#1 |
Bluetooth, streaming music through bluetooth and Iphone connection
Hello-
I purchased the Dice mediabridge 1500 and I just installed it. There is a loud ticking when text is scrolling and the bluetooth says "phone linked" whenever I switch songs or do anything on my phone. It is like it disconnects the bluetooth and reconnects all the time. Is there a better solution to the Dice? Please let me know becuase I really want to return this. I want bluetooth through the steering wheel controls, streaming music from iphone through bluetooth and using steering wheel controls, etc. Basically everything the dice does, but without all the bugs i comes with. Thanks |
#2 |
My Ride: '06 330CiC, '03 M5
Not sure this is a better solution, but it is an option.
Make or buy yourself an Aux input cable for your head unit. http://www.amazon.com/BMW-Genuine-Au...+E46+aux+input Then buy one of the Belkin units. Supports A2DP, Bluetooth hands free phone calls and you can skip and pause music with the device. http://www.amazon.com/Belkin-Bluetoo...music+receiver Issues to be aware of - 1. you probably want to power the unit from the radio or switched power so it stays on when you turn the car off but goes to sleep or shut off when the radio shuts off. Also this will kill the BT connection when you leave the car. I was somewhere yesterday and I was hanging outside the car, BT still connected, however, my phone still rings and when I answered the call I could not hear, took me a moment to realize the BT link was still active. 2. you have to push the button to resycn the phone each time you enter the car. 3. If you are not listening to the Aux source like Pandora or a playlist, if a phone call comes in it will not mute your current audio from the radio or CD player. Most phones will ring anyway when BT is connected so you will need to pay attention, then bring up Aux on your head unit to use the hand free connection.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#3 |
100% star stuff
I have the DICE Bluetooth mediabridge and I am extremely happy with it. It actually made me look forward to driving my car again. The ticking you hear can be eliminated by turning off the scroll feature or by shortening a set of wires behind the radio. There is a DIY somewhere here for that. Also, you can change the announcement settings in the unit so it doesn't annoy you with the British accent.
There really isn't any other good option besides the Bluetooth mediabridge for the features you're looking for. There are combinations of other systems, but I have to say I am satisfied with my mediabridge. Try reseating the main connector on yours as well. One big feature I like about my mediabridge is that once I start the car, my phone instantly connects and I have full control through the steering wheel.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#4 |
Weagle Weagle
JFOJ, when you say you should wire this into the radio, is that because the 12v cigarette plug is powered even when the car is off? Should I just cut the adapter off the Belkin and wire it to the 12V accessory wires?
#5 |
I just purchased a Grom Audio device, has aux, bluetooth, usb charging, everything I wanted for not a bad price $124.99.
http://www.gromaudio.com/store/aux_a...connector.html Last edited by BimminLSB///M3; 01-17-2013 at 08:58 AM. |
#6 | |
Weagle Weagle
#7 |
#8 |
There are plenty of other aftermarket stereos with Bluetooth linking to the iPhone. The iPhone should link automatically every time the unit is powered on, with these units. There are also device interface's that will let you hook up your steering wheel controls to most aftermarket stereos, as long as the stereo has that capability built in. The easiest way to get advice on this would be to call Crutchfield. You don't necessarily have to buy from them, you can just take their advice, and buy elsewhere. I found that Amazon usually has lower prices than Crutchfield on most units.
BTW - February is the best month for buying this sort of stuff, since the new models are released at CES, which just wrapped up. You can get a good deal on last years models, which are usually no different on features, they just update the looks. |
#9 |
sub'd
![]() '02 325ci Smoked Turn Signals, Tail Lights, and Side Markers, 17"CSL Replicas, Plasti-Dip Grille and Reflectors, Carbon Fiber Wrapped Pillars Replaced Water Pump, Expansion Tank, Power Steering Pump, Drivebelt Pully, ABS Control Module, Passenger Window Regulator, VCG Dead '84 Mercedes 190E '95 Pontiac Grand Prix GTP '95 Mitsubishi Eclipse GS '99 Mitsubishi Eclipse GST '98 Mitsubishi Eclipse GSX '99 Cadillac STS |
#10 | |
Weagle Weagle
That's not too bad then. Last edited by WDE46; 01-17-2013 at 11:40 AM. |
#11 |
Weagle Weagle
**** I just found this post:
http://www.m3forum.net/m3forum/showthread.php?t=423044 Apparently you can just buy this: http://www.amazon.com/gp/product/B00...tofgamonlco-20 My car is equipped for the iPod so I can just plug this into the cord. HAHAHAH AMAZING! Now I forget if I uninstalled the iPod thing when I put in my aux cable. I hope I didn't! EDIT: If this link expires, the product is simply a small adapater that plugs into an Apple 30 pin connector and makes it bluetooth! Last edited by WDE46; 01-17-2013 at 03:59 PM. |
#12 | |
#13 |
Weagle Weagle
I just ordered this:
Patuoxun Bluetooth A2DP Music Audio Receiver Adapter for 30-Pin iPod iPhone Dock Speaker and this: Scosche passPORT Charging Adapter for iPod and iPhone My car has the OEM iPod connector installed. This adapter was made before Apple switched it's devices to the USB charging format (old was firewire). Therefore, the current adapter won't power this bluetooth adapter that was made for the USB charging iPhone 3G and up. So you use this charging adapter so the BT adapter can get power. This is going to be incredible. |
#14 | |
I have a 2002 325i Business radio No Bluetooth. If I buy this with the bluetooth will I have the full bluetooth functions with the steering wheel and all?
#15 |
Weagle Weagle
E46 iPhone 5 Bluetooth
I am reporting back on my experiment. I have installed the items from my post above. It works perfectly. The audio quality is quite good and comparable to the aux in hard wire. Here's a picture of the ridiculously simple setup. It took less than 30 seconds.
![]() I should add that steering wheel controls don't work. At least not in pandora. I haven't used the "music" app yet.
fa·nat·ic
Noun A person filled with excessive and single-minded zeal Last edited by WDE46; 01-21-2013 at 07:25 PM. |
#16 |
I am just looking to keep oem CD player in 2002 325 xi and add aux I'm confused with all the option tossed around what may be the BEST not necessarily easiest or cheapest experience for adding Bluetooth tech and wanting to keep the steering wheel controls...?
#17 | |
Weagle Weagle
fa·nat·ic
Noun A person filled with excessive and single-minded zeal |
#18 |
Thanks I'm leaning toward that but I'm seeing a ton of mixed reviews on the mediabridge and I can do w/I Bluetooth but won't give up steering wheel controls and would prefer to see text on CD player through iPod or aux..
#19 | |
I was in a local car stereo shop in Portland last week looking for other options to have bluetooth and to integrate with the steering wheel controls. I noticed they were an Audiovox dealer and was surprised the sales guy never mentioned or suggested the Mediabridge. The owner came over and said he had sold 6 units and ended up "buying back" 4 of them. |
#20 | |
