Old 01-14-2013, 01:13 AM   #1
Variant
My Ride: 2001 BMW 330i
Removing Lock Cylinder - "Blind Plug"
Someone broke off my lock cover (leaving portions of the plastic clips stuck in the lock cylinder) -- I've ordered a replacement but need to remove the lock cylinder so I can clear out the remnant plastic cilp parts.
From reading various threads (here) along with Bimmian's instructions for their keyhole cover, it seems you need to remove a plug in the side of the door to access a screw which keeps the cylinder in place.
See attachment for what I'm referring to.
However, for the life of me I can't figure out how to get it to come off and at this point probably need to replace it (appears to be P/N 51211975404) from prying at it.
Perhaps I need to remove the interior door cover to access it properly from the inside? Bimmian's instructions make it sound simple ("fold it back").
EDIT: 2001 330i
Variant is offline   Reply With Quote
Old 01-17-2013, 10:19 AM   #2
Variant
Bump. Anyone?
Old 01-17-2013, 11:53 AM   #3
boostntsi
My Ride: 330i
Put the your key in the lock cylinder and use it as leverage...move it side to side as you pull it out. That worked for me...
boostntsi is offline   Reply With Quote
Old 01-17-2013, 12:30 PM   #4
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Maybe these pictures will help you.
http://www.bmwgm5.com/lock_cylinder.htm
The sedan has the hole plug, but, the couple just have a rubber flap (the link above currently shows the sedan, but, will be updated soon to show the coupe)
scottjoh is offline   Reply With Quote
Old 01-31-2013, 11:32 PM   #5
Variant
Great pics. Makes it look like it pops right off! Mine won't budge (have seriously chipped it trying too, haha).
Old 02-01-2013, 11:44 AM   #6
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Its just a rubber plug, pop it out with a flathead.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
