012, 04:46 AM   #10
Zardoz33
My Ride: 2001 325xi
I have a good powerwasher at work. Would this be safe hosing the whole engine down? What needs to be covered? Does it need to fully dry to start it?
I circled in red what I think, in my noob BMW owner's opinion you should cover when machine washing the engine bay. I probably missed some areas, so seasoned e46'ers can point them out.
I have all rubber weather stripping, disa, icv, throttle body, maf, cabin filter housing, engine covers, upper/lower intake boots and airbox off the car already because I'm doing maintenance....so, electrical connections to some of those parts are not circled. Plus, it's easier cleaning the weather stripping and engine covers when they're removed anyway.
I did a quick once-over by hand with a 91% isopropyl alcohol & water mixture on everything except for plastic/rubber parts & hoses just so you can actually see what the parts are. The bay was 10x dirtier before & was driving me nuts to look at, but I'm not going to bother doing a proper job right now. Way too lazy lately.
Hope that helped somewhat. Good luck.
Old 12-27-2012, 11:53 AM   #11
John in VA
My Ride: 328i/325xi
At least half of those items circled will not be a problem.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 12-27-2012, 11:59 AM   #12
zhenkaaaM3
I wouldnt think so either.
Eugene
Old 12-27-2012, 03:31 PM   #13
Zardoz33
My Ride: 2001 325xi
Depends how meticulous you want to be. Also, if you're a power washer noob or not, how strong of a degreaser you're using, etc.
lol Hey man you asked....but you're welcome anyway.
Old 12-30-2012, 07:41 PM   #14
Zack01GC
My Ride: 2001 330Ci/5
After being a detailer at a BMW dealership for longer than I'd like to admit, it is fairly safe to rinse a motor. I've never had an issue with mine or any of the hundreds I've done at the dealership, using the same process time and again.
-Cover engine with water-based degreaser/APC (I like Ardex Green Stuff Plus)
-Let sit 5 minutes, but do not let dry
-Rinse with a hose with a nozzle, generously.
-Dry with compressed air via blow gun
-Apply dressing of choice.
Here are the results of that process on my 112k mile 330ci.
Zack01GC is offline   Reply With Quote
Old 01-01-2013, 10:24 AM   #15
AudiEtr
My Ride: 330i
cover the alternator with a plastic shopping bag and wash away. Myself and several of my friends have had problems getting them wet. takes 2 sec to cover.....
AudiEtr is offline   Reply With Quote
Old 01-03-2013, 10:10 AM   #16
k20z1 L
My Ride: 04 330ci
Tin Foil FTW! It's so easy to cover parts with tin foil so I go a little crazy sometimes, better safe than sorry!
k20z1 L is offline   Reply With Quote
Old 01-16-2013, 04:19 PM   #17
Rudy540
My Ride: E46
I wish my engine stayed that clean, but unfortunately none of ours do, do you recommend covering anything?
Rudy540 is offline   Reply With Quote
Old 01-16-2013, 04:27 PM   #18
Rudy540
My Ride: E46
Old 01-24-2013, 01:50 PM   #19
mikeetastic
My Ride: lots of 3
what are recommended engine dressing?
TIA
mikeetastic is offline   Reply With Quote
Old 01-24-2013, 09:02 PM   #20
Zardoz33
My Ride: 2001 325xi
TIA
It depends on what kind of look you want. Some people like a "wet" look. I don't prefer that, so I go with 303 Aerospace Protectant.
